Old 05-25-2012, 09:36 PM   #126
tc4x4
tc4x4's Avatar
Re: 1978 GMC Sierra C35 "Project Second Life"
Rotors, calipers, pads, you can reuse your same rear brake lines but mine were seized so i cut them and replaced them from the top of the diff out to each side.
Project Second Life----1978 c35
http://67-72chevytrucks.com/vboard/s...d.php?t=503961
tc4x4 is offline   Reply With Quote
Old 06-10-2012, 09:23 AM   #127
tc4x4
tc4x4's Avatar
OK I will be starting the drop on the front end real shortly, I'm posting for help. Can all you who have done this post up some advice and safety tips. I'm putting on drop spindles and cutting the springs. Also remind me about how much spring cut is equal to how much drop?
Also with this amount of drop, can I get the tires properly aligned again?
Thirdly, this truck needs a name. I'm open for suggestions...
Old 06-10-2012, 09:28 AM   #128
tc4x4
tc4x4's Avatar
One more question, for future thought of raising the bed floor, how is the bed floor attached and what is the easiest was of raising it as a whole like I have seen?
Old 06-10-2012, 09:33 AM   #129
cochino12
It followed me home?
cochino12's Avatar
1 coil is about 2", i always run a chain through the coil when pulling them so they pop out and take my head off.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 06-10-2012, 02:54 PM   #130
tinydb84
tinydb84's Avatar
Yeah you should be able to still align it but might have a ton of shims on the uca. I picked up an extra set of lca's and am going to try sectioning them 3/4'' so I dont have as many shims and narrow my track with.
Old 06-10-2012, 07:30 PM   #131
79 blue monster
79 blue monster's Avatar
on mine(3/4 ton 454) i cut 1.5 coils out and used 2.5in drop spindles. mine dropprd about 8 in. and my lca are 2in off the ground and im sitting on my bump stops. with your truck being a one ton, you have more leafs in the back giving you more drop. so in the front you have to go lower then that so you might have to notch your crossmember otherwise you'll have the rear lower than the back. someone correct me if im wrong.
safty stuff: i used a hoist, so i put blocks under my lower control arms, and lowered the truck down onto the blocks (compressing the lower control arms) and unbloted the spindle. then slowly lifted the hoist till the coils werent compressed.
1979 GMC 3/4 ton camper special 454 (7/8in drop) UPDATE: CADDILAC 500 SWAP AND 4X4 SWAP
http://67-72chevytrucks.com/vboard/s...d.php?t=518625
1965 gmc 4x4 build : http://67-72chevytrucks.com/vboard/s...d.php?t=724972
79 blue monster is offline   Reply With Quote
Old 06-10-2012, 09:12 PM   #132
tc4x4
tc4x4's Avatar
My rear dropped 9 inches.
Old 06-11-2012, 10:36 PM   #133
79 blue monster
ok, well you should be fine then. just make sure you cut enough coils out the first time, because it sucks having to do it twice..lol
Old 06-16-2012, 08:31 PM   #134
tc4x4
tc4x4's Avatar
Ok what tranny should i put into this beast when I put the 572 into it? Im thinking about going with an automatic, what say ye?
Old 06-16-2012, 09:04 PM   #135
JRANGER
JRANGER's Avatar
i say...dayum 572 damnit man thats beastly
JRANGER is offline   Reply With Quote
Old 06-17-2012, 09:36 PM   #136
tc4x4
tc4x4's Avatar
I'm thinking th400 with the gear vender overdrive....
Old 06-17-2012, 09:52 PM   #137
cochino12
cochino12's Avatar
Gear vendors are expensive but nice, I've found better pricing on 4l80e and controllers.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 06-18-2012, 09:56 PM   #138
tc4x4
tc4x4's Avatar
Ill look into them thanks.
Old 07-25-2012, 08:50 PM   #139
tc4x4
tc4x4's Avatar
I need to bro talk................lol............Anyways, I'm having second guesses and cold feet. The one ton was original when it came into my hands. I started off with little changes but now am to the point where major changes are happening. I know that in the long run at this point I could reverse all that I have done.
Older guys at my shop I take my DD's to are totally against doing anything to this truck. Ive said it before there is a huge lifted truck 4x4 scene around here in norther Michigan, but hardly any lowered trucks at all.
I guess i need opinions, guidance, or maybe just a good slap to the face.
What say ye?
Old 07-25-2012, 09:11 PM   #140
Conundrum
Conundrum's Avatar
Do what you want with it, it's your truck after all. Most of the people around here are into the lifted 4wds as well cause they like to play in the mud and what not. I have a few friends that are in the lowered truck scene but it's not many. I really like where your truck is headed and i'd like to see you finish personally, but ultimately it's up to you and what you want.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 07-25-2012, 09:14 PM   #141
tc4x4
tc4x4's Avatar
Don't get me wrong, I want to finish it, but do you think it was to original to start modifying.
Old 07-25-2012, 09:31 PM   #142
Conundrum
Conundrum's Avatar
No, and the reason I say that is they are all over the place. I know they are pretty rare up in Michigan in that good of shape, but i'm sure you could find another to leave or fix up as original if you want to.
Old 07-25-2012, 09:37 PM   #143
tc4x4
tc4x4's Avatar
Good point...
Old 07-26-2012, 09:09 AM   #144
JRANGER
JRANGER's Avatar
This is what you want to remember...Its your truck! Its your baby! Its your vision and what you want!!! Do what you want bro not what others want you to do!!
Old 07-26-2012, 09:23 AM   #145
82ccshorty
82ccshorty's Avatar
Did you weld those rear end plates in already? I had to take mine back out because i had to machine them because my rear sat lower then the front because those plates where to thick. so if you already welded them you will need to drop your front like an extra half an inch to make it sit level.
1969 chevy camaro Z28 #matchin Factory 4wheel disc
1969 chevy cst10 big block overdrive 5/7 drop dog dishs
1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s
2004 gmc sierra dually 4/4 lowering daily driver
82ccshorty is offline   Reply With Quote
Old 07-26-2012, 11:01 AM   #146
79 blue monster
keep going on it, its all in how YOU want it to look. you'll get people that cant stand to look at it and then you'll get people that love it more than anything. i myself am looking forward to seeing it get done because i am doing the same thing. your truck and mine are the only 8lug single cab trucks that i've seen lowered in our area, so that means its really unique! keep going on it, and keep up the good work!
Old 07-27-2012, 07:52 AM   #147
tc4x4
tc4x4's Avatar
Are you talking about the spring saddles? If so yes they are welded in.
Old 08-11-2012, 11:36 AM   #148
tc4x4
tc4x4's Avatar
http://www.summitracing.com/parts/WST-13600/
OK, so here is where I'm at. These spindles will get me 3'' lower. My front started and still is at 34 3/4 inches at the lip of the fender above axle. It never changed when I lowered the rear. The rear was two inches higher before I lowered it. 36 3/4 inches measured the same way. Now it is at 27 3/4 inches high. So it appears to have been lowered a total of nine inches.
So my question is how much to lower the front. If I lower it 7'' then the truck should be level. Right? But I think I want the truck slightly lower in the front. I forget what that is called. So how do I go about getting it that low? Isn't cutting a whole coil get me 2''? If so I could cut 2 coils out getting me 4'' and with the 3 '' i get with the spindle that would make 7''.
How am I looking so far? How would I get a little more than 7''? Do you guys see any problems with this? Am I cutting to many coils out?
Old 08-11-2012, 11:49 AM   #149
cochino12
cochino12's Avatar
Cutting 2 coils is probably too much. Id try cutting one coil adding the spindles and adding a shorter shackle to bring the rear up a bit. 7" drop and tires as tall as yours will require you to remove your inner fenders too.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 08-11-2012, 12:02 PM   #150
tc4x4
tc4x4's Avatar
Ive never asked but what is involved in removing your inner fenders? Does removing them take away from structural support? any bracing needed? What negative affects are there from cutting out two coils?
