Old 06-06-2010, 01:48 PM   #126
Frizzle Fry
Frizzle Fry's Avatar
Re: Irish's 1966 LWB Fleetside
You're about a month late on that
Frizzle Fry is offline   Reply With Quote
Old 06-06-2010, 01:50 PM   #127
irish1966
irish1966's Avatar
I'm Irish, so this is BBQ weather for us.
Cheers
David
66 LWB Fleet (on hold)
64 LWB Fleet (daily driver)
65 SWB Fleet (almost finished as a driver)
64 SWB Fleet (just started - "Tommys Hot Rods" tribute truck)
Nothing worth doing, is easy.
irish1966 is offline   Reply With Quote
Old 06-06-2010, 02:11 PM   #128
Frizzle Fry
I was in Ireland for 3 months the summer of 2003. Nuthin but blue skies!
Old 06-06-2010, 02:14 PM   #129
irish1966
irish1966's Avatar
That was the first year, I spent over here in Hillsboro. I must have brought the rain. lol
Cheers
David
Old 06-06-2010, 07:15 PM   #130
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Great progress I'll be watching this one.
Alan's Classic is offline   Reply With Quote
Old 06-06-2010, 07:34 PM   #131
irish1966
irish1966's Avatar
Smile Re: Irish's 1966 LWB Fleetside
Thx a million Alan. I love these old trucks. I am learning more everyday and with the support from you lads on this forum, it has been great. I'll be uploading some pics in a bit. Have to run to the job and pick up a cable for my phone, so I can connect it to the pc.
Cheers
David
Old 06-06-2010, 10:54 PM   #132
irish1966
irish1966's Avatar
OK, so after butchering the weld on the toe-kick panel, I decided to do what my da always did with his arc setups. I created 2 test jobs and went thru every setting on my little Harbor freight welder. The pics below show each of the feed settings and either Max or Min Power. I think no5 seems to be the best for penetration and looks like a good spot weld using the min power.
Cheers
David
Old 06-06-2010, 11:01 PM   #133
irish1966
irish1966's Avatar
I also cut my patch panel for the drivers side floorpan. The repro panel had the cab mount hole pressed in the wrong location, so I had to cut it out. I will prob trim the panel for what i need further before welding it in. I have to drill the holes for the lower pillar and bolt it up, so everything is in the right position when I weld it. Is it better or worse to leave old material under the new panel or just cut it out altogether?
Cheers
David
Old 06-07-2010, 12:24 AM   #134
ol_skool_chevy
ol_skool_chevy's Avatar
your Trucks looking great David....for a guy that has not done alot of welding your really charging head first into it....thats REAL hot rodding..cut-patch-weld...
It was cool meeting you...thanks alot for the door Panel...I was wondering where I would find one..
Let me know if you have a door for sale
heres that place I was telling you about....let me know I'll rum over there with ya one day I have to pick up a few things there
www.dansclassic.com
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 06-07-2010, 12:57 AM   #135
Captainfab
60-66 Nut
You'll want to cut out all the bad sheet metal, and fit your new pieces as a butt joint. A lap joint is certainly easier, but that leaves a perfect place for rust to form again.
Captainfab is online now   Reply With Quote
Old 06-07-2010, 12:58 AM   #136
irish1966
irish1966's Avatar
www.dansclassic.com
Thx man. It was a cool bullcrapping with ya. Sounds like a plan, heading to Dans. I'm gonna start a list and get some money together. I spoke with my buddy and he said he will do that stuff on your motor, if u want. JUst shoot me a text.
Cheers
David
Old 06-07-2010, 01:05 AM   #137
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
If your lookin for doors you should try dan up in vancouver.www.sickindustries.net. He has lots of parts and does killer work.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 06-07-2010, 01:06 AM   #138
irish1966
irish1966's Avatar
From practicing on the butt joints, I actually preferred welding that type of joint. I thought that totally removing the bad was the way to go. I am going to cut out the majority of the thinning/pitted sheet metal. It's good practicing on the cab floor coz it's not gonna be seen
Cheers
David
Old 06-07-2010, 01:17 AM   #139
ol_skool_chevy
Ya David....I will pick up a Oil pump..and Gaskets,,,,I'll have your buddy come on over to do that for me....
I'm not rich...but I could use the help putting it together
Mark with Chalk
Cut with a torch
Old 06-07-2010, 01:25 AM   #140
irish1966
irish1966's Avatar
He's a good guy. I'll make sure he takes care of ya. Just gimme a shout when u have the stuff and he'll do it.
Cheers
David
Old 06-07-2010, 02:12 AM   #141
LILRED66
LILRED66's Avatar
When using patch panel, I always cut out the bad areas and cut the patch panel to fit...instead of cutting the original area to fit the patch panel. The more original material, that is not damaged, you are able to leave in place, the less work it is to get it back together properly.
LILRED66 is offline   Reply With Quote
Old 06-10-2010, 12:14 PM   #142
irish1966
irish1966's Avatar
Thx a million for all of your inputs about the patching. Last weekend was a busy one, but not on the truck. I had to change a fuel pump on the I-ROC. That in itself was a fun job. The exhaust had to come off, jack the car way up, remove the sway bar, remove the cross member, lower the axle way down, and finally drop the tank. It turns out the neoprene sleeve on the old pump had turned to goo and completely covered the strainer and got into the lines. I had to switch the pump, clean out the lines, weld the pump holder and re-install everything. It was fun to drive it afterwards, except the right rear would lock up everytime I touched the brake pedal. Any, ways, that job is done, so back to the truck this weekend. I took saturday off to watch the Englan V USA game in the world cup, so I might get to work on it after that.
Cheers
David
Old 06-10-2010, 03:03 PM   #143
ol_skool_chevy
the I-ROC sounds like it was a Big ol' Pain in the butt David....Be glad old chevy trucks are alot more simple.
Hey If ya need a hand on your Truck this weekend Give me a call....I Have the weekend free..I'll come over and see if we can Get some of it done...I dont have any plans and the weather is suppose to be pretty nice..
Mark with Chalk
Cut with a torch
Old 06-10-2010, 03:12 PM   #144
irish1966
irish1966's Avatar
Thx Kelly, Yeah, if the weather is supposed to be nice, maybe I can get that bed finished and get the interior walls of it in Rhino-liner. Then all I have to do is get primer on it and it can be protected. I'm thinking about putting the cab back on the frame. I'm most likely gonna go with another th350, so I won't have to take it back off anytime soon.
Cheers
David
Old 06-10-2010, 03:19 PM   #145
ol_skool_chevy
why are you thinking about another th350,,,whats wrong with the one you have?...
I'm still wanting those doors....Beg beg beg .....
Ya if you want to get the bed in Primer I'll bring my sander over and we can knock it out in no time at all........
Mark with Chalk
Cut with a torch
Old 06-10-2010, 03:23 PM   #146
irish1966
irish1966's Avatar
Here's some pics of last weekends project. The 2nd to last pic shows the goo all over the pump. The last pic....now that's what I call a rake
Cheers
David
Old 06-10-2010, 03:29 PM   #147
irish1966
irish1966's Avatar
I just mean, I am not switching to a 700R4 or anything, so I won't have to go messing around with the location of the support. That th350 needs a rebuild. It's the one I got with the truck. That's the next big payout after the exhaust and the rear mounted fuel tank. ( I will hook you up with the doors. We can pull em down and figure out if they are all worth it or not)
Cheers
David
Old 06-10-2010, 08:29 PM   #148
Frizzle Fry
What are your plans for the exhaust? My advice is to tuck it up as high as possible for a lowered truck. I like to go through the T/A xmember. Here's what I did.
Old 06-10-2010, 09:34 PM   #149
ol_skool_chevy
That looks good Frizzle Fry...I'm going to call on you when I need my exhaust hung...sence your here in Hillsboro....Im kidding....
I dont think he's going to lower his truck....I think he should...It looks cool and rides nicer..
Mark with Chalk
Cut with a torch
Old 06-10-2010, 09:49 PM   #150
CHIZZLER
CHIZZLER's Avatar
sherwood car show this saturday.anyone going
61-crew cab D-max
