Old 01-16-2013, 09:44 PM   #126
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 1988 Suburban "V Rig" Gets Cummins Power
Originally Posted by 1985-GMC View Post
Man everything looks awesome! Super jealous!
What condenser are you using on this truck Chevy, Dodge, universal? Whatever it is you should go with a parallel flow like all the 94+ vehicles have.
It has the stock condensor in it which is like you describe.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-16-2013, 10:26 PM   #127
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
So is it stock or a stock replacement with the new design? The type of condenser makes a world of difference, I used the stock one when I fixed mine because I was tight on money at the time but I should have just waited and bought the parallel flow one. I'm running R152a in my truck and it does really well even with the old condenser. It's one of the refrigerants that may get used when R134a gets banned in the next few years, and you can get it at Walmart for $4.97 per 12oz can. They use it in keyboard dusters and it is actually more efficient than R134a. Here's the condenser I was planning on using: http://www.ebay.com/itm/NEW-UNIVERSA...ab4f4a&vxp=mtr
And what the R152a comes in: http://www.walmart.com/ip/Ultra-Dust...igger/16630941
I do have to mention that is it slightly "flammable" under curtain circumstances, it will light with an open flame but it wont support a flame.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 01-16-2013, 11:44 PM   #128
Dieselwrencher
Thanks for the info. I'll be getting one of those for my 76. I'll advise the owner and let him make the call on it. I doubt he'll want to change it since we have half of thea/c lines already made. The a/c worked fine before so we'll see.
Ryan
Old 01-16-2013, 11:57 PM   #129
ryanroo
ryanroo's Avatar
Originally Posted by Dieselwrencher View Post
You a Slacker Yeah right. You have a 44lb spool compared to my dinky 10lb'r. My new welder will hold a bigger spool I hope. And my cylinder isn't a T unit either. Another reason why you suck. Haha
Go big or go home right? what are you looking at for new ones?
that was an awesome link. ive been entertaining the condenser in the back of my head, not really worrying about it. i need to get it figured out so i can mount it and get the hood latch done. i may try to run R12 since it works so well and i like vintage....
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 01-17-2013, 12:00 AM   #130
Dieselwrencher
Ryan
I ordered an Auto Arc 222, it should be here in a week and a half.
Ryan
Old 01-17-2013, 12:22 AM   #131
ryanroo
ryanroo's Avatar
cant go wrong with blue! im not familiar with the auto arc, but the 212s have pretty much the same output, and i liked those a lot. i did and do a lot of structural MIG work, so i wanted something i could spray arc with at home. just in case i stumbled into some side work or something. Ill be interested to learn how it welds! and it should support the big rolls of wire.
72 K20 12v build
Old 01-17-2013, 12:24 AM   #132
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Ryan
That one should be fine as long as you can make it work with your latch, Ive thought about putting two hood latches on either side of the intercooler and just remove the one in the center.
I plan on running R-12 im my GMC because I want it freezing cold and I already have a couple of cans saved I just need a couple more. I'm also thinking about switching over from the fixed orifice tube to an expansion valve like the 67-72 trucks to save the A6 from dieing.
Tony
Old 01-17-2013, 12:30 AM   #133
ryanroo
ryanroo's Avatar
i'll force it to work! hahaha it looks like ill have plenty of room, ill probably just have to hang it down a little. the I/C is away from the latch far enough that itll barely require a trim. i have plenty of space in front of it, and nothing stopping me from going down an inch or so as needed.
mosesburb has a set up in his burb that he says is an icebox. so i may use his plans and run the more modern stuff... that is to far away for me to worry about to much.
72 K20 12v build
Old 01-17-2013, 12:42 AM   #134
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
With R-12 and a parallel flow condenser you will have icicles coming out of the vents!
Tony
Old 01-17-2013, 12:56 AM   #135
Dieselwrencher
This brings back a funny memory for me. We went to pick up my friend's dad's 64 T-Bird convertible from his step dad's barn. It was mid July and hot as balls out. We finally get the car running and pull it out of the barn. This poor thing was nasty dirty, and had a huge hole in the top from the coons tearing it up. Anyway, we were BSing by a tree and my buddy turns and runs thinking the t-bird was on fire. It was just frosty air from the a/c. I'll never forget that. That was crazy. The car barely had any power, but the a/c was better than most refrigerators.
Ryan
Old 01-17-2013, 01:01 AM   #136
ryanroo
ryanroo's Avatar
I had a 77 c20 that was that way. i bought it to part but drove it for few days first. my mom borrowed it to haul some rocks for her garden. as she got in to go get them she made some comment about getting the raw deal on the swap(i had her trailblazer). i just smirked. when she brought the truck back she whined about how cold it was inside
72 K20 12v build
Old 01-17-2013, 06:05 PM   #137
Dieselwrencher
The auto arc's are made by Miller and use all the same components. I'm not sure what the real difference is. I have an auto arc 182xlt now. I'm just upgrading before my current welder says bye bye.
Ryan
Old 01-17-2013, 06:10 PM   #138
Dieselwrencher
More progress. I made a new bracket to mount the rear brake line to. I transferred the brake lines over from the old 14 bolt, and installed a new rubber line.
I also finished welding the tail pipe up. I had to remove 1" above the rear axle so the tail pipe wouldn't hit the fuel tank shield. This whole exhaust kit started out as a 4" after market kit to fit a 1993 Dodge cummins truck. I've modified what needed to be to make it work on this Burb.
Tony, the owner of the "V Rig", made this cool skid plate to protect the trans cooler. It is made from 1/4" aluminum, and has a hinge on the front so you can lower it down for maintenance or cleaning.
Ryan
Old 01-17-2013, 08:05 PM   #139
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Oh that's pretty cool! I might make something like that because I have a PTO winch to go under the front like that and that should protect it pretty good.
Tony
Old 01-18-2013, 12:42 AM   #140
Dieselwrencher
Tail pipe cleaned up and painted.
Ryan
Old 01-18-2013, 08:23 PM   #141
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Sweet! Do they make a 5" for the first gens like that?
Tony
Old 01-18-2013, 09:02 PM   #142
Dieselwrencher
No they don't. I don't think you can get 5" over the tcase and then over the rear axle on a first gen. Maybe over the axle, but it'd be really tight.
Ryan
Old 01-21-2013, 08:10 PM   #143
Dieselwrencher
I got the exhaust all finished up and installed. I didn't get as much done this weekend as I wanted to. I went hunting yesterday, and Saturday I took a conceal carry class and we had my daughter's 2nd B-Day party.
Ryan
Old 01-22-2013, 07:27 PM   #144
v-man
I can hardly hold my pants on. I can't to drive that bad ass and give that dump trailer a workout
v-man is offline   Reply With Quote
Old 01-23-2013, 09:56 PM   #145
Dieselwrencher
The driving part will be really soon! The radiator hold downs are made and drying right now. In the morning I have to finish the trans linkage set up, finish the grid heaters, and source parts for the vacuum lines. Fill the coolant system, drill and tap the exhaust manifold for a pyro probe, and go over wiring and such. It's really close.
Ryan
Old 01-23-2013, 10:01 PM   #146
mosesburb
I had a V-8
mosesburb's Avatar
Looks great man!! A word of warning on that skidplate for the cooler though; there are nowhere near enough holes in it to allow the cooler to be effective anymore. It needs to be more holes than metal and even at that, it will still be a SERIOUS restriction to airflow. Maybe some expanded metal with large holes would work better, but even that is a large restriction to free-flow air. Years ago a buddy of mine was running a racecar/engine development testbed and he was experimenting with different screens across the frontal opening to keep track debris/stones/etc out of the radiator and even wide pattern wire mesh creates a significant reduction in airflow. I never would have believed it myself, but it was hard to debate the actual test results. He ended up runing a wide mesh for the purpose really surfing the fine edge of cooling system preservation vs engine temp control. Not quite chicken wire, but closer to chicken wire than door screen. Just some food for thought.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 01-23-2013, 10:14 PM   #147
v-man
Point well taken, Ryan thought it might be a problem but it looks so sweet on there, might have to remove until we can come up with something different.
Old 01-23-2013, 10:29 PM   #148
v-man
Maybe drill 2 giant holes in that cheap tin foil front bumper on both sides of the winch and make some kind of ram air.
Old 01-24-2013, 12:06 AM   #149
Dieselwrencher
We can try that. Worst comes to worse, we can put a small electric fan on the cooler its self.
For some good news, we are making progress. Today Tony found the correct strap kit for the front frive shaft at the D60 yoke. So the drive shafts are done now. I got the radiator hold downs completed, and started on the trans shift linkage. The list of 35 things 2 weeks ago is down to about 8 now. Wahoo!
Ryan
Old 01-24-2013, 07:20 PM   #150
Dieselwrencher
Well, I didn't get as much done today as I would have liked to. When I got to my shop this morning, nothing wanted to light up due to the lovely temps. Any way, I did get the radiator hold downs installed, and finally got coolant in the system. Has anyone used Champion radiators before? I'm not real pleased with this one. First off the small fitting for the over flow hose was stripped out in the radiator neck. I repaired that last week. Today I went to tighten the plugs they provide for the 2 extra ports in the RH tank. They were both cross threaded. I had to drill them bigger and re tap them. Then go to Tompkins and get bigger fittings. What a PITA! Anyhow rant over.
Ryan
