03-16-2014, 10:15 PM | #126 |
Re: Project NiteMare-1970 C10 LWB build
Thought I'd update this thing while I'm havin a beer and starin at it again.. Box all tore apart and stripped of paint. Even had a helper for an afternoon. (what are we gonna do today Dad?) The inner box support rails were rotten. (the part that rests on the wood floor) Dug out the metal brake and bent up some repair pieces.
03-16-2014, 10:21 PM | #127 |
Drilled holes through inner boxside and plug welded repair panels.. as well as stitched along inside of 90 deg. bend. The holes for tail lights/reverse lights were filled... as well as the holes for the stake pockets
03-16-2014, 10:26 PM | #128 |
Those steel flowers I made for wife to keep me from buyin anymore?... Wife voluntold me to make a set for a wedding present for her friend. Just buy them. This knocked a couple days off my truck time..
03-16-2014, 10:26 PM | #129 |
i gotta know what your plan is for the taillites?
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
03-16-2014, 10:31 PM | #130 |
Back to the truck again.. cut a tail bed corner off my parts truck to replace the damaged one I found covered in filler while stripping paint. It was damaged as well on the lower side. So some is replacement... some is fabbed up.
03-16-2014, 10:36 PM | #131 |
Hey zicc.. I've made an LED light bar I'm flush mounting in the rollpan... below the tail gate. 1" x 64" wide made from 4 individual multi LED light bars. Will appear as a continous light bar... full width with park lights on. But using sequencial flasher setup for signals..( inner flashes.. outer flashes.. etc)
03-16-2014, 10:44 PM | #132 |
Had some steel repair to do behind the wheel openings.. the goodmark repair panel I got my hands on fit like absolute crap. What a piece of garbage. Rear indent below tail lights non existent... and 45 deg. bend along the wheel opening not to be found either. I used pieces of it... but it took lots of reworking to make anything of it.. pittiful really..
03-16-2014, 10:52 PM | #133 | |
03-16-2014, 11:14 PM | #134 |
Thanks zicc!..
I won't take it to heart if anyone calls me mentally challenged for this one.. lol The tailgate I'm using was bowed.. like 1.5". There was only one way I could see to really get it straight again... so I split it. Drilled the spot welds.. zip cut along the top.. and split it all apart. After several hours with a hammer, block and a dolly, I think it's useable now. Rust removed/sealed from the inside.. and welded back together. Finished fabbing the cover plate for the reverse handle setup I made |
03-16-2014, 11:19 PM | #135 |
I tack welded the gate skins to cross sills from the truck bed.. after verifying straight/true. This kept everything true as I welded it back together. Just finishing up the bodywork on the gate ... should be spraying some primer in the next day or 2. Box assembly will follow.. and my lightbar/rollpan setup.
03-16-2014, 11:38 PM | #136 |
looking awesome! i still need to strip and fit up my bed. I'm jealous of your heated shop it would make prrojects and running my own weld shop that much easier!
1968 Chevy C10 build - http://67-72chevytrucks.com/vboard/s...d.php?t=546713 Member of tailgate association of manitoba |
03-16-2014, 11:55 PM | #137 |
Thanks..Lol... it'll come brother. I've spent lots of years working on gravel driveways and in unheated barns before I built this one
03-17-2014, 07:17 AM | #138 |
I really enjoy your thread. Your grill looks different, yet slightly familar, more modern, (which usually bothers me,) yet old style. Really like it. I to have been looking for that portion below the taillight where someone has hit mine. I have discovered all the replacements are flat, and dont have the body lines. Why wouldnt they make a proper patch repair? That makes no sense to me? Keep up the good work.
03-17-2014, 09:26 AM | #139 | |
03-17-2014, 09:04 PM | #140 |
bodywork complete.. seam sealer on and just sprayed with hi builds. (filled antennae hole in cowl cover as well)
03-17-2014, 09:24 PM | #141 |
Nice work.
project: "my happy mess" |
03-17-2014, 09:47 PM | #142 |
03-18-2014, 12:38 AM | #143 |
Lookin good!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
03-18-2014, 02:05 AM | #144 |
Your craftsmanship is really impressive. Some of the mods you did such as the skull in the console and the grill are not necessarily something I would do to my car, but you did a hell of a job on all of them. Real nice work.
03-22-2014, 01:35 PM | #145 |
Thanks Charles... I just noticed your reply. Thought I'd add a pic to my thread of one I've completed... And the next one "in waiting".
03-22-2014, 01:37 PM | #146 |
And that's what u get for loading pics from a phone. Lol
03-22-2014, 01:48 PM | #147 |
Maybe a moderator will fix that for me...?
03-24-2014, 05:30 PM | #148 |
Your work is awesome, you a bodyman by trade? Or where did you learn from?
03-31-2014, 10:11 PM | #149 |
Another update... built a wood frame to enable box assembly. The frame rests on a cab cart so I can roll it around. The LED tail light assembly I made is 4 individual lights, fiberglassed to 1" x 60" plate(1/8" thick) 5/16" rod welded to backside for mounting. Some 18g was broke into a channel shape to act as a recessed holder for the light. Holes drilled through it for lightbar mounting bolts.. and end caps fabbed up
03-31-2014, 10:14 PM | #150 |
To make room for the bar assembly within the roll pan.. the license plate area had to be reworked. New holes cut for license plate lights too.
