Old 12-25-2013, 07:03 PM   #126
skymangs
skymangs's Avatar
Re: 49 ls1
Lookie what got for Christmas, a new Lawnmower! This is pre-bags. took the springs out to decide where I want it to sit aired out. boards are about 2" off the ground, and I think I'm gonna be happy with that. Any lower and I'll be concerned about my oil pan, it's 2" off the ground as well. Ride height will be in the 4.5-5" neighborhood. Looking like I'm headed to Kansas tomorrow to pick up a rolling frame for my buddies 31 sedan, probably won't get much done till Friday.
skymangs is offline   Reply With Quote
Old 12-25-2013, 07:38 PM   #127
59stepside
59stepside's Avatar
Re: 49 ls1
That will look good sitting low.
USCG Aviator
C-130
1959 Stepside build - http://67-72chevytrucks.com/vboard/s...d.php?t=602386
59stepside is offline   Reply With Quote
Old 12-26-2013, 12:49 AM   #128
oldman3
oldman3's Avatar
Re: 49 ls1
Looking good Chris...Jim
oldman3 is offline   Reply With Quote
Old 12-26-2013, 11:32 PM   #129
skymangs
skymangs's Avatar
Re: 49 ls1
thanks guys. Having self doubt about the aired out clearance. I'm thinking I'd better decide on a tire size (overall height in front) before I set the min height. right now I have an inch and a half clearance between the oil pan and the ground. with 27" total tire height. If I use a shorter tire, my pan may wind up in the ground. I was looking at H3 pans, they advertise as shorter, but no one provides any actual measurements.
Old 12-27-2013, 12:11 AM   #130
BlueJeep
BlueJeep's Avatar
Re: 49 ls1
I've got the H3 (AKA Muscle Car) pan, what do you need/want to know?
Here is the depth vs. the tranny pan on the 4L60:
Side pic:
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 12-27-2013, 12:20 AM   #131
oldman3
oldman3's Avatar
Re: 49 ls1
Hey Chris, go to thread #518233, page 1 has a link to all the LS pans. I don't know how to attach the link...Jim
Old 12-27-2013, 12:27 AM   #132
jed971959
Re: 49 ls1
think this site may have what you want http://www.stevesnovasite.com/forums...d.php?t=208618
jed971959 is offline   Reply With Quote
Old 12-27-2013, 12:32 AM   #133
99 to Life
99 to Life's Avatar
Re: 49 ls1
sarge, yeah tire size is key. Im running a 26" tall 14" bias white wall. couldn't start till I had them. So are you running bag cups up front? you could run a taller cup which should restrict how far down it will go up front, then set the back up however you want to level it out. Aired out I'm 4" off ground with no weight on the frame, thinking about 3.5-3.75" when I load it up. With this distance it allows me to keep important things up a little higher. That lets my body set about 3" off frame, but I'm running s10 frame. The nice thing about these trucks is the stock channel it has with the rockers hanging down over frame. From my experience I don't like the frame being less than 6-7" off ground at ride height, running boards obviously lower. So to me, its not always about laying frame esp with trucks, they are a bit more forgiving with that. I'd take advantage of that and just keep frame up a little higher aired out. Nice thing is you got your boys truck to reference, as do I.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 12-27-2013, 11:23 AM   #134
skymangs
skymangs's Avatar
Re: 49 ls1
Wow, lots of information in those links. Looks like the Hummer pan is the way to go. That one will suck the pan up 1/2" above the crossmember. Thanks all!
Old 12-27-2013, 09:43 PM   #135
skymangs
skymangs's Avatar
Re: 49 ls1
Ok, so first let me backtrack a little to cover what I've got to work with. 4 2600lb bags, 2 V-air 480C compressors, 5 gallon tank, avs 9 toggle switch, and 8 1/2" npt solenoids. I was told by a good friend of mine that 2600lb bags and this setup were the way to go.
Old 12-27-2013, 09:47 PM   #136
skymangs
skymangs's Avatar
Re: 49 ls1
I plan to set up my air manifolds this way, on each side, to eliminate air lines crossing over the exhaust and driveshaft. I've also seen them set up as individual pairs for each corner. Does anyone have any recommendation as to which way works better? Or is it merely a personal preference.
Old 12-27-2013, 09:57 PM   #137
skymangs
skymangs's Avatar
Re: 49 ls1
So here's my progress for today. I made plates for the top and bottom of each front airbag. The lowers I welded into the A frame to give me a flat surface, and stiffen it up a little.
My plan on the front tires is P215/45R17, which measure at 24". Since I've got 27" tall tires on it now, I'll build it 1.5" higher than final ride height, and I should be good to go.
The last pic is the mocked up setup. Tomorrow morning I'm going over to a buddies shop to slip roll some 1/8" plate to make those upper plates into "cans". (I know I can buy "cans", but I can't stand buying something I can build myself). Then I'll pull it all apart, make some gussets for my upper cans, and seam everything back together. I should be about ready to put the front end together at that point. When I tear it down to paint the frame I'll put new ball joints and bushings in it.
Quick question, does anyone use a front sway bar with bags? It seems like it shouldn't be needed with the 8 solenoid setup, but I thought I'd ask.
Old 12-27-2013, 11:30 PM   #138
99 to Life
99 to Life's Avatar
Re: 49 ls1
sarge, looking good. Sway bar, yes those are recommended as well as shocks. but if worst case atleast run shocks. As for the valves, looks like they just plumbed two valves with one fill line. Issue I see with that is slower fill rate (isn't always a bad thing tho) but if you blow a line or lose a valve, both bags are affected. I'd run each bag off of 4 ports on a tank with 8 valves. for the dump valves, not sure if you are familiar with dump controls or not, you can buy them and most of them are adjustable, so you can control how long it takes to air out. or you can use a bolt and drill a small hole in it. they help keep the valve clean too.
Old 12-28-2013, 12:20 AM   #139
oldman3
oldman3's Avatar
Re: 49 ls1
front end is looking good...Jim
Old 12-28-2013, 11:09 AM   #140
skymangs
skymangs's Avatar
Re: 49 ls1
Thanks Jim and 99. I was planning on running shocks front and rear. I guess I'll see how well I can work that sway bar back into the suspension.
Old 12-28-2013, 08:25 PM   #141
vht
Re: 49 ls1
I've got a TCI frt susp, 4 bar rear with no bags. I would like to find frt and rear sway bars to adapt to mine. Keep this build going, love what you've done so far.
vht is offline   Reply With Quote
Old 12-28-2013, 11:06 PM   #142
skymangs
skymangs's Avatar
Re: 49 ls1
Thanks vht. I've done a bunch of research, and have a friend who has air bagged tons of vehicles, so I'm not going in totally blind.
Here's what I got done today. I slip rolled a chunk of 1/8" flat steel (LOTS OF WORK!) to an 8" circle. then took it home, and cut it in half and played with my "cans" till I liked the way they fit into the frame (They double as the "bottom stops" for my suspension travel).
Then my problem was that the bolts and air fittings were inside the frame. bent up some 1/8" to reverse cut it into the frame so I could access the hardware, and welded it in. Once I was happy with the left side, I moved on to the right.
Old 12-28-2013, 11:11 PM   #143
skymangs
skymangs's Avatar
Re: 49 ls1
Here's the left and right sides, all finished up. I have some welding to do on the underside of the frame tomorrow, and then final suspension travel test. I got my Bushed D.O.M. ends for my rear links from the brown truck fellow today, so next week I'll tear my hair out calculating the triangulated 4 link setup!
I also got my 65 Mustang tank on Friday, so that will be part of next weeks thrash as well.
Old 12-28-2013, 11:18 PM   #144
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: 49 ls1
Super nice work on the front suspension man. I really like the plates around the bags as the botton limit. Sweet!
--Josh
Old 12-28-2013, 11:25 PM   #145
skymangs
skymangs's Avatar
Re: 49 ls1
Thanks brother. I've been following your Chassis build as well. That is one hell of an undertaking!
Old 12-29-2013, 12:33 AM   #146
oldman3
oldman3's Avatar
Re: 49 ls1
Chris, very nice work on the front pieces...Jim
Old 12-29-2013, 12:46 AM   #147
STOCKISH
STOCKISH's Avatar
Re: 49 ls1
Thanks, a lot of work but a lot of fun too. Made a ton of progress tonight too!
--Josh
Old 12-29-2013, 10:43 AM   #148
skymangs
skymangs's Avatar
Re: 49 ls1
I'll check it out today Josh. Thanks Jim
Old 12-29-2013, 02:11 PM   #149
99 to Life
99 to Life's Avatar
Re: 49 ls1
looking good, nice progress.
Old 12-29-2013, 02:27 PM   #150
skymangs
skymangs's Avatar
Re: 49 ls1
Thanks 99, you get that dash and T-shirt yet?
