#126 |
Re: Project 1966 C-10 LSx
Love the gauges. Who makes them?
#127 |
Speedhuts.... they are AWESOME!
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB |
#128 |
Which line provides the backlighting like that? Much better than autometers backlighting.
#129 | |
All lines I believe use the same lighting system. (mine has a seperate lighting transformer and dimmer for the backlighting and then another lighting voltage had to be applied directly just for the needles.) Worth every penny to customize exactly what I wanted (gauge font, color, backlighting color, needle color, trim ring color etc. ![]() ![]()
#130 |
MOAR!
![]() ![]() ![]() ![]() ![]() couple weeks away from engine first fire
#131 |
Looking great! Can't wait to hear/see it fire up. You going to film it for us all?
#132 | |
running fuel and transmission lines this week....probably will be 2 weeks out.
#133 |
More of the same... swapped back to my old hood with the hole in it... I'm going to try to go hood scoop.... finished up fuel lines.... some wiring etc.... so much to do yet.... so little time.
Enjoy.... ![]() ![]() ![]() ![]() ![]()
#134 |
Very nice work. Beginning to reconsider my 'no rear tank' stance....
First start this week? P. ![]() |
#135 | |
Still have to wire up radiator fans, alternator charging line, some relay wiring under the hood, check rear diff, u joints, a final torque on the 'important things' etc etc.
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB Last edited by 66LSx; 07-26-2014 at 02:30 PM. |
#136 |
It continues....
Entropy Radiator installed..... ![]() ![]() ![]() ![]() ![]() ![]()
#137 |
Nice Work
#138 |
AWSOME work. didnt know you were over here too.
Truck: 1972 International Harvester 1210 Engine: Caterpiller 3116 220 HP 630 tq Transmission: Eaton Fuller rt 6610 Axles: Merritor I beam front axle |
#139 |
Yea.... its no 1947 Ford 1.5 ton but.... still fun.
1947 Ford 1.5 ton 1993 GM P-30 chassis Air suspension all 4 corners Custom 1-ton dually designed rear 4 link suspension hydroboosted disc brakes in all 4 corners Cummins 6BT 12 valve 190HP/440ftlb Turbo diesel Eaton Fuller 10-speed Roadranger transmission RT6610
#140 |
yah it looks about done (unlike mined) that will look nice going down the freeway.
#141 |
Got the recirculating coolant overflow tank mounted up behind the grill and finished up plumbing transmission cooler lines tonight. In order to access the coolant overflow yes I'll have to remove the front passenger side coverplate (6 1/2" bolts I think?) Kept everything clean under the hood I thought and looks okay/good from the front. Enjoy
#142 |
Nice work....that's one slick set up you have!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#143 |
Its alive! Videos on the way
#144 |
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB Last edited by 66LSx; 08-09-2014 at 01:10 AM. |
#145 |
#146 |
OMG it sounds fantastic. So excited to hear it fire up. Love how it just purrrrs like something modern, but still has that nice grunt when you rev it.
And I am in love with those gauges. Definitely ordering from those guys when it comes time. Awesome work buddy. |
#147 |
#148 |
great job 66lsx thanks for the videos ......gives me some much needed inspiration.
#149 |
Sounds great. Would appear your tach is off? I thought I saw 6-7k a few times, but the engine sounded more in the 3k range.
#150 | |
Should be only displaying 4 pulses/rev. First drive I didn't bother pre-calibrating it as the ECM for the LS swap only puts out 4 pulses/rev. Its x2 off... but now fixed.
