Old 07-08-2015, 10:33 AM   #126
step65
Re: My 65 step build and first chevy
Originally Posted by TJ's Chevy View Post
Hoping to hear a video of what they sound like! lol
Lol I will try. My neighbors want me to start it on weekend so they can hear it. I told them sure and we can celebrate with a few shots of tequila Lol
step65 is offline   Reply With Quote
Old 07-08-2015, 10:36 AM   #127
step65
Originally Posted by Jeff La View Post
Your doing some really great work. Paint looks flawless. Work to be truly proud of.
Thanks Jeff I appreciate your support.
Old 09-14-2015, 09:56 PM   #128
step65
Well it's been a few months since I posted been doing work on truck when I can nothing goes as fast as planned lol. Here are some pics of things I have been working on.
Old 09-14-2015, 10:00 PM   #129
step65
Ebrake system took awhile to set up I used most of old system fit to the new cross member I got. added some cable guides from junk yard to keep cables from rubbing. Work really well. I used some 3/8 stock to make cable ends to adjust the length of the ones I had shorter. Used the mig welder as well as crimp.
Old 09-14-2015, 10:02 PM   #130
step65
Cable and guide to keep it from rubbing
Old 09-14-2015, 10:04 PM   #131
step65
I still need to get a few bolts a little longer and some cotter pins to make sure the system stays together. But for the most part pretty happy with the outcome.
Old 09-14-2015, 10:08 PM   #132
step65
Next I got the fuel system finished made a line to mount to front of engine that can connect to fuel pump as well as carb with short hose. Also got the gas pedal cable and trans TV cable working right. Got the Tv system from Bowtie and the throttle bracket is a universal I modified to fit
Old 09-14-2015, 10:10 PM   #133
step65
Next I got the column all hooked up linkage and steering shaft.
Old 09-14-2015, 10:14 PM   #134
step65
I got the wheels cleaned up painted with some rally silver and put the center caps and rings on. I like them more than I thought I would. Running 255 70 15 on back and 235 70 15 on front.
Old 09-14-2015, 10:21 PM   #135
step65
Last thing I have been working on is the exhaust. I got the flow master universal kit. And I don't think I used one pipe where it was intended for. All I have left from the kit now is a bunch of 18 to 24 inch straight pipe left. I need to pick up a 45 bend to finish the exit out on passenger side. I am gonna wrap the pipe where it goes by the brake line. I also got a piece of aluminum to make heat shield by the fuel filter. I think I am ok here as far as clearance. Take it easy on me this is my first exhaust, a little pieced together but I am pretty pleased with the end result.
Old 09-14-2015, 10:22 PM   #136
step65
More exhaust pics
Old 09-14-2015, 10:24 PM   #137
step65
And here is what I had to make it work
Old 09-14-2015, 10:28 PM   #138
step65
Now I am starting to modify the ammeter to a volt meter. Getting close will post more pics when completed. Using every ones suggestions from this site. You can see how hot it was getting so will feel better having the voltmeter instead, especially since I am using a 100 amp alternator now.
Old 09-14-2015, 10:34 PM   #139
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Looks good!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 11-17-2015, 07:57 PM   #140
step65
Quick update got gauges back together with the volt meter upgrade. Here is pictures of before and after. I still want to get a tach for it before I put in. I just cleaned up and painted needles no decal kit was really needed. Polished the lens with 3M micro polish.
Old 11-17-2015, 08:00 PM   #141
step65
Also just got my seat back from upholstery shop. Really like the outcome. Seat has all new foam and is nice and solid again.
Old 11-17-2015, 08:05 PM   #142
step65
Last thing to update is got the drive shaft back from getting it shortened and balanced. Also got new yoke and bearings. No pictures of it in but it fits perfect now. I got a Champion 3 row radiator with 2 12 inch electric fans as well. Will be staring to put the front end together soon now. I went with the CC6062 because it will bolt in without the saddles and also has the top coming out in center which works well with my serpentine setup. Will post pics of install when done. It is nice to see it starting to come back together.
Old 11-28-2015, 11:49 PM   #143
step65
So I tried the CC6062 and was told it would bolt right in. Unfortunately it does not. I had hoped it would. It is to tall and would have to cut the cross member where the saddles for original are. Also petcock on wrong side. Went ahead and took back and got the CC284 which is for my year truck. Also went with 2 12" fans. Here is pic of radiator mount in truck only had to slightly reshape lower saddles.
Old 11-28-2015, 11:54 PM   #144
step65
I fabricated this frame to hold the fans and bolted where the stock shroud was. It worked out pretty nice. I did not want to use the plastic ties through the radiator. I have heard some guys having heating problems with the shrouds when going down highway as they can restrict airflow. So thought I would give this a try.
Old 11-28-2015, 11:58 PM   #145
step65
Here is a pic when I powered one of the fans it passed the dollar test lol. And a pic of where I put the overflow. And also a pic of front end coming together. Starting to look like a truck again. That's it for now getting close to starting electrical.
Old 12-14-2015, 07:36 PM   #146
step65
Started installing the Fatmat Rattletrap sound deadener. I got 50 square feet looks like it will make it. Here is a few pics will post finished cab after next weekend. I have the firewall pad to install as well. This part taking longer than expected.
Old 12-14-2015, 07:38 PM   #147
step65
Got my GenIV vintage air system ordered today. Can not wait to get it. Just a few odds and ends to get and will have all that is needed to start engine. As soon as I finish this Fatmat I can start the electrical as well.
Old 12-14-2015, 07:50 PM   #148
DOUBLE-DINGO
DOUBLE-DINGO's Avatar
Wow that truck cleaned up nicely.
DOUBLE-DINGO is offline   Reply With Quote
Old 12-15-2015, 11:06 AM   #149
step65
Thank you it has been almost 3 years I am starting to get excited now. Hope to be driving this summer.
Old 12-26-2015, 08:48 PM   #150
step65
Finished up my sound deadener install today. 50 square feet just made it.
