Old 04-17-2019, 04:00 PM   #126
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Re: My 1st 68 panel
Since this panel is almost complete, I am going to remove it and fabricate some new ones using this one for a pattern. Since I am using suburban quarter panels on my panel I am going to remove the spare tire well from the passenger side one and fab up a new panel like this to replace it. A buddy of mine has the machine needed to get the X beads put in the panels to keep them looking stock and I can cut and bend them on my brake and shear.
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 04-18-2019, 02:43 PM   #127
HO455
Post Whore
HO455's Avatar
Re: My 1st 68 panel
The wood floor is in pretty good shape (At least compared to mine). Were you able to salvage any of the countersunk bolts across the back?
RIP Bob Parks.
Old 04-18-2019, 03:05 PM   #128
richard2717
Re: My 1st 68 panel
The floor, or what was left of it, was in very good shape. It had been cut by previous owner so would not be usable unless it was spliced in to an existing one. I was actually able to salvage quite a few different type bolts, some good enough to clean up and reuse and some for sizing purposes.
Members I have met.
Old 04-18-2019, 04:09 PM   #129
HO455
Post Whore
HO455's Avatar
Re: My 1st 68 panel
How did you get the flush countersunk bolts out?
RIP Bob Parks.
Old 04-18-2019, 04:23 PM   #130
richard2717
Re: My 1st 68 panel
The ones I was able to get out still had a hard chunk of undercoating on them that when tapped with hammer fell off, leaving good thread exposed. I have had limited luck using small wire wheel on drill to clean them up before nut removal as well. If they start to spin I just go up top and drill the head off of them and punch them thru vs tearing up the metal strip. You could probably tack weld the head to the strip if you are attempting to save the bolt. Seems to me they are available new as well. I think it was Paul (powdercougar) that found them, but not 100% on that.
Members I have met.
Old 04-18-2019, 04:39 PM   #131
richard2717
Re: My 1st 68 panel
Here is the thread where we were actually talking about them. I think i am going to go ahead and order a box of them since I have a couple here that could use them and I will hope I can sell the rest to others that may need them.
https://67-72chevytrucks.com/vboard/...elevator+bolts
Members I have met.
Old 04-18-2019, 05:07 PM   #132
richard2717
Re: My 1st 68 panel
Here is a close up shot of the bolt
Members I have met.
Old 04-20-2019, 03:32 PM   #133
HO455
Post Whore
HO455's Avatar
Re: My 1st 68 panel
Count me in for some. I would like to replace the floor in mine this spring.
RIP Bob Parks.
Old 04-20-2019, 07:56 PM   #134
richard2717
Re: My 1st 68 panel
I think I ordered the right ones. Had to get 100 of them so we will see but they were not to expensive.
Members I have met.
Old 04-21-2019, 12:23 PM   #135
pwdcougar
pwdcougar's Avatar
Re: My 1st 68 panel
I'm in for some too! They were so expensive by the box I just put in flat head phillps bolts.
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 04-22-2019, 06:00 PM   #136
richard2717
Re: My 1st 68 panel
Well, quick shipping but not quite correct. They will work but wont be quite flush with the metal strip like the originals. The original heads are 5/8" diameter and the new ones are 1". I saw no where in the listing on the size of the head so went ahead and chanced it. I sent a picture to the supplier with them both side by side to see if they have it in the correct size but not real hopeful about it. If they don't, I will still use these
Members I have met.
Old 04-22-2019, 06:46 PM   #137
richard2717
Re: My 1st 68 panel
well 15 minutes later I have an answer from the supplier. No smaller head available to their knowledge without special order which requires 10k minimum order. I think I will stick with these.
If you guys still want to try them just let me know. Shipping is just as much as the bolts It would be $9 total for 8 of them.
Members I have met.
Old 04-22-2019, 08:30 PM   #138
Average Joe
Average Joe's Avatar
Re: My 1st 68 panel
Holy frijoles batman!! I have never seen a burb or panel taken down this far! Thank you so much for posting pics!! You have serious ambition.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 04-23-2019, 09:26 AM   #139
HO455
Post Whore
HO455's Avatar
Re: My 1st 68 panel
Since I think I will chuck them up in the lathe and turn them down I would like a double order. 18 each. PM me and we can work out details.
RIP Bob Parks.
Old 04-23-2019, 10:15 AM   #140
richard2717
Re: My 1st 68 panel
Sent you a pm
Members I have met.
Old 04-23-2019, 03:33 PM   #141
richard2717
Re: My 1st 68 panel
Just got an email back from a supplier that I had contacted a while back saying they can do these out of stainless but the head would be slightly smaller at .58. The cost would be about $3 per bolt which I am not sure is worth it once you add shipping on top of that. They also did not mention the minimum quantity even though I asked about it. I sent another email trying to get that determined.
Members I have met.
Old 04-23-2019, 06:14 PM   #142
Beach-Burban
Beach-Burban's Avatar
Re: My 1st 68 panel
I 100% agree with Average Joe...it makes me feel silly for being proud that I installed my own mirrors!
Woody
Beach-Burban is offline   Reply With Quote
Old 04-23-2019, 06:18 PM   #143
richard2717
Re: My 1st 68 panel
Woody
Don't feel silly. It is easy disassembling things, it is reassembly that is the hard part. It has been so long I am not too sure I can but I got plenty of spare parts to use until I get it right or send it out to someone else
Members I have met.
Old 04-23-2019, 08:57 PM   #144
richard2717
Re: My 1st 68 panel
All the body bolts in the rear snapped off right away under the wrench, the cab and radiator supports unscrewed easy peasy and I came out of it unscathed with no bloody knuckles. All is right in the world tonight. That went so fast I went ahead and pulled the fan shroud & Radiator , along with unhooking the heater hoses, battery cables, engine harness, oil line, temp line, choke & carb linkage. The column was already unhooked from the box but I am going to go ahead and pull it out of the cab before lifting the body off the frame. Oh yea, also removed the Ebrake cable from thru the frame and the clutch rod from the pivot bar. Tomorrow evening I need to pull my Herman Munster shift handle off and the column out and it "should" lift up and off. Once I get it up, I need to make sure body is balanced on the lift ( might strap or clamp it for added safety) I am going to lift the body up as high as the lift will take it and leave it there while I finish up the frame & drive train. Once the drive train is done I will put it in the back room covered up and get the rest of the body underneath cleaned up and a coat of POR on everything except where I need to do a little floor pan work. I am hoping I am not messing up, but the plan is to drop the body back down on the burb chassis I just got, with new body mounts, to do all the sheet metal work ( so I don't mess up the frame I just did). I never intended for it to go this far......really.
Members I have met.
Old 04-23-2019, 09:02 PM   #145
richard2717
Re: My 1st 68 panel
I also noticed tonight that there is a major difference in the rear metal strip that those elevator bolts go in, between the 69 suburban with barn doors and the 72 suburban with barn doors. I forgot to take a pic but will post one tomorrow. The 69 one is way longer and has 8 bolts the 72 is shorter and has 7 bolts. At 1st I thought maybe it was barn door vs gate difference but then remembered they were both barn door. I am going to see what the panel is as well as a couple of the gate burb are sitting outside.
Members I have met.
Old 04-23-2019, 09:46 PM   #146
richard2717
Re: My 1st 68 panel
Pictures for HO455
Members I have met.
Old 04-24-2019, 04:16 PM   #147
richard2717
Re: My 1st 68 panel
This is the difference in the strips I was talking about. I can't check the panel at the moment because it is full of parts and up high on the lift
Members I have met.
Old 04-24-2019, 04:21 PM   #148
richard2717
Re: My 1st 68 panel
Too much body lift? Now I can get to the rest of the frame to clean & paint. Will also make sure there are no other issues that need to be addressed. I will have to remember to take the alternator off or leave front clip off when the body goes back on. It was a wee bit tight getting the inner fender past it. Progress like this is what keeping me motivated
Members I have met.
Old 04-24-2019, 05:13 PM   #149
pwdcougar
pwdcougar's Avatar
Re: My 1st 68 panel
Whaaaaaa
I want a lift!
Looking good Richard!
Old 04-24-2019, 08:20 PM   #150
richard2717
Re: My 1st 68 panel
Ok I am kinda scratching my head here, which is bad because most of my hair is already gone. Since I lifted the body off earlier, I figured I would go ahead and decode the engine. PO said that it was a 350 but I knew without running the numbers it was pot luck and probably a ragged ole 305. Anyhow, Casting # is 3970010 Which I had always understood to be a 350. I went to NastyZ28 website because I could actually read the stamped #'s on the front of the block which are MM14800. According to Nasty that decodes to a 1968 327. So I went back to the main page and sure enough that block casting # also works for a 327 From 1968 with A code for coming out of a Chevelle if i understand correctly. Can anyone else confirm if I am reading all of this correctly?
Members I have met.
