Old 04-05-2010, 10:13 PM   #126
Captainfab
60-66 Nut
Re: My whole braking system - thinking out loud
Got some parts ordered this morning......
Old 04-06-2010, 12:10 PM   #127
suttoncurt
suttoncurt's Avatar
Originally Posted by smashingchuck View Post
Guess what came in today! Now to save some more cash for some rotors that don't rust...
What part number did you order smashing chuck ? So i need four of the exact same d52 willwood calipers with the astro rotor and captin fab bracket? thanks
suttoncurt is offline   Reply With Quote
Old 04-09-2010, 12:33 AM   #128
Captainfab
60-66 Nut
OK I got some parts today. Everything looks good as usual and fits like it should. I was a little concerned about what the cut quality was going to be like on the 1.250 thick spacer but it looks awesome. Although I guess it should considering it was cut with a 400 amp high def plasma.
I got one set all cleaned up and assembled and took some pics so you guys can see what you're buying. So far I have just used a stock D52 caliper. smashingchuck has one of his Wilwood dual piston D52's on it's way to me for a test fit. I'll be posting a thread in the Vendors marketplace this weekend officially offering these for sale. Those of you that already said you want a set, send me a PM and we can work out the details.
Old 04-09-2010, 12:49 AM   #129
BossHogg69
motor exploder
BossHogg69's Avatar
That looks good and plenty stout also!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 04-09-2010, 01:45 AM   #130
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
wow, those look great! Do you think using countersunk bolts would reduce the strength too much?
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 04-09-2010, 01:59 AM   #131
Captainfab
60-66 Nut
Thank You
I wouldn't think it would. I believe flat heads are typically GR8 anyway.
Old 04-09-2010, 07:56 AM   #132
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
that does look great, i was wondering are the calipers more or less clocked to look like if they are in the same position of the front ones? so did you break down a final price? If im not wrong we would have to remove the axles to do the swap anyways right? i thin thats the only way to remove the backing plate for the drums.
staggerd86c-10 is offline   Reply With Quote
Old 04-09-2010, 08:24 AM   #133
nlped
nlped's Avatar
I'll be curious to see if these brackets will work with the dual piston design of the Wilwood caliper. The brackets look GREAT!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 04-09-2010, 09:56 AM   #134
lolife99
67-72 parts collector,…
lolife99's Avatar
PM sent.
Keith
Convert to disc brakes.
Old 04-09-2010, 11:55 AM   #135
suttoncurt
suttoncurt's Avatar
Pm sent - Bracket looks great !
Old 04-09-2010, 11:58 AM   #136
suttoncurt
suttoncurt's Avatar
The D52 willwood is a direct replacement for the GM D52 .
Old 04-09-2010, 01:02 PM   #137
nlped
nlped's Avatar
Oh, I know that, but I was just looking at how this bracket seems to follow the shape of the single piston D52 caliper, where the overall shape of the Wilwood would seem to be different due to the dual piston design. The factory spindles and aftermarket spindles have a much larger open area than this bracket is all I was concerned with. Do not get me wrong...the piece looks phenomenal, I just was wondering out loud about the relief size where the actual caliper body fits.
Carter
Old 04-09-2010, 02:12 PM   #138
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
nothing a grinder cant fix if it turned into a clearance problem..
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 04-09-2010, 02:30 PM   #139
suttoncurt
suttoncurt's Avatar
Here's some basic astro rotors at the zone for 34 bones ? http://www.autozone.com/autozone/cat...questid=288074
Old 04-09-2010, 05:26 PM   #140
nlped
nlped's Avatar
That's right
Carter
Old 04-10-2010, 01:56 AM   #141
Captainfab
60-66 Nut
Yes the calipers are up at about 2 O'clock which might be a little higher than the fronts. The final price on these brackets remains the same as I posted above....$232.00 plus a flat rate shipping of $10.00 in the USA. Yes you will have to remove your axles to remove the backing plate. However these conversion brackets can be removed from the housing without removing the axles again.
Old 04-10-2010, 02:00 AM   #142
Captainfab
60-66 Nut
If there was a clearence issue, I would do whatever it takes to make it right. Smashingchuck is sending me one of his Wilwood dual piston D52 calipers to test fit. So we should have a comfirmation on those in a few days.
Old 04-10-2010, 04:04 AM   #143
lolife99
lolife99's Avatar
Money sent.
I'd like to wait on shipping them out,... until you confirm the Wilwood rotors fit.
Thanks.
Keith
Old 04-10-2010, 09:09 AM   #144
SCOTI
SCOTI's Avatar
Money sent.
Thanks.
Calipers?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-10-2010, 10:20 AM   #145
nlped
nlped's Avatar
Cool...sorry if I caused you any issues with my question
Carter
Old 04-10-2010, 03:52 PM   #146
Captainfab
60-66 Nut
No problem. I'm actually glad you brought it up. I am going to hold off shipping any of these until I can confirm the fitment of the Wilwood dual piston D52 calipers. That way if there is an issue I can take care of it here.
Old 04-10-2010, 04:51 PM   #147
lolife99
lolife99's Avatar
Originally Posted by SCOTI View Post
Calipers?
Oops. Calipers is correct.
I was still asleep when I typed that..
Keith
Old 04-12-2010, 07:31 PM   #148
lowdownstar
big guy
lowdownstar's Avatar
So whats the deal here guys? I am looking for rear disk brakes but i need a E brake to make the state happy. How is this all working out? thanks for any and all help.
Thanks Ray
lowdownstar is offline   Reply With Quote
Old 04-12-2010, 08:08 PM   #149
crakarjax
crakarjax's Avatar
Thanks Ray
Just claim that it didnt come with one from the factory...
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 04-12-2010, 08:10 PM   #150
smashingchuck
Thanks Ray
Wilwood make a kit that has an ebrake for under $600. Check out Summit.
78 Build Thread
4Runner Build
