Old 03-02-2010, 10:46 AM   #126
Cherub
Cherub's Avatar
Re: 79 GMC Sierra LWB 6.0L swap
Originally Posted by 79gmc5.3 View Post
Thanks Bob.... I knew if I asked, you guys would have the answer. Not much is going on, getting the last few parts, temp sending unit for the p/s for my gaugeand few misc parts. Still not sure about the original oil pressure sending unit, was told that if you do not use it it would give a low pressure code in the ECM and shut down the engine. Do you know anything about that? Think I am going to tap the oil cooler line fitting and use that.
Here is another forum talking about the same issue.
http://www.ls1truck.com/forums/lsx-t...-gauge-s-2.htm
Cherub is offline   Reply With Quote
Old 03-02-2010, 11:21 AM   #127
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Originally Posted by Cherub View Post
Im just catching up on your thread. If you havent found a pedal yet i have one sitting in my garage from a 2003 lq4. I went with drive by cable instead.
well i kept reading and saw you picked one up already.
Yea thanks anyway, the local pull a part was very reasonable. Why did you go cable?
What ever the mind of man can conceive......... he can achieve!
My built thread http://67-72chevytrucks.com/vboard/s...d.php?t=375914
1979 GMC Sierra 6.0 L 4L60E
1995 Mustang GT 347
79gmc5.3 is offline   Reply With Quote
Old 03-02-2010, 12:06 PM   #128
McMurray76
subscribed
McMurray76 is offline   Reply With Quote
Old 03-02-2010, 03:07 PM   #129
Cherub
Cherub's Avatar
I dont have any welding tools or skillz so it was just simpler to add the sensors in while the harness was getting reworked instead of chopping and welding getting the pedal to work. So i guess for my skill set it was the best route
Old 03-02-2010, 06:42 PM   #130
D.FENS
You guys posting up all the details of your swaps are probably more help than you know.
Still trying to decide if I want to swap a 6.0 / 4L80E into my dually, but searching and digging through all the various build threads made me a little smarter than I was before. Thanks.
D.FENS is offline   Reply With Quote
Old 03-02-2010, 08:47 PM   #131
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
I would not have tried this if it were not for this forum. I know what ever problem I have someone on this board will have an answer. Best forum by far for this type of swap. Go ahead and dive in. You want be sorry.
1995 Mustang GT 347
Old 03-02-2010, 09:21 PM   #132
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Yeah man, we've all got your back. Do it!!!
--Josh
Old 03-02-2010, 11:55 PM   #133
D.FENS
Got a couple of O/T projects in line ahead of the dually (one's almost done and the other won't take too long, hopefully), so I got plenty of time to do the research and ask all the dumb questions beforehand.
New trucks run anywhere from 25 to almost 50K. Something tells me I can upgrade my $2500 dually to a late-model drivetrain and get a few more years out of it for a little less than the price of a new CCD.
Thanks again, guys.
Old 03-03-2010, 07:42 PM   #134
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Just a couple of pics because I know how much you guy like them. D/S battery tray and test fit on factory filter box. Fits great just like soule64 said it would.
1995 Mustang GT 347
Old 03-04-2010, 09:59 AM   #135
soule64
soule64's Avatar
Good stuff! Sorry for not providing more details even though several people asked, but it's been a hectic few weeks. I am glad it worked out for you and it looks great! Have you thought about where to re-position the radiator overflow bottle? A '99 Tahoe fits ok next to the air cleaner on the fender, but it's a little too long for the inner fender (about an inch). I am hitting the salvage yard this weekend and will let you know if I find anything that'll work.
soule64 is offline   Reply With Quote
Old 03-04-2010, 01:13 PM   #136
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Hey thanks a lot. Yes it worked out great the overflow bottle will work where it is but it is a little hard to get to. On the bottom of the filter box there are 3 posts for lack of a better word, 2 are on the engine side look like push lock pins. Do they need the rubber groumets in the battery tray? and the drain hole post near the fender looks threaded does it have a plastic nut? Mine was already removed from the truck so I was unable to see how it was secured.
1995 Mustang GT 347
Old 03-04-2010, 06:23 PM   #137
soule64
soule64's Avatar
I didn't use any grommets (which is why I probably still have a tilt...). I ended up breaking one of the push-pins (from the force of having to extend the air tube I think) so I replaced it with a 1/4"x20 1" bolt. I couldn't make room for the bottle so I am going to try something else. If you look in one of my pictures you will see a castleated nut (from a ball joint I think!) holding down the drain. It's the only thing I had on hand that would fit. I am sure that the original was a nylon nut or something, but it didn't come with mine, either. I will find something better and let you know.
Old 03-05-2010, 08:20 PM   #138
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Soule64; went to the dealer today to see how that filter box is installed. It does have two rubber gourmets and a plastic nut so I ordered them today. Less than seven bucks. Guy let me measure the pan to get the hole size and pattern from. He was real interested in seeing the truck when I'm finished, he has an 81 Silverado.
1995 Mustang GT 347
Old 03-05-2010, 11:19 PM   #139
menace121978
menace121978's Avatar
^^^ that is cool!!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 03-09-2010, 01:48 PM   #140
soule64
soule64's Avatar
Thanks - I'll have to do the same thing. Throw a pic up of the drain nut if you get a chance. Thanks!
Old 03-10-2010, 12:39 PM   #141
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Went to the dealer yesterday to get the groumets and the "nut" ,but it was not a nut it was a type of plate that was part of the bottom tray. You could not buy it seperate so all I got was the groumets. I am going to just get a nut like you did. I will take the battery tray out to mount the filter box and take a pic of it when I am finished.
1995 Mustang GT 347
Old 03-10-2010, 01:45 PM   #142
Jhogan830
Jhogan830's Avatar
Hey man where did you buy those guages? im dieing to replace mine and i REALLY want some digital ones! if you could PM me the place/website id be really greatful im also in the process of building my 84 LWB needs work but it gets me around for now =D
Jhogan830 is offline   Reply With Quote
Old 03-11-2010, 05:52 PM   #143
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Got my gauges from Dakota Digital easy to install and I like the way the look. Here is a link: http://www.dakotadigital.com/index.c...rod/prd158.htm
Very small update: Got the motor mount plate for the P/S modified (Thanks to Bob)and the clam shell installed, it clears the A/C compressor so that's good. And of course the D/S was a good fit any but I know how you guys like pics so here they are. Got the Oil cooler line block off plate from Nook & Tranny with the tapped hole for the oil pressure sending unit installed. Will be doing a test fit to get the engine pedestal modified for the D/S (Thanks to Bob) this weekend. I will post pics as soon as I get them. Slow and Steady!!!
1995 Mustang GT 347
Old 03-12-2010, 11:58 AM   #144
fpjr0
fpjr0's Avatar
lots and lots of progress,,, while I am still waiting for my tranny to get fix,,, I miss my truck....
ONCE YOU GO LS, YOU NEVER WANT LESS!!
fpjr0 is offline   Reply With Quote
Old 03-15-2010, 07:58 PM   #145
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
OK.... Progress is progress no matter how small.......... I also got a friend to weld the motor mount stand on the P/S for the new motor mount location should get it back in the next day or so. Should have nice weather this weekend will try to install this bad boy
1995 Mustang GT 347
Old 03-15-2010, 09:19 PM   #146
STOCKISH
STOCKISH's Avatar
Awesome, cant wait to see it in the engine bay.
--Josh
Old 03-16-2010, 07:25 PM   #147
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
OK... Now I have everything ready. Got the engine mount modified and installed, Drilled the new hole pattern for the new motor mount location, the filter box is installed. A few pics of the rubber grommets that hold the filter box in, still need to get the nut to secure it, but I am pleased at how it turned out. Covered the hole left in the intake tube. I think I am ready..... hopefully I will install the engine and tranny this weekend I have a 3 day weekend so I should have it in soon.
1995 Mustang GT 347
Old 03-20-2010, 01:56 PM   #148
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Finally some real progress! Put it in last night, no real problems which scares me! but will use the next few days running fuel lines, wiring and odds and ends like that. Still waiting for the harness and ECM from W4M. One step closer!!!!!! Looks right at home in there!
1995 Mustang GT 347
Old 03-20-2010, 06:47 PM   #149
menace121978
looks great in there! nice progress buddy
"Dennis the Menace"
Old 03-20-2010, 08:51 PM   #150
STOCKISH
STOCKISH's Avatar
Looks awesome. Great progress.
--Josh
