Old 03-04-2013, 09:32 PM   #126
Rude Dude
Rude Dude's Avatar
Re: 56 Chev Garage build
Thank you Kabwe, been really busy with other things it was nice to work on truck again. Going to try and get on Doors next then prime one solid color.
Originally Posted by Kabwe View Post
Hey man,
The truck is looking great. Nice work buddy.
Rude Dude is offline   Reply With Quote
Old 03-07-2013, 07:30 AM   #127
dug224
dug224's Avatar
Good choice on the steering wheel. Looks great. dug
dug224 is offline   Reply With Quote
Old 03-31-2013, 09:57 AM   #128
hammerdog57
hammerdog57's Avatar
I like the look of the tri five steering wheel. What does it take to adapt it to the van column? Any close up pics of the conversion?
hammerdog57 is offline   Reply With Quote
Old 03-31-2013, 01:03 PM   #129
Rude Dude
Rude Dude's Avatar
It bolts right up if you want to close up the gap between stock wheel and column you can buy an a spacer ring available from. Ididit see this video.
Old 03-31-2013, 01:27 PM   #130
hammerdog57
Thanks for the info and video.
Old 03-31-2013, 07:34 PM   #131
Rude Dude
Rude Dude's Avatar
I like the fancy Aluminum recovery tanks but can't see in spending that much money for something I can not see the fluid in. I needed an overflow tank for the radiator so went to Autozone and bought one of the generic plastic recovery tanks. I used the factory holes that where already drilled, put in Three rubber grommets for hose and two behind the mounting bracket so it wont rub against the the paint, also split a gas line and placed on the lower bracket in two spots that lay against the fender wheel all for under $10.
Old 03-31-2013, 08:42 PM   #132
Kim57
Kim57's Avatar
Nice clean install on the over flow tank.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-31-2013, 09:54 PM   #133
Rude Dude
Rude Dude's Avatar
Thanks Kim
Kim
Old 04-21-2013, 07:35 PM   #134
Rude Dude
Rude Dude's Avatar
Today I re-did an old bumper, stripped with paint stripper and etch primed and repainted it white. Color sanded too
Old 04-22-2013, 02:02 AM   #135
Kim57
Kim57's Avatar
Very nice.
Kim
My build thread
Old 05-19-2013, 11:42 AM   #136
Rude Dude
Rude Dude's Avatar
Worked on the doors yesterday just wanted to share a little on a tool my brother recommended to buy and it work great. I have a harbour frieght stud gun and the stud pullers sucks big time, the wheel that holds the studs strips out very quickly after use. My right door was dropped by previous owner (look like a 2nd story drop) and the damage was extensive it buckled the bottom of door and pushed the outter skin up so much so that I was thinking of buying an outter skin and new lower panel. This got be thinking why not use my new tool and fix it so I cut the bottom of door which gave me access to inside skin and using a hammer and dolly I straighten the door as best I could. Then after straightening and welding the bottom I used the tool to finish the rest. I am sorry but I forgot to take pictures on outter stud work but I got pics of the bottom. If you need the tool just google it stud leveler I highly recommend it.
Old 05-19-2013, 11:51 AM   #137
Rude Dude
Rude Dude's Avatar
Here is some pics from my left door after using the tool.
Old 05-19-2013, 12:00 PM   #138
_Ogre
_Ogre's Avatar
we have a hf stud gun, works great but we use different tools than the cheap hf pullers too
i'm surprised studs do anything with the thick metal on our trucks
i massaged a fender with two 5lb hammers for a couple hours to fix a crushed lip
shop air compressor timer
Old 07-06-2013, 10:16 AM   #139
Roadkill58
Roadkill58's Avatar
Nice work on the truck. I like the mods you are doing.
Rust Never Sleeps
Roadkill's 58 Chevy Stepside build
Roadkill's 69 Custom C20
Roadkill58 is offline   Reply With Quote
Old 07-21-2013, 03:24 PM   #140
made2drag
made2drag's Avatar
nice build so far
made2drag is offline   Reply With Quote
Old 08-09-2013, 09:32 PM   #141
Rude Dude
Rude Dude's Avatar
I finished up passenger door ran out of primer so I used flat black until I buy more primer
Old 08-09-2013, 09:34 PM   #142
Rude Dude
Rude Dude's Avatar
A couple more pics
Old 08-10-2013, 01:21 AM   #143
Kim57
Kim57's Avatar
Looks nice and smooth.
Kim
My build thread
Old 08-17-2013, 09:17 PM   #144
Rude Dude
Rude Dude's Avatar
Was fighting the left front fender trying to get it right, idea came a long how about a come-along!!! Also primed the passenger door, side view looks good. Man this door took a lot of time.
Old 08-18-2013, 02:34 AM   #145
Kim57
Kim57's Avatar
Very ingenious.
Kim
My build thread
Old 08-23-2013, 03:36 PM   #146
Rude Dude
Rude Dude's Avatar
Installed the passenger side door today noticed that top of door had about 1/4 inch gap larger than the drivers side door. It wasn't the adjustment just made that way from GM. I just happen to have a strap the same width of the difference so out came the MIG Welder. Here are the results the pics are of both door gaps to compare. I wouldn't have welded the darn thing on but it was very obvious and it look horrible to me. I am happy with it just more dang body work!
Old 08-23-2013, 06:03 PM   #147
Kim57
Kim57's Avatar
Your fix came out nice.
Don't you just love the door gaps on these old trucks?
Kim
My build thread
Old 08-23-2013, 08:46 PM   #148
Rude Dude
Rude Dude's Avatar
No Kim, I hate door gaps I am getting tennis elbow from sanding!!!
Kim
Old 08-23-2013, 09:02 PM   #149
Roadkill58
Roadkill58's Avatar
makes me glad I'm still working on the chassis, well almost....
Rust Never Sleeps
Old 08-23-2013, 09:06 PM   #150
Rude Dude
Rude Dude's Avatar
Chassis was easy for me too, I hate body work!!!
