06-06-2011, 08:10 PM | #126 |
A guy with a truck
Re: Bolt in steering rack
How does one go about locating dead center? Looks good so far
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
06-06-2011, 08:32 PM | #127 |
Truck and auto performance nut
yes.....we're getting there!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
06-07-2011, 12:06 AM | #128 |
06-07-2011, 09:33 AM | #129 |
What kinda of rack is being used here?
06-07-2011, 02:49 PM | #130 |
There is a hole above the bend, and also on the bottom. We measure using the lower A-arm U-bolt as a guide. More to come.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
06-07-2011, 03:23 PM | #131 |
At the body shop.
Is it available manual?? How much lighter.
" That didnt make it any newer " " Dont antique the equipment " |
06-07-2011, 04:41 PM | #132 |
When the thread was somewhat new, I read where it was stated what OE rack was being used. Now I don't see it anywhere. Did someone delete it???
06-07-2011, 05:20 PM | #133 |
Next we cleaned all of the greese and grime off of the main crossmember. A piece of tape on the crossmember will make it easier to see the center line marks.
06-07-2011, 05:37 PM | #134 |
Using the lower A-arm u-bolts as a guide, measure and mark the center of the crossmember-make 2 or 3 measurements and double check your center from both sides.
06-07-2011, 05:47 PM | #135 |
Set the main mounting bracket onto the cross member and line up the center hole with the center line mark. Locate the hole center and mark it.
06-07-2011, 06:08 PM | #136 |
Center punch and drill with a 3/8 bit.
06-07-2011, 06:13 PM | #137 |
Re-mount the main plate and bolt in place. Reach through the large port in the crossmember behind each spring pocket.
06-07-2011, 06:15 PM | #138 |
Using the bracket as a guide drill the remaining 4 holes with a 3/8 drill bit.
06-07-2011, 06:20 PM | #139 |
Assemble the rack to the rack mount. Start with the drivers side rack mount bolt.
06-07-2011, 06:22 PM | #140 |
For the passenger side use the two supplied u-bolts to mount the rack to the bracket.
06-07-2011, 06:24 PM | #141 |
Test fit the rack mounting bracket. Our rack hit the lip of the crossmember-mark any interferance.
06-07-2011, 06:27 PM | #142 |
Use a grinder to cut the lip down for clearance.
06-07-2011, 06:32 PM | #143 |
Next is the spindle modification. Using a 5/8 drill bit, drill out the tie-rod mounting hole. Start from the top side. Try to drill it straight down through the original hole.
06-08-2011, 12:16 AM | #144 |
this looks great and should perform nice . i can't wait to see the finished product.
06-08-2011, 02:10 AM | #145 |
So far looks killer. I can't wait for them to be up for sale...
Some progress is better then no progress |
06-08-2011, 05:32 PM | #146 |
Next it's on to the steering shafts and u-joints. This bearing mount comes in the kit and must be fitted into the frame rail.
06-08-2011, 05:34 PM | #147 |
Using the diagram provided you will need to drill two new holes in the chassis-both 5/16". Then open up the factory hole to 7/8".
06-08-2011, 05:42 PM | #148 |
This shows the holes drilled out. We also did a little die-grinding for steering shaft clearance. You'll see why next.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! Last edited by robnolimit; 06-08-2011 at 05:49 PM. |
06-08-2011, 05:51 PM | #149 |
Here you can see the shaft support bearing in place.
06-08-2011, 05:54 PM | #150 |
To get the Flaming River u-joint (supplied with the kit) to fit. The lower lip of the frame needs to be ground back about 3/8" to clear.
