Old 02-08-2012, 08:28 PM   #126
xpickup
xpickup's Avatar
Re: 1948 Chevy / S10
Next one is the dies I made for my bead roller. I made the bead roller over 10 years ago but last year I powered it. I should have done that years ago. I have the AD belt line die, 1/4 bead die, 1/8 step die, 3/16 step die, and a tipping die. I made them all on a manual lathe. The next picture are the dies I made for my air planishing hammer and the way I hand finish my 1/4 beaded sheet metal. The next one is the 2 woodward fab hand shears and my beltsander. The next one is my air planishing hammer I made and my stretcher/shrinker. The last one is my one drawer in my big tool box. It has my Dagger tools hammer and dolly set , poly mallets, 8" sand bag, and a bunch of other sheet metal tools. I also have a large Dagger tools sand bag. I have a large english wheel that I started and have not finished it yet. I have Hoosier patterns lower dies because it was cheaper to buy them than me to hard cut and heat treat. Hpoe you all enjoyed the picture and if you want any more info just ask. That is all stuffed in a 20'x20' garage. I need more space!
Shannon
xpickup is offline   Reply With Quote
Old 02-08-2012, 09:34 PM   #127
99 to Life
99 to Life's Avatar
so sick, gotta love the tools man. It is such a good feeling buying em and or building them in your case.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 02-08-2012, 10:29 PM   #128
xpickup
xpickup's Avatar
99 to Life, I am a tool junkie. I love tools. I have bought a lot of them in the past 5 years. When I need to do something I usually buy what I need. Then I have it for the next project.
Tonight I started gaping the doors. They were tight all the way around mostly except the to because when I shaved the drip rail I gaped that then. So I lined up the door and started with the back. I ground it back and then welded the edge. I like to have between 5/32 and 3/16 gap. To grind them I use a small slitter wheel with a 36 grit disc along side of it. It gives the sanding disc a backer but does not cut with the slitter wheel. Because you can not use the rubber backer because it is too thick. And grind till you are happy with the gap. A good way of checking it is with the back of a drill bit.
Shannon
Old 02-08-2012, 11:52 PM   #129
BlueJeep
BlueJeep's Avatar
You do amazing work in a very small space!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 02-09-2012, 12:40 AM   #130
Rods57
Rods57's Avatar
Wow those front fenders are just unbelievable. that is one of the coolest things i have seen on this site, nice work...
Rods57 is offline   Reply With Quote
Old 02-09-2012, 12:43 AM   #131
oldman3
oldman3's Avatar
Shannon, thanks for the tool display, nice job on the door gap. I do mine the same way but I use a paint stick to check my gap....Jim
oldman3 is offline   Reply With Quote
Old 02-09-2012, 07:59 AM   #132
xpickup
xpickup's Avatar
BlueJeep, Thank you, I need to find out about adding on this summer. But hate to deal with the township. I know I could build it. But knowing all about the BOCA codes, what a pain. I might just have them rough frame it and then I will finish it.
Rods57, Thank you, I can not wait till I have the other side done so I can stand back and see the finished product.
oldman3, No problem on the tool display. I heard of using a paint stick before.
Shannon
Old 02-09-2012, 12:49 PM   #133
blitz'd
vintage car junkie
blitz'd's Avatar
Great work as always, love the headlights.
1950 chevy truck, s10 swap, bagged, v8, 18s
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761
blitz'd is offline   Reply With Quote
Old 02-09-2012, 01:56 PM   #134
xpickup
xpickup's Avatar
blitz'd, Thank you, Have you done anything to your truck lately. I have not seen any new posts for awhile.
Shannon
Old 02-12-2012, 05:07 PM   #135
xpickup
xpickup's Avatar
I ended up almost getting the headlights all done today. I also had to fix where someone else welded up the light hole on the top of the fender. It had something globed to the bottom so out it came. On the passengers side I have to make/weld in the fill piece for under the eye brow to the fender. Then the headlights are done except for the upper screw pads. They are even for as much as I can tell. I measured them out and they are right on. Then back to gaping the doors and a few other things.
Shannon
Old 02-12-2012, 05:08 PM   #136
xpickup
xpickup's Avatar
more
Shannon
Old 02-12-2012, 06:56 PM   #137
oldman3
oldman3's Avatar
Shannon, looks really good....Jim
Old 02-12-2012, 09:02 PM   #138
Atommik
Atommik's Avatar
Nice job, as always Shannon!
Atommik is offline   Reply With Quote
Old 02-12-2012, 09:33 PM   #139
britnjc
britnjc's Avatar
Looks great. I may have to try my hand at this mod in the future. Oh yeah I got the box also. You are a good friend. Thanks man
britnjc is offline   Reply With Quote
Old 02-12-2012, 09:56 PM   #140
Larry Lindley
very good shannon now Ill sale my tools and go back to drinking.thanks for posting
Larry Lindley is offline   Reply With Quote
Old 02-12-2012, 11:23 PM   #141
sgtusmc
sgtusmc's Avatar
One of the best fender treatments I've seen in a long while! Great job man.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 02-13-2012, 01:01 AM   #142
blitz'd
vintage car junkie
blitz'd's Avatar
Haha, my thoughts exactly!
Old 02-13-2012, 01:37 AM   #143
Daze57
Daze57's Avatar
shannon
you absolutely knocked it over the green monster wall ! again great work skills
there are such great fab/ builders on this site - what a pleasure to see all the fab work done by all !
Daze57 is offline   Reply With Quote
Old 02-13-2012, 02:13 AM   #144
drivea55
drivea55's Avatar
Man, What can I say?
Those headlights are awesome! what a look!!!
current project;
1950 GMC "Junk Yard Dawg"
http://67-72chevytrucks.com/vboard/s...d.php?t=635960
___________________________________________
SOLD to "ONEBADFIVEFIVE"
http://67-72chevytrucks.com/vboard/s...d.php?t=436406
drivea55 is offline   Reply With Quote
Old 02-13-2012, 02:42 AM   #145
Maximus
Maximus's Avatar
Hah, I just assumed when I first read this thread that they were 55-57 pickup eyebrows...
After you finished both sides i realized that they were car brows, VERY well done!
great custom touch, without being ruining any of the original lines
Bravo!
Maximus is offline   Reply With Quote
Old 02-13-2012, 02:44 AM   #146
drivea55
drivea55's Avatar
OMG... they are not 55-57 brows?
that's exactly what I thought too...
still cool but a bubble popper for my brainski.
ha ha
current project;
Old 02-13-2012, 08:58 AM   #147
AUSSIE54
AUSSIE54's Avatar
G'day Shannon,
Swell work again there mate. They look sharp in the photos. Geez it gets your mind ticking over with all of the ideas that can be gained through the forums. I just love the look of what you've done there, but then I also like 'em frenched as well as just standard! Oh the decisions,… what to do…what to do! I just have been checking out the door treatments on the crew cab Coe that mr pops has put on the 'pics of 47-59 crewcabs' thread. Certainly has got my mind ticking over! Great job again there on those brows mate! Are you happy with them? Any thoughts on doing the same treatment to one of your own trucks?
Anyway have a good one, I'll be catching up with you.
Regards,
Trently.
AUSSIE54 is offline   Reply With Quote
Old 02-13-2012, 04:12 PM   #148
jimig1
jimig1's Avatar
ha ha
I thought the same thing. A+ xpickup that is a great look i like it even more now that both are done.
55 2nd series Chevy Pickup
2019 Chevy Equinox(Daily driver)
2011 Chevy Malibu (Wife's car)
MSRA Member
I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose.
-George Carlin
jimig1 is offline   Reply With Quote
Old 02-13-2012, 06:37 PM   #149
xpickup
xpickup's Avatar
oldman3, Atommik, sgtusmc, Daze57, drivea55, Thank you very much.
britnjc, Thank you. If you do try it, let me know if you need any pointers and I will tell you how I did it. Glad you got your box.
Larry Lindley, blitz'd, Thank you, don't sell all your tools. You can drink and work at the same time. That is what I do when I get stressed!
Maximus, drivea55, jimig1, Thank you. No they are 55/56 car brows. I think the truck ones have a body line in them and that is why you use the car ones. I am glad they are both done so now I can see the finished product.
AUSSIE54, Thank you. Yes, I really like them but boy what a lot of work. On mine I welded the trim rings on and made special buckets with adjusters in the fender well. Then fill the seam on the trim ring so it smooths everything out and paint everything. I know what you mean with the forums, so much good ideas and information. Now when you work on yours again you better cut out that center post and start over.HAHA. Yes, we have to talk soon.
Shannon
Old 02-20-2012, 09:34 PM   #150
xpickup
xpickup's Avatar
Finally got back in the garage tonight. Last Tuesday my wife told me that the living room ceiling was wet. The bath room is right above, so out with the sawzall. Ended up cutting up 1/3 of the bathroom floor to fix the water pipes. I had to run them from the basement to the second floor. So now the sink, tub and toilet all have new plumbing. Thank god that I have as many wood working tools as metal tools so I had all the tools I needed. I only had to buy a small tubing cutter because mine was to big to go around the pipe. Yes i am a tool junkie. The drain for the tub was also bad so that got replace as well. I also put in a new sink and cabinet. Which as my luck has it, it also broke in half and had to get another one. I got a defective one naturally. It was not a good week! But as of yesterday it is mostly done. It really stinks we live in a house with only one bathroom. So back to the truck tonight. I finished up gaping the drivers door. It has a 5/32 gap around it now. It fits a lot better now. Next is the passengers door.
Shannon
