07-20-2018, 06:51 PM | #126 |
Re: HOW TO: Crossmember sectioning ...
I'm running spindles and mmw control arms. looks like you might have to notch the control arm for steering shaft?
07-20-2018, 07:00 PM | #127 |
I’m all stock, going as cheap as possible. Yea probably I will do so after I slap cab back on and see exactly how much I need to knotch and where exactly
07-20-2018, 07:10 PM | #128 |
I've been trying to stay cheap through the whole thing. and I have 7k into it
07-20-2018, 08:40 PM | #129 |
One of a kind is "priceless"! In my neck of the woods it sure would be...
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
07-21-2018, 05:43 PM | #130 |
I went 1.5" and when I realized that I'd need to notch the control arm I ordered a no limit R&P kit. I don't like spending $1k on a single component but for the amount of work it would take to DIY a R&P I think it's worth it.
Whether the no limit kit will work with a pancaked crossmember is yet to be seen...
1968 LWB C20 / AC / Wood Bed |
07-21-2018, 06:37 PM | #131 | |
07-23-2018, 12:24 PM | #132 |
Yeah I think if you're fine with the stock steering there's no need to go R&P -- in my case I was going to convert in the future anyway, and just didn't want to waste the effort getting the stock steering to work now only to upgrade it later.
07-24-2018, 05:53 PM | #133 |
Nvm
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy Last edited by tinydb84; 07-24-2018 at 05:53 PM. Reason: Wrong thread. Oops! |
07-26-2018, 06:42 PM | #134 |
The X-member on my dually is notched 1.5" (89 Square body). The lower a-arms are PB 1" forward units but I originally had the modified OE lowers moved forward .750".
My set-up did require the small notch to the upper driver a-arm as mentioned. MMW uppers & later model OE uppers also had too large of an OD @ the bushing area & would not have cleared (I still have the MMW arms sitting in a box on the shelf three years later ). When I'm air'd out, I can slip a slim piece of cardboard between the shaft/notch (like a spiral notebook cover).
07-27-2018, 02:06 PM | #135 | |
07-27-2018, 02:46 PM | #136 |
When I cupped the arms, I allowed for ~1/2" of clearance on my mock-up bag @ 25psi. Installed, the weight of the BBC plus those heavy hubs expanded the bad more than I liked (my clearance was about the thickness of a yardstick). I felt once the suspension started moving around, the bag would likely make contact.
I opted for Porterbuilt arms as they would swap right in place, had the forward placement option, & already had a tab for a sway bar (I still had to figure that out for the modified factory lowers as the original mounting position was no longer an option).
08-07-2018, 10:57 PM | #137 |
I too tried this and failed. Now i have to make my own motor mounts for my 292
nevertheless, it is an awesome write up |
08-08-2018, 11:40 AM | #138 |
Failed how?
08-08-2018, 02:53 PM | #139 |
well it isnt a complete failure cus it looks cool and i made it work but im having a hard time leveling the engine and making motor mounts. So i went to put in a spare c20 cross member i had and its not the same. they are different
08-08-2018, 04:07 PM | #140 |
The way the x-member in this thread was sectioned should not alter the MM tower dimensions. Makes me wonder how yours are not working? I've done 4 of these & all re-used the MM towers w/o issue. One even used aftermarket MM towers & they fit/worked w/no problem.
08-12-2018, 02:00 PM | #141 |
they bolt on just fine the problem is that i too have to section them as well to bolt on to the motor...
unless i make up the difference from the frame to the engine with some square tubing which i found out about yesterday |
08-13-2018, 11:42 AM | #142 |
I think you did it wrong, the surface where the engine mounts should not have moved at all relative to the frame.
08-13-2018, 06:04 PM | #143 |
Not so much 'wrong' since there's more than one method/version of x-member notching. But, if he did it the way this "How To" thread describes, the MM towers should not require mods unless an x-member from a different year model was used.
08-13-2018, 10:17 PM | #144 |
I think the issue is when you raise the steering up to keep the stock geometry. That's the problem I ran into with mine. My crossmember was sectioned 2" and raised the steering the same. I had to move the engine up to clear the drag link. When I had the 292 in it, I spaced the mounts up about 1.750" and chopped some of the oil pan. I've now switched to an LS and had issues with the crank pulley hitting the drag link. I have the mounts spaced 1.5" and used dirty dingo sliders on square body clamshells. It took some moving around but I think I have the engine in a spot that they can coexist peacefully.
08-14-2018, 01:14 AM | #145 |
I didn't move the steering. I also limited things to 1.5" to avoid the domino effect. These trucks had geometry issues w/o modification. I didn't notice steering related issues until my Dually. But, that's my fault as I was super agressive on Caster (7-ish).
08-14-2018, 02:48 AM | #146 |
08-14-2018, 10:35 AM | #147 | |
I've seen how they did their initial set-up for their R&P kit (notching the x-member @ the rail area only). I didn't think sectioning an x-member as described within this thread would work w/the NL R&P kit.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-14-2018 at 10:42 AM. |
08-14-2018, 11:55 AM | #148 |
I got my no limit kit and it looks like everything will clear with some modifications to the mounting bracket and steering linkage location, and probably frame notches for the R&P links. Side note, not super happy with the quality of this kit -- sloppy grinding on the rack, hoses installed crooked, plastic crossover line instead of metal... probably more to notice upon install.
08-14-2018, 12:09 PM | #149 | |
03-31-2020, 08:24 PM | #150 |
what happened to the pics they dont show up
