Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-31-2012, 01:16 PM   #126
noonzor
Re: My build thread.. 63 LS powered C10
what kind of numbers are you hoping for from the new 418? i know a 12 bolt can be built up to handle high hp, just the 9" seems to be the more trusted route. not that im questioning your methods, just curious.
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 03-31-2012, 07:50 PM   #127
Super73
Super73's Avatar
Hoping to go 10.7x-10.8x on motor next time out and get it down to 10.5x in the near future. On the unit, hoping to go 9.9x and work it down to at least a 9.5x. For all I know, the rear could last 10 years or 1 pass. I don't look forward to having to build the 9", but when the 12 bolt goes, the 9" will get built. Maybe before.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 03-31-2012, 10:46 PM   #128
Vortecpro
Ck out the rear end 69 GMC 910 had built.
Vortecpro is offline   Reply With Quote
Old 04-01-2012, 08:28 AM   #129
djracer
djracer's Avatar
That Tig Welding is so Sexy!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 04-08-2012, 11:31 PM   #130
Super73
Super73's Avatar
Ok, went by again to see the truck late last week. Had another set of headers to try and fit. Let's just say they did not work with the new 6 bolt heads
But here are some pics of the wishbone.
Old 04-08-2012, 11:33 PM   #131
Super73
Super73's Avatar
I was uploading the above pics when I got a plesant suprise via text I believe this means all the welding on the chassis is done. Well, minus the bottle brackers, Mounting the cell and the fuel pump.. Oh, and removing the existing cross member that held the LCA's in place and putting in a new cross member with driveshaft loop.
Old 04-09-2012, 08:11 AM   #132
LSPWRD67CHEVY
LSPWRD67CHEVY's Avatar
How are you going to do the bed? just curious..
1967 C-10 (project)
1964 Pontiac Lemans (Treasure lol)
2009 GMC Denali Truck (DD)
LSPWRD67CHEVY is offline   Reply With Quote
Old 04-09-2012, 09:31 AM   #133
Super73
Super73's Avatar
Unbolt the front panel, put it in place and bolt the panel back in. The 60-66 beds can be completely unbolted.
Old 04-09-2012, 09:41 AM   #134
LSPWRD67CHEVY
Right. I should have been more clear. I was wondering more about the inside, like are you going to put tubs in it or a floor or a bed cover, stuff like that?
1967 C-10 (project)
Old 04-09-2012, 12:17 PM   #135
Super73
Super73's Avatar
Thinking of doing an alum bed cover. I don't run a gate most the time, if I do it is down. I have also thought about skinning the bottom of the truck, similar to how the newer betts are done.
Old 04-09-2012, 10:28 PM   #136
djracer
djracer's Avatar
I have thought about running a wishbone with trailing arms.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-10-2012, 12:02 AM   #137
Captainfab
60-66 Nut
That's interesting. I'm used to seeing the wishbone above the axle.
Truck is looking very nice.
Old 04-10-2012, 12:34 AM   #138
noonzor
so very very sweet. gettin close man you must be happy, id be ear to ear grinnin with that craftsmanship!
Old 04-16-2012, 12:48 AM   #139
Super73
Super73's Avatar
Joe cut the front panel today and we set the bed on the frame. Notice we left two holes per side. It helped keep it from being floppy with the little bit of shear strength in the sheet metal (upper aera you can see a slight triangle).
Old 04-16-2012, 12:51 AM   #140
Super73
Super73's Avatar
Couple more from today.
Old 04-24-2012, 09:15 PM   #141
Super73
Super73's Avatar
Joe sent me these couple pics today. We discussed lowering the truck a little more in the rear. It is now about 2" lower.
He also mounted the N20 bottle.
Got a bunch of stuff in the mail today from Summit. I am making some changes to the fuel system to run E85. Fuel system will look like this:
5/8 (-10) hard line from cell to Weldon 2035-A
Splitting to dual 1/2 (-8) before the rails
Off the other end of the rails is a -4 T fitting
One 1/4 (-4) goes to the N20 noids (one on each side, 2-stage) the other goes to the Aeromotive A1000 regulator
1/2 (-8) return back to the cell
Things left for Joe to do before I get it back and start working on the fuels system:
Mount the batterey
Mount the fuel cell
Drain plug in radiator
Rod end radiator mounts from the front bars cage bars to the radiator
Map out 4-link for ICG
I have a race coming up May 19/20 that I am hoping to be running by.
Old 04-24-2012, 10:16 PM   #142
bigboybodry
bigboybodry's Avatar
Looking good brother mines next
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 05-01-2012, 03:17 PM   #143
team39763
Your truck is getting serious man. Come a long way since I first seen it a few years ago.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 05-01-2012, 10:27 PM   #144
Super73
Super73's Avatar
Yup, it's a money pit.. Good news is it is coming home on Friday. Then on to getting the fuel system back together and a rear brake line. Should hopefully be racing the 19th and 20th. Just 1/8 mile with no track prep or timers, but will give me some seat time
Old 05-01-2012, 10:43 PM   #145
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: My build thread.. 63 LS powered C10
Shakedown run
What do you think your 60ft time will be with all the new goodies on her now?
Maybe you can have someone to video you launching out of the hole and down the track to see the difference now.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 05-05-2012, 11:36 PM   #146
Super73
Super73's Avatar
It is home....
Old 05-06-2012, 12:28 PM   #147
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Super congrats on your progress. Looks like a jr promod tuck in the making. Only thing I see missing is your wheelie bars.lol Best of luck at the track in a few weeks. Wheels up and have some fun. Keep us posted.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 05-06-2012, 02:22 PM   #148
Marv D
Registered Truck Offender
Marv D's Avatar
no other word comes to mind.. just "WOW"!!!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 05-06-2012, 04:12 PM   #149
dbmx66
truck is looking nice, lots a great fabrication work for sure
dbmx66 is offline   Reply With Quote
Old 05-07-2012, 07:22 AM   #150
bigboybodry
Awesome!!! sums it up in a nut shell
