Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 04-08-2011, 12:35 AM   #126
Captainfab
60-66 Nut
Re: Camaro Caliper Brackets
I checked out the Centric Camaro calipers on rockauto.com, but there wasn'r much info on just what you are getting. It didn't say whether or not if the bracket is included. I would be curious if anyone has bought these yet, anf just what all is included.
As for the hub size, I have found there to be a bit of tollerence with the hub bore on the various rotors. If you do find that you have a slightly tight fitting rotor, you could likely take care of it yourself as long as you are careful and take it slow. You could either remove material from ther axle hub, or from the ID or the rotor, with a file, or maybe a die grinder with a flap wheel. We're talking about only a couple thousandths.
Originally Posted by Project1970 View Post
Yeah, no core even. Love Rockauto!
I checked Centric, the Impala rotors are based on a 3.07" hub size and the 5-lug C10 drums are on a 3.10" hub size. Order custom axles, or just have a shop turn .03" out of the inside diameter of the rotor?
Old 06-11-2011, 11:56 PM   #127
71Longbed
Not Mine But A beauty
71Longbed's Avatar
i have a question about the brake line tubing since your changing to disc would that mean you would have to change the brake line tubing to 3/16ths instead of 1/4?
68 Chevy Shortbed 454/400
2000 Chevrolet Camaro SS 6spd
2011 Silverado 5.3 6spd auto
71Longbed is offline   Reply With Quote
Old 06-12-2011, 12:42 AM   #128
Captainfab
60-66 Nut
I haven't seen any info that shows any advantage of using 3/16ths versus 1/4". Unless you're re-plumbing your truck anyway, I would leave the 1/4" line to the rear.
Old 06-12-2011, 08:09 PM   #129
71Longbed
71Longbed's Avatar
i need to replumb because there is no line there whatsoever right now should i go with 3/16
Old 06-12-2011, 11:57 PM   #130
Captainfab
60-66 Nut
All the GM factory 4 wheel disc cars and trucks that I remember looking at were 1/4" line to the rear. So I know 1/4" will work, but I don't know for sure about 3/16".
Edit: I just realized I should clarify something. The 1/4" line to the rear, would just be from the proportioning valve to the hose that goes from the frame to the differential. Then from the tee on the end of the hose, the lines should be 3/16" to each wheel.
Old 06-17-2011, 02:41 PM   #131
Nova_Cobra64
Nova_Cobra64's Avatar
I am at the stage of starting to put my chassis back together with this setup for rear brakes. I did a quick review of the discussions here and didn't notice a direct answer about the e-brake cables. Do the factory cables work just fine? Any simple mods needed? I need to buy new anyway, just wondering if there is a kit that would make more sense than going with the factory setup.
2004 Silverado - Beater
1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683
2011 Aveo - Work commuter
2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck.
Nova_Cobra64 is offline   Reply With Quote
Old 06-17-2011, 04:09 PM   #132
Captainfab
60-66 Nut
By 'factory cables' are you referring to the factory truck cables or the factory Camaro cables? I don't think either one will be a simple connect and work situation. I would think a combination of the two, since the Camaro cables will fit the bracket on the calipers. Then you will likely need to connect/splice those into your original truck cables. Alternately, you may be better off with made custom cables once you figure out the required lengths. If you don't have someone local that can make up the cables for you, I believe a couple of the suppliers that specialize in brake line tubes, can make them up.
Old 08-16-2011, 07:54 PM   #133
71Longbed
71Longbed's Avatar
also interested if any one has hooked up the e-brake cables if so how
Old 08-16-2011, 11:45 PM   #134
Captainfab
60-66 Nut
I haven't installed a set of these but I am going to try and look into this issue and see what I can come up with.
Old 08-16-2011, 11:54 PM   #135
Nova_Cobra64
Good stuff. I've been meaning to get mine mounted and figure out the cable setup but it is one of the smaller "loose ends" type of projects that I have put on the back burner to get the ball rolling on some of the major items. It'd be cool if somebody gets a setup figured out before I get to that point, but if not I'll be sure to share whatever setup I come up with.
Old 10-07-2011, 03:55 PM   #136
TRUKLUVR
JOHN! All i need is a mailing address to send my money order to. Please give me a call at (613)7357691.if no answer please leave voice mail. email at home does not work.Just need call from you to set things in motion-thanks karl (TRUKLUVR)
TRUKLUVR is offline   Reply With Quote
Old 10-07-2011, 11:26 PM   #137
Captainfab
60-66 Nut
I'll try and give you a call tomorrow (Saturday)
Old 10-09-2011, 11:58 PM   #138
Captainfab
60-66 Nut
I called yesterday and left a message.......
Old 10-31-2011, 01:29 PM   #139
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Has anyone actually made this work and driving with this kit? I am looking for pics of the complete set up. I have bought the kit and have the parts list for it, just trying to get a visual of the parking brake cable set up with the info that comes with it.
Thanks,
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 10-31-2011, 02:06 PM   #140
dznucks
dznucks's Avatar
Are these brackets still available?
dznucks is offline   Reply With Quote
Old 10-31-2011, 11:10 PM   #141
Captainfab
60-66 Nut
I'll see about getting a Camaro e-brake cable, and hopefully I can find time to get something figured out for you guys.
Thanks,
Smitty
Old 10-31-2011, 11:12 PM   #142
Captainfab
60-66 Nut
Yes, these are always available.
Old 11-03-2011, 08:40 AM   #143
71meangreenc10
Thanks CPTFAB,
Just want to make sure I am not going down the wrong path with the park brake.
Also:
FENCO brand calipers come with the park brake mounting brackets new and installed, most parts stores I have checked only sell the rear caliper without anything.
Smitty
71 C30 Wrecker
Old 11-10-2011, 12:14 PM   #144
jbice70gmc
jbice70gmc's Avatar
I'll take a set for my 70 GMC. P/P sent.
1969 GMC SWB Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=486320
jbice70gmc is offline   Reply With Quote
Old 11-10-2011, 12:46 PM   #145
jbice70gmc
jbice70gmc's Avatar
Don't know if it matters or not but I have ordered a set of 5x5" axels from mosier. I have the early model 70 GMC with the narrower rearend. Thanks
Old 11-11-2011, 12:56 AM   #146
Captainfab
60-66 Nut
Your payment has been received, and your brackets shipped today. Thank you for the purchase
The one thing you will want to be sure of on those axles, is that they make the drum/rotor register the correct size for the rotors. The register hole on the rotors are aprox 3.06"
Old 11-12-2011, 02:03 AM   #147
jbice70gmc
jbice70gmc's Avatar
Ok thank you for that info and I appreciate the quick response to my request.
Old 11-12-2011, 07:34 PM   #148
jbice70gmc
jbice70gmc's Avatar
Wow that didn't take long at all. Ordered them on Thursday and received them at my door on Saturday. Thanks John
Old 11-12-2011, 10:39 PM   #149
Captainfab
60-66 Nut
Wow,I didn't think you would get them by today since Friday was a holiday.
You're welcome....I appreciate the business, thanks.
Old 11-24-2011, 01:53 PM   #150
derek6787
Backwoods Body
Will these work on the 88-98 truck 10 bolt?
derek6787 is offline   Reply With Quote
