Old 04-27-2011, 10:21 AM   #126
Stitch
Location: Where I come from, it's cornbread and chicken...
Re: 77 yellow gmc swb
They don't make 73 GMC repop grills only the Chevy ones
Stitch is offline   Reply With Quote
Old 04-27-2011, 04:03 PM   #127
menace121978
menace121978's Avatar
WOW!!! incredible build man!!! very nice job and loving the quality work subscribed finally
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 04-28-2011, 06:55 PM   #128
73gmc454
73gmc454's Avatar
Thanks guys , I'm gonna try to start on the dash panel saterday , I think it will work out nice painted black to match the right side dash panel
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237
73gmc454 is offline   Reply With Quote
Old 05-15-2011, 07:45 PM   #129
73gmc454
73gmc454's Avatar
Ok I got the exhaust and mounts finally completed , also got the wiring harness in for the tailights put back in, still working on the dash panel at work also,heres some pics of the exhaust mounts I made
Old 05-15-2011, 08:15 PM   #130
my4by2
my4by2's Avatar
WOW!!! Very nice man - great detail!
my4by2 is offline   Reply With Quote
Old 05-15-2011, 09:27 PM   #131
77BBGMC
77BBGMC's Avatar
Man you do good work..too bad you don't live closer to Wichita!
77BBGMC is offline   Reply With Quote
Old 05-15-2011, 09:41 PM   #132
spudz
spudz's Avatar
VERY nice..... like always!!!!
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 05-16-2011, 10:38 AM   #133
Tagg33
Tagg33's Avatar
Very nice, love the fab work.
Ryan
84 SWB, C4 IFS Crossmember, C4 IRS, RE7 bags, WCC 3pc 22"s
My reBuild: http://67-72chevytrucks.com/vboard/s...d.php?t=346328
Tagg33 is offline   Reply With Quote
Old 05-16-2011, 08:39 PM   #134
73gmc454
73gmc454's Avatar
Thanks guys , really it helps ! I worked on getting the front light wiring harness tucked into the fender and ran in front of the bottom of the core support instead of across the top, it looks like I'll have to add about 12" to the main plug end to get it to reach
Old 05-16-2011, 09:18 PM   #135
mooseknuckles
mooseknuckles's Avatar
...but then at least it will be hidden.
mooseknuckles is offline   Reply With Quote
Old 05-16-2011, 09:53 PM   #136
menace121978
x2.... its def. worth it man. thats how i ran mine but i was lucky the painless kit has tons of extra length. after you get the wiring in order all you will need to set it off is to make a fuse box cover(or just get one from Jeff)
"Dennis the Menace"
Old 05-17-2011, 05:50 PM   #137
73gmc454
73gmc454's Avatar
I wondered if they gave you extra with the painless kit ,I still may update to the painless wiring before the end , I wanted to make a cover but I didnt want to make Jeff mad for stealing his idea , the only thing I would do different is leave the welds on to match everything else , I also have some nice rubber inserts leftover from trailer junction boxes ,I thought they would help make a clean install,
Old 05-19-2011, 12:37 AM   #138
bigblock73
yeller
bigblock73's Avatar
You do good work, don't worry about me getting mad Maybe jealous is a better word
I am in the middle of re-wiring and sheetrocking the garage, almost done...I need to get that GMC gate crated and shipped to you...thanks for being patient!
bigblock73 is offline   Reply With Quote
Old 05-19-2011, 08:52 PM   #139
73gmc454
73gmc454's Avatar
Thanks Jeff , glad ya like my junk ! not sure what you mean about a gmc gate ? all this talk about the cover I made a moch up from plastic today after I got the light harness installed, I made it a lil different put a step in the top , to clear the wiper motor , I'm gonna make mounting tabs off the back edges ,drill out the tapped screw holes in the firewall and just mount the fuse box and the cover with the same screws, also made it a lil longer I'm gonna drill a hole just below the fuse box to run all the fan and air control wires that are running up front with the hightlight harness ,then they can come right outta the box them and into the fender , pics below !
Old 05-20-2011, 09:59 AM   #140
BuddR
Jamie, Awesome work, I don't know how I missed your project, as you said in the beginning, " I've been truck drunk" since I found this site, a couple months back. You've came along way with it since I was up there and seen it. Seems to be a really good group of guys on here, not to mention the info I've picked up on. Also Guys there is no end to this mans talents, to the smallest of details to who only knows. GOOD WORK. Budd...
BuddR is offline   Reply With Quote
Old 05-20-2011, 02:00 PM   #141
bigblock73
yeller
bigblock73's Avatar
Sorry, got you mixed up with 75gmc454
Old 05-20-2011, 04:11 PM   #142
mcboomport
mcboomport's Avatar
Man, you do some clean subtle touches. Details man, awesome!
mcboomport is offline   Reply With Quote
Old 05-21-2011, 08:09 AM   #143
73gmc454
73gmc454's Avatar
Thanks Budd , you make it sound like I know what I'm doin ! Thanks also Mcboomport just tryin to make a clean build , I was able to get all the E brake cables on yeasterday and made a fuse box cover from aluminum , turned out good , I'm gonna try and get the notches for the wires to come out and get it mounted today ,
Old 05-22-2011, 08:19 PM   #144
73gmc454
73gmc454's Avatar
The box is on and all the wires going in are done , Thanks to Jeff for having the box idea and Dennis for giving me the push to do it , It really makes it look cleaner ,
Old 05-22-2011, 08:50 PM   #145
3r!c84
Badass
3r!c84's Avatar
very sharp! where do i order
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 05-22-2011, 09:00 PM   #146
BuddR
NICE !!!! gives it a nice clean touch. As always beautiful work my freind.
Old 05-22-2011, 10:04 PM   #147
watahyahknow
watahyahknow's Avatar
you could make it look like its out of one piece by smoothing the welds and polish it again , it looks verry nice
the box gave me an idea about mounting the cover by making a bracket with a strong magnet where the cover slides over and hold it in place
it would be a nice mountingsolution without any screws needed on the outside , too bad its a box made out of aluminium or stainless than again you could still glue a piece of steel or the magnet itself on the back of that cover , some of these magnets are pretty powerfull and you would need more then just youre fingers to get it off the bracket
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 05-22-2011, 11:21 PM   #148
73gmc454
73gmc454's Avatar
Thanks guys, I cant sell em, if I start makin parts for everybodys trucks mine wont get done ! I like the welds , I left them on everything I made , the tabs on the back side is what I used to mount it so you cant see any screws, I also put some gasket material on the back side to keep from scratchin the paint ,
Old 05-22-2011, 11:41 PM   #149
BuddR
I kinda like the welds too. gives it a clean fabed product, instead of store bought. That tonnueu cover I emailed you about is for a long bed.
Old 05-24-2011, 08:10 PM   #150
73gmc454
73gmc454's Avatar
So since I got the wiring tuned up I figured I would plug the led lights in and a headlight switch and fire em up , I dont have the electronic flasher yet so I knew I wouldnt get a flash ,but as soon as I plugged the battery in the marker lights came on with the switch off . I played with the switch and replace with another still the same, its been a long day so I gave up and went to the house , after thinking about this for awhile I went back out found it to be the hazards were on !
