Old 04-29-2010, 07:42 PM   #126
handsomerob
handsomerob's Avatar
Re: 572 update
Hey, no I'm not getting new gauges, I'm using the stock ones,
Here are a few other pics, I got the new drivesgaft in today, and I modified one of the A/C lines, I actually recieved a bunch of parts, Fuel pressure regualtor, Fuel shut off switch, exhaust pipes, wheel bearings etc.
So much stuff so little time. I spend more time working then taking pictures.
handsomerob is offline   Reply With Quote
Old 04-29-2010, 07:52 PM   #127
highperf4x4
Re: 572 update
Dang, I wish I had that problem of more stuff than I had time to install.
That driveshaft looks awesome!
Question I forgot to ask though. What's up the 2 different length axles in the previous pics?
highperf4x4 is offline   Reply With Quote
Old 04-29-2010, 07:54 PM   #128
handsomerob
Re: 572 update
One is the original Axle, the other is an axle blank, needs to be cut to length and machined. I'm actually goin another way though and having Dutchmen machine some.
Old 04-29-2010, 08:06 PM   #129
highperf4x4
Re: 572 update
Cool. Who is Dutchmen?
Old 04-29-2010, 08:11 PM   #130
handsomerob
Re: 572 update
thats what I thought too, I actually called Strange and they said they couldn't help me, but they referred me to Currie, Currie said they couldn't help me with a full floating axle setup, and to call Dutchmen, Dutchman aparently can make any axle you want. they quoted me $295 US for 2 new axles made of 1541U steel significantly stronger then stock.
So if anyone needs Axles give dutchman a call.
http://www.dutchmanaxles.com/
Old 04-29-2010, 08:31 PM   #131
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: 572 update
hey could you give me some info on your A/C hose mod I'm going to have to do some mods to mine for the silly A/C thaqts mounted on top of the intake
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 04-29-2010, 08:35 PM   #132
handsomerob
Re: 572 update
What exactly would you like to know?
I basically ordered all new everything from LMC, then I ordered a new primary line for my new 134a compressor that way I have the high and low side connections. Then I cut the original line off so I could use the 180 degree bend from the factory install, I cut the 80 degree bend off the new line and and attached the piece from the old line. I will be assmbling the A/C system in the next week or so, I'll post pics of it when I'm done that part.
Old 04-29-2010, 08:50 PM   #133
Hottrucks
Hottrucks's Avatar
Re: 572 update
what is the piece you used to join the two togetether its neat and clean...mine will be a blend off caddy hases and the stock truck stuff..I' trying to keep it looking stock
Old 04-29-2010, 08:57 PM   #134
handsomerob
Re: 572 update
Umm thats a tubing coupler it's one of our GM products, I'm sure there are many companies that make them, it's basically a compression fitting that gets pressed into place. That black tool in the background is what compresses the fitting on.
Old 05-01-2010, 01:28 PM   #135
handsomerob
Re: 572 update
Well here are a few more pics, nothin' fancy.
Black spray paint for the condensor
POR 15 for the frame
Ball flanges to connect to the headers
Old 05-03-2010, 06:04 PM   #136
handsomerob
Re: 572 update
well started modifying the driveshaft hoop today . . .
Pre modification, the hoop has to be lowered and moved to the right (passenger side)
Hoop removed
Hoop modified
I'll have more pictures tomorrow . . .
Old 05-03-2010, 08:45 PM   #137
Hottrucks
Hottrucks's Avatar
Re: 572 update
does your truck have any drop???? I may run into the same issues.....
Old 05-03-2010, 10:24 PM   #138
hiwaydave
Re: 572 update
Did you have to box or beef up the frame?
hiwaydave is offline   Reply With Quote
Old 05-04-2010, 12:44 PM   #139
handsomerob
Re: 572 update
No there is no drop on this truck, it's factory stance.
And as of yet I have not boxed or beefed up the frame, once the truck is driving we may need to strenghten it.
Old 05-04-2010, 08:22 PM   #140
highperf4x4
Re: 572 update
Can you paint a condenser? I thought it screwed up the cooling process for the freeon?
Old 05-04-2010, 08:31 PM   #141
handsomerob
Re: 572 update
Well it couldn't hurt because it came spray painted silver, so I gave it a coat of black, same thing as the Radiator shop spray painting your rad black.
Old 05-04-2010, 08:34 PM   #142
highperf4x4
Re: 572 update
Yeah but I thought the temp of a condenser played havoc with the freeon? I don't really know much about it though. I just hear stuff and never know what is actually right.
Old 05-04-2010, 08:36 PM   #143
handsomerob
Re: 572 update
I'm afraid I'm in the same boat as you . . . but ignorance is bliss . . .
Old 05-04-2010, 08:53 PM   #144
handsomerob
Re: 572 update
Well as promised here are some more pics . . .
Modified hoop installed
Driveshaft clearance
Single piece driveshaft installed
Old 05-04-2010, 09:48 PM   #145
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: 572 update
Sweet.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 05-04-2010, 10:41 PM   #146
highperf4x4
Re: 572 update
Holy crap that looks good!!
So, you just flipped it over?
Old 05-05-2010, 12:48 PM   #147
handsomerob
Re: 572 update
Nope, I had to cut a section out of the passenger side, and move it to the driver side, then I had to slice into the top section and spread it upwards, then cut a section out of the bottom and close it up. I then moved the section I removed from the bottom to fill the gap in the top. then I just filled all the holes and smoothed the whole thing out.
Old 05-05-2010, 01:10 PM   #148
Newtz67
Newtz67's Avatar
Re: 572 update
Wow! That came out really nice!
Newtz67 is offline   Reply With Quote
Old 05-05-2010, 06:00 PM   #149
handsomerob
Re: 572 update
Well I hung the exhaust today, still need to make up some tailpipes.
here are some pics.
Old 05-05-2010, 08:25 PM   #150
handsomerob
Re: 572 update
Anyone have any opinions on magnaflow mufflers? I'm wondering what these will sound like once I fire this thing up.
