#126 |
![]() Join Date: Oct 2009
Re: Parting out a 1972 Chevy Cheyenne C10 ***Parts list added 12-17***
Welcome to the board. This is a great place to get answers but I am sorry because I do not understand what you are asking. What are you asking about fitting? Are you asking about the steering column? If you are the column should fit your truck but I have 2 other people in line infront of you. I have a local guy that is supposed to be here this weekend to get it. Let me know. Thanks
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. |
#127 |
Re: Parting out a 1972 Chevy Cheyenne C10 Rusty
Hey if you still have the fuel tank for $40 Ill take it if I can pick it up sat jan 14 (tomorrow). Let me know you can call me at 217-791-2883 so we can set it up.
Friends don't let friends drive fords. |
#128 |
do you still have the wheel tubs?
#129 | |
This pair of wheel tubs are sold. I might have a decent pair in another truck I have. I should be able to check tomorrow and let you know. Thanks
#130 | |
Pictures for timberjim36 The 67 cluster I have has 2 mounting holes with cracks(tried to show in the last 2 pictures and the printed circuit is coming apart at the studs for the temp. gauge. I think the one from the other cluster will work. PM sent
#131 |
I really appreciate all the stuff Todd. It really made the drive worth my time. It was nice meeting you and thanks again!
#132 |
todd,
what all do you have left of this truck ? cab/doors/chassis and maybe front clip ?? |
#133 | |
Here is an updated parts left from this truck. 1. Shifter linkage & Frame Pivot-- missing transmission tab $20.00 plus shipping 2. Grille brace- rusty-- Free plus shipping 3. Hood latch-- $15.00 plus shipping 4. Hood pin and latch plate (attaches to hood)-- $6.00 plus shipping 6. Interm. steering shaft-- $10.00 plus shipping 7. Evap. Canister bracket-- $5.00 plus shipping 8. Flange for exh. pipe against exh. manifold-- $5.00 pair plus shipping 9. Washer bottle bracket-- $5.00 plus shipping 10. Washer Jug-- FREE plus shipping 11. Core support to fender brace-- rusty but solid-- Free plus shipping 12. Exh. bracket that rivets to the frame by transmission crossmember--$10.00 plus shipping 13. Tailgate support links-- SOLD 14. Tailgate pivots-- SOLD 15. Heater hose clip/ bracket-- $2.00 plus shipping 16. Center bumper brackets-- $5.00 pair plus shipping 17. Battery hold down bracket-- $2.00 plus shipping 18. Steering column, automatic-- $40.00 plus shipping 19. Steering column mount-- under hood with clamp-- $10.00 plus shipping 20. Steering column mount-- strap attaches to brake pedal bracket-- $6.00 plus shipping 21. Steering wheel (cracked) with horn button and horn parts-- SOLD locally 22. Steering column trim (goes up to cluster)-- $6.00 plus shipping 23. Throttle cable bracket-- $5.00 plus shipping 24. Carrier bearing bracket-- rivets to the trailing arm crossmember-- $15.00 plus shipping 25. Misc. parking brake cable items including center cable-- SOLD 26. Door panels and armrest wood grain worn, extra holes drilled, chrome trim good-- $30.00 plus shipping 28. Rear step bumper-- SOLD 29. Tail light harness, See issues pointed out in post 138-- $15.00 Shipped 30. Harness from firewall to taillight harness-- $10.00 plus shipping 31. Headlight harness-- $18.00 plus shipping 32. Dash harness, fuse box looks ok, gauge cluster, non-a/c and no cig. ligher-- $20.00 plus shipping 33. Dome light--SOLD 34. Fuel gauge wire, from tank to fuse box-- $5.00 plus shipping 35. Fuel lines that hook to the sending unit-- $5.00 plus shipping 36. Evap. lines-- $5.00 plus shipping 37. Sunvisors, sticking is loose--$15.00 plus shipping 38. Sunvisor clips-- $5.00 pair plus shipping 40. Headlight and washer knob-- $5.00 plus shipping -- Washer Knob- SOLD 41. Glove box lid-- $20.00 plus shipping 42. Glove box latch catch (attaches to dash)-- $2.00 plus shipping 43. Reverse light housing, right side-- $5.00 plus shipping 46. Taillight housing-- $10.00 pair plus shipping 47. Cheyenne fender emblems-- $25.00 pair plus shipping 48. 8/350 emblems (frt. fender)-- $15.00 pair plus shipping 49. Headlight bezel-- $20.00 pair plus shipping 50. Left outside door handle-- $6.00 plus shipping 51. Jack tool hold down items-- $5.00 plus shipping 52. Speaker bracket-- SOLD 53. Door lock lever and retainer-- $5.00 plus shipping 54. Brace under steering column (flat panel)-- $5.00 plus shipping 56. Automatic brake pedal-- $35.00 plus shipping 58. Inside heater box with cables-- $35.00 plus shipping 60. Cowl panel, extra holes-- FREE NO shipping 61. Driveshaft-- $20.00 NO shipping 63. Roof panel (cut at the bottom of the a pillar and acrosss the rear below the double panel)-- $75.00 NO shipping
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. Last edited by Todd68Chevy; 03-05-2012 at 08:41 PM. |
#134 |
i am looking for a project period !
cab/rolling chassis....etc. and cheap. something to start with. |
#135 |
71-72 chevy preferred.
#136 | |
#137 | ||
I am sorry but I forgot to check. If you still need them let me know if you are looking for a wood floor bed or steel floor bed. Thanks
#138 |
Tail light harness pictures for Big Orange. When rechecking it I noticed a couple more issues that I had not noticed before. Right side marker light ground is broken but I also seen the power wire going to that light has a bad spot and actualy broke apart when I was moving it so that will need repaired and the boot for the left side taillight connector is split- see the pictures. I would take $15.00 shipped for the harness. Thanks
#139 |
Do you have pics of the dome light? If it's in good shape I will take it.
#140 |
I will check it out again and get pictures. Let me know a zip code and I will figure shipping. Thanks
#141 |
Shipping is to zip 26501. Thanks!
#142 | |
#143 |
Sold. PM sent
#144 |
#145 |
i'll give you $10 for the tailight harness shipped to 92706 if interested
#146 |
Sorry but I will not go cheaper than $15.00 shipped for the harness. It has a couple issues but it still has to be worth $10.00. Thanks for your interest but $15.00 shipped is the price. Let me know if you are still interested. Thanks
#147 |
I see your updated list but if items 13, 14 25 & 52 are available I would like to purchase all.
13. Tailgate support links-- $10.00 pair 14. Tailgate pivots-- $5.00 pair 25. Misc. parking brake cable items including center cable-- $10.00 52. Speaker bracket-- $5.00 PLUS; All front and rear marker lights $20.00 Steering wheel $25.00 Seat belts $20.00 Door pressure relief $5.00 AND I will pay shipping cost if you wrap and send to 04106 please. Thanks I can PAYPAL today if you PM. |
#148 |
Does it have have a good battery tray? 77018 Tks
1977 Camaro 468 BBC - SOLD - 1972 Chevy SWB....in the works!! ![]() 2006 Crew Cab Dmax/Allison Summit White-SOLD- 2009 Toyota Tacoma V6 Pre Runner - daily driver - my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595 |
#149 | |
This truck did not have a good tray but I will check and see if I have one around. Thanks
#150 |
This truck did not have a good tray but I will check and see if I have one around. Thanks[/QUOTE]
