Old 11-07-2010, 07:47 PM   #126
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
Bottoms of these doors were swiss cheese, so I didn't feel bad stealing the window frames. The Blue and white cab that they came off of was also totally gone on the bottom. Someone had repaired it with newspapers stuffed in the rockers with bondo liberally spread on top. Really nice, long lasting repair. The fun part was the small fire when the plasma cutter hit the newspaper layer. It was very helpful when I was cold that day. At least I could use the newspapers to date the repair, Oct 7, 1992.
Onto trying to weld air on the drivers rear window channel, yeah that's not gonna work. I had to cut and weld in the eighth that I was short. Wasting time, but it worked fine.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 11-07-2010, 10:25 PM   #127
swamp rat
swamp rat's Avatar
Originally Posted by drewskiren View Post
Remember the 100 dollar cabs I got? Well they came with doors too which I need to steal something off of. Measured 3 or 4 times on the drivers side only to cut it an eighth inch too short. DOH!!! Some surgeon I am. Passenger side I drilled out the spot welds and removed a good bit into the door. I'll just plug weld the holes at the bottom and butt weld at the top frame.
Don't ya just hate it when ya cut on the wrong side of the line!!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-18-2010, 12:14 AM   #128
drewskiren
drewskiren's Avatar
Green truck is now donating more sheet metal to the patient on the operating table. I'll be getting rid of my old inefficient heat and air system in favor of a new one, so a new firewall is in order.
Drew
Old 11-18-2010, 12:23 AM   #129
drewskiren
drewskiren's Avatar
Here is another opportunity for a solution. The burb roofline has a very slight pinch waist as it continues to the rear, a truck does not. So I encountered a little problem of the drip rails not meeting up just right. I decided the best way to attack this issue would be simply to slice off the drip edge, weld in a tiny strip of metal, and grind it all smooth. The drip rail gets a liquid caulk on top which also helps cover up where I welded the roof back down.
Drew
Old 11-18-2010, 12:25 AM   #130
drewskiren
drewskiren's Avatar
Semi finished on this side.
Drew
Old 11-18-2010, 10:29 AM   #131
Jmac0585
Jmac0585's Avatar
You... you are very good.
Yes, I used to do the L.E.D. tail lights. No, I don't do them anymore. But I might be able to fix them if you need help.
Proverbs 3:5-8
Jmac0585 is offline   Reply With Quote
Old 11-18-2010, 10:32 AM   #132
67cheby
67cheby
67cheby's Avatar
nice work on the drip rail !!
67cheby is offline   Reply With Quote
Old 11-18-2010, 12:01 PM   #133
68 TT
Still plays with trucks
68 TT's Avatar
Nice solution to the problem. Keep up the great work.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 11-18-2010, 05:31 PM   #134
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice progress!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-18-2010, 08:28 PM   #135
VA72C10
VA72C10
VA72C10's Avatar
Nice work! Keep up the good progress!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-18-2010, 11:37 PM   #136
mcbassin
Still Learning
mcbassin's Avatar
This is an Awesome project! It's going to be super cool when done. subscribed.
mcbassin is offline   Reply With Quote
Old 11-19-2010, 08:03 PM   #137
steppside69
steppside69's Avatar
Looking good, Keep it up Eric
69 chevy stepside (project)
2006 Silverado Z71 Ext. cab
2005 Saturn VUE (wifes dd)
steppside69 is offline   Reply With Quote
Old 11-19-2010, 09:52 PM   #138
drewskiren
drewskiren's Avatar
OK Eric, I'm keeping it up!
Drew
Old 11-19-2010, 09:54 PM   #139
drewskiren
drewskiren's Avatar
I'm growing tired of all my posts being so YELLOW.
Drew
Old 11-19-2010, 09:55 PM   #140
drewskiren
drewskiren's Avatar
I really like this shot of the new and improved drip rail.Name:  DRW_1188.jpg
Drew
Old 11-19-2010, 10:01 PM   #141
drewskiren
drewskiren's Avatar
More self etching primer. My goal was to be ready for block and prime before the summer began. I am almost current on my posts with where I actually am now. Yes, I have been leading a few of you on.
Drew
Old 11-19-2010, 10:06 PM   #142
Dieselwrencher
Very nice! Man, you are going to force me to sell my standard cab and drive to Wyoming.
Ryan
Old 11-19-2010, 11:05 PM   #143
swamp rat
swamp rat's Avatar
Tell me more about the blue stuff in the drip rail (also looks like its on the front passenger side below the window) is it seam sealer or some kind of special drip rail filler? Thanks! The roof has made some real progress too, when i first saw the pick showing the different slopes i was about mortafide.. over my head..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-20-2010, 01:51 AM   #144
drewskiren
drewskiren's Avatar
Originally Posted by swamp rat View Post
Tell me more about the blue stuff in the drip rail (also looks like its on the front passenger side below the window) is it seam sealer or some kind of special drip rail filler? Thanks! The roof has made some real progress too, when i first saw the pick showing the different slopes i was about mortified.. over my head..
The Blue stuff is MONEY!
It's almost like cheating.
It is Eastwood 2K self leveling seam sealer.
A 2 part epoxy that self mixes in the caulk nozzle. It comes out as a liquid, so you need to have your part on level ground. After about 3 minutes it starts to get slow, that's when I trained it down the drip rail rear side. 2 minutes later it is gooey and unworkable. Ten minutes it is hard.
Roof is basically finished now and looks totally fine/factory. I'll probably block it down 2 more times before paint, but that's another lesson.
Drew
Old 11-20-2010, 02:24 AM   #145
VA72C10
VA72C10
VA72C10's Avatar
very nice....even though we're mad at you for leading us on and making us wait j/k. Keep up the good progress!
Old 11-20-2010, 08:57 AM   #146
Hart_Rod
Hart_Rod's Avatar
Looks great! I need to get motivated and work on mine.....
Hart_Rod is offline   Reply With Quote
Old 11-20-2010, 09:03 AM   #147
steppside69
Old 11-20-2010, 09:31 AM   #148
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Damn man you do great work for sure...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-20-2010, 09:38 AM   #149
JohnC
JohnC's Avatar
Looking good man! Keep it up.
JohnC is offline   Reply With Quote
Old 11-20-2010, 11:39 AM   #150
67cheby
67cheby
67cheby's Avatar
looks AWESOME!!!
