Old 01-04-2012, 05:24 PM   #126
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: Project: B.A.D. 1976 K30 CCLB
Yeah I was going to say ive never heard of that swap before. Im really interested now to see what kind of numbers it will put out. Isn't the record like 700hp on a VE 12V fuel only?
What are you doing for injectors?
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 01-04-2012, 05:37 PM   #127
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Yeah, I think it's around there with a 14mm VE. Since this is the wife's truck, it won't be a huge power house. I'd like it to be around 300-350HP to the rear wheels. It has 7x.012 injectors in it that are built in house, and the pump is turned up. I have another pump at the pump shop that has a 3200 govonor spring in it and has been rebuilt. Just have to wait for them to finish it up. My plan for now is to run a HX35W with a 14cm exhaust housing. That will help out top end and won't get as hot either. Should make for a great towing combo too.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-04-2012, 05:56 PM   #128
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Well even at 300-350hp its really cool man!
I just did a quick search here's a guy that was thinking about doing this swap... http://www.cumminsforum.com/forum/89...-24v-work.html
and maybe another > http://www.dieseltruckresource.com/d...-t288083.html?
Tony
Old 01-04-2012, 06:02 PM   #129
Dieselwrencher
Some think and talk, some do.
Ryan
Old 01-04-2012, 06:20 PM   #130
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
haha
Wait
Tony
Old 01-04-2012, 06:31 PM   #131
Dieselwrencher
I wasn't referring to you.
Ryan
Old 01-05-2012, 04:29 PM   #132
Dieselwrencher
I got the harmonic balancer, engine adapter plate, and fuel pump block off plate installed this morning. Then I had to clean up the bay enough to get this thing inside the shop.
Started removing front clip to get ready to set engine in it's new home.
We pushed the truck in the shop and rolled the front of the frame right under the engine. Now the fun part comes. I'm going to have to notch my front cross member and brace it according. Then I can start building an engine cross member and get the mounting ears made up. Right now it's just sitting on the cross member and a big jack stand.
Ryan
Old 01-05-2012, 05:16 PM   #133
madcow75
madcow75's Avatar
Wow, now thats tight on clearances. Looks keep up the good work. At the rate you are going you will be driven her by the end of the week.
madcow75 is offline   Reply With Quote
Old 01-05-2012, 08:34 PM   #134
tecky11
almost looks like mine
Truck: 1972 International Harvester 1210
Engine: Caterpiller 3116 220 HP 630 tq
Transmission: Eaton Fuller rt 6610
Axles: Merritor I beam front axle
tecky11 is offline   Reply With Quote
Old 01-05-2012, 10:44 PM   #135
6lcummins
I wouldn't listen to the folks on CF about this, they will have you blowing up your truck in under 5 miles...
Nice to see no one followed through lol And I know Schied said they were the first VE 24V Conversion lines thy had ever bent, and they bend a ton of lines.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 01-06-2012, 03:03 AM   #136
fakerwade
fakerwade's Avatar
WOW Ryan, another wicked build,,,just read about your other build a couple of days ago. Your engine looks great!! How does it feel to be a Pioneer??? Can't wait to see how she turns out!!
Wade
JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!!
Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570
Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro
fakerwade is offline   Reply With Quote
Old 01-06-2012, 03:20 AM   #137
Dieselwrencher
Thanks Wade. It'll feel great to be able to pull it out of the shop without a chain or guys pushing it.
Ryan
Old 01-06-2012, 07:09 PM   #138
Dieselwrencher
The last few nights on my break at work I started polishing my intake plate and valve cover. What do you think?
I started to trim my cross member in the front and eventually wacked it out. I was going to try to install this engine with a mechanical fan. However, I forgot that I have a return line that comes out of the back of the head. If I ever want to get it off or repair it if needed, I had to bring the engine forward to be able to do so. Oh well, I like electric fans any how.
I put a bare trans housing in there to see how it's going to fit. I'm going to have to either cut and modify a floor pan brace, or lower the rear of the engine to be able to install the over drive housing and transfer case on the transmission. We'll see what I come up with.
I also have to watch the front differential because this engine has a huge oil sump on it. I may have to add a 4th leaf to these springs if they don't like the weight and I'm not happy with the clearance I'll have after the weight of the power train is on the chassis.
Tomorrow I'm going to start building the engine cross member. It's going to be a PITA because this oil pan is deeper through out the entire length compared to 2nd gen dodge pans. I'm also going to redo the front cross member and build a steering box brace and integrate it into the front cross member some how.
Ryan
Old 01-06-2012, 09:49 PM   #139
fakerwade
fakerwade's Avatar
MMMMMM,,,polished parts!!! Looks real good! Nice tight fit on that engine.
Wade
Old 01-06-2012, 11:25 PM   #140
Mattman2010
Mattman2010's Avatar
Looks like you were busy today. The polished valve cover will be cool! Looking good man.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 01-07-2012, 12:16 AM   #141
Dieselwrencher
Yes it is a tight fit. I need a magic wand.
Ryan
Old 01-07-2012, 12:16 AM   #142
jbclassix
Junk Yartist
jbclassix's Avatar
I just realized I was drooling...
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 01-07-2012, 12:17 AM   #143
Dieselwrencher
Yes I was and will be all weekend trying to make this less of a yard ornament.
Ryan
Old 01-07-2012, 12:19 AM   #144
tecky11
tell me what the secret to squeezing it in is
Old 01-07-2012, 01:02 AM   #145
Maxxd07
Maxxd07's Avatar
Looking good, moving along nicely. VE 24v? Some would say you need to have your head inspected, others will say how unique, way to think outside the box. I would love to sell my Dmax and build a daily driver like such with a P-pumped 24v with a 6spd handshaker, but I dont have the time and these newer diesels move pretty well stock and with a plug in can move even better for a 7500lb vehicle.
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 01-07-2012, 09:54 AM   #146
yousesteers
The motor Looks good. You must have moved the motor forward quite a bit I just trimmed like a 1/2 unch off my front crossmember to get tthe motor to set down. Looks good. Now you are down to the stuff that seems like you never accomplish anything because it is all smalll and no real visual progress or at least that is the way mine seemed. Course I just had a P[-pumped 12 valve
Clint Youse
Paris, MO
1984 Chevrolet 3+3 K30 with Cummins
1966 IH Scout has been a work in progress for 16 yrs
yousesteers is offline   Reply With Quote
Old 01-07-2012, 01:28 PM   #147
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Your really moving along on this one! Great work and love the polishing..you gonna share the process? what do you do after its polished..just spray can clear coat?
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 01-09-2012, 02:23 AM   #148
6lcummins
Cost, availability, and reliability. hardest part about it was getting the lines made, other than tuning its a rather simple build honestly.
"STOCK"
ASSEMBLY THREAD
Old 01-09-2012, 02:44 AM   #149
Dieselwrencher
Patience and a plasma cutter and welder.
I wanted something different for this rig. My other chevy will have a P-pumped 24v and a 5 speed with a DD. I already have a VE 12v and a P-pump 12v in drivers. Plus I've always wanted to do a VE 24v. It should make for a killer mileage engine hopefully.
Yes I had to because of the return line banjo bolt in the back of the head. I don't want to have to pull the engine to fix the line if it ever leaks or what ever. Plus the #6 Injection Line is super close to the fire wall.
If I start with a rough casting piece, I use a corps disc scotch brite pad, red medium grit on a die grinder. I smooth up the surface best I can. Then I sand it starting with 180 grit. Then 220, 320, 400, 600, 800, 1000, and then 1200. I then use a polishing wheel with aluminum polish and buff it up. On these parts I only had 220, 400, and then ultra fine gray scotch brite pad. I will go back over these parts with finer sand paper and re polish it later. The valve cover is going to be a real PITA!
Ryan
Old 01-09-2012, 02:51 AM   #150
Dieselwrencher
I wasn't happy with how the engine sat in the chassis so we re positioned it and then I started building the engine mounting brackets.
Tomorrow I'll wrap up the LH engine mount. The energy suspension bushings don't fit worth a crap. They're extremely tight and in their instructions they tell you to trim to fit according to your mount. So I have to trim the ears some more so the bushings will stay in all the way so I can tack the upper portions of my mounting brackets other wise it will be a fight every time I want to install or remove it. Then I'll get on to the cross members.
Ryan
