Old 04-19-2016, 08:54 AM   #126
chase@ridetech
chase@ridetech's Avatar
Re: RideTech's New C10 CoilOver Kits
Originally Posted by aod92 View Post
I have this kit on my truck and the bottom control arm sits about 1-1/2 from the ground. No matter how much you change the spring height on the coil over the control arm will stay in the same place right? I took my truck for a ride and the control arms scrapped the ground multiple times.
what is your eye to eye measurement on your coilovers at ride height? Also, what size of wheel and tire do you have mounted on the truck?
Chase Mundy
Direct Line: (812) 481-4736
Email: chase@ridetech.com
chase@ridetech is offline   Reply With Quote
Old 04-19-2016, 09:28 AM   #127
aod92
aod92's Avatar
I adjusted the coil over yesterday and it gave me a little more clearance. I have about 2" now. I'll take a measurement from eye to eye. What should it be? The tire size is a 205/70-15
aod92 is offline   Reply With Quote
Old 06-13-2016, 09:42 AM   #128
Vandals909
Can more of you guys running this kit please post photos of your trucks?
Vandals909 is offline   Reply With Quote
Old 06-13-2016, 09:55 AM   #129
aod92
aod92's Avatar
Here's the latest pic of my truck.
Old 06-13-2016, 10:08 AM   #130
MMcMasters
MMcMasters's Avatar
The Stance is perfect!!
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 06-13-2016, 10:09 AM   #131
tommyd241
tommyd241's Avatar
Looks great!
'68 SWB Fleetside
'98 K1500 Silverado
tommyd241 is offline   Reply With Quote
Old 06-13-2016, 10:56 AM   #132
Vandals909
thank you. The truck looks great. What is your experience with the kit how does it ride and how do you like it? Any issues with ground clearance and the front end?
Old 06-13-2016, 11:02 AM   #133
aod92
aod92's Avatar
Rides and handles very well. I haven't even put on my front sway bar
Yet and it corners great. Ground clearance by the control arms is a little low but with and lowered vehicle you have to be careful. No regrets buying this kit at all.
Old 06-13-2016, 12:22 PM   #134
Vandals909
Old 06-13-2016, 12:38 PM   #135
Hugger67rsss
Hugger67rsss's Avatar
Here is mine, haven't drove it yet but it's about done
Aarik Gault
1966 GMC SWB, Ridetech Suspenion
1968 Camaro autocross/track car
Hugger67rsss is offline   Reply With Quote
Old 06-13-2016, 12:53 PM   #136
Vandals909
Aod92 is that the lowest the back will go without some type of bed modification?
Old 06-13-2016, 02:05 PM   #137
Hugger67rsss
Aarik Gault
Old 06-13-2016, 02:12 PM   #138
aod92
aod92's Avatar
It could go a little lower but not much.
Old 06-14-2016, 08:20 AM   #139
chase@ridetech
Truck Looks great!
Chase Mundy
Old 06-14-2016, 08:23 AM   #140
chase@ridetech
keep us posted!
Chase Mundy
Old 06-14-2016, 12:55 PM   #141
SKT
SKT's Avatar
Originally Posted by Kook87 View Post
Sharp looking truck!
SKT is offline   Reply With Quote
Old 06-14-2016, 04:51 PM   #142
Vandals909
When you order the kit do you tell Ridetech which motor and trans combo you are running to get the correct rated springs for the coilovers?
Old 06-14-2016, 05:54 PM   #143
aod92
aod92's Avatar
I would give ridetech a call in the morning and ask. I believe most kits go out with the same coil springs for our trucks.
Old 06-29-2016, 09:53 AM   #144
chase@ridetech
When you order a coilover kit we ask what the motor and trans combo is. If we don't be sure to tell us. The LS and Small block springs are the same, but the big block trucks require a stiffer spring.
Chase Mundy
Old 06-29-2016, 09:55 AM   #145
chase@ridetech
Also let us know if you have any additional weight such as superchargers, turbos etc. because they can also vary the spring rate.
Chase Mundy
Old 07-10-2016, 09:57 PM   #146
Hugger67rsss
2nd trip out with the truck and less than 20 street miles. Brought home a win in the Columbus Goodguys truck class. It's amazing how well it does for a stock crossmember.
Aarik Gault
Old 07-11-2016, 10:05 AM   #147
aod92
aod92's Avatar
Congrats man that's awesome!
Old 07-12-2016, 11:58 AM   #148
zach_carver
zach_carver's Avatar
I thought i recgonized this truck! Seen its pics on goodguy show last weekend. I love the trucks in autocross! Yours and James trucks make me jealous. Congrats man!
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 10-27-2016, 10:22 AM   #149
Trackman101
Trackman101's Avatar
Anyone snaked a dual exhaust through the rear coil over set up ?
Trackman101 is offline   Reply With Quote
Old 11-10-2016, 03:48 PM   #150
KenAdams
KenAdams's Avatar
I'm a little late to this thread, but I also purchased this kit. So far this install has gone okay. A couple things I learned though.
-Paper templates are next to worthless. It was much easier to cut off the high section of the front crossmember. Sit the new bracket down and then trace out what actually has to be cut out. The one for the rear was, ummm... off... I bet I ground down another 1/4-1/2 inches in spots to have a nice tight flush fit.
This is the final cuts before the frame went off to powder coat. I should start reassembling it next week.
KenAdams is offline   Reply With Quote
