Old 05-06-2014, 02:47 PM   #126
dman1982
dman1982's Avatar
Re: Finally starting my 5.3 swap!!
Put
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 05-12-2014, 06:52 PM   #127
ivorton74
ivorton74's Avatar
update...got my radiator finally. also have the egr block off kit for the exhaust manifolds, freeze plug for the egr in the intake, lower rad hose, coolant, tranny fluid, silicone coupler for my cai filter and radiator cap. Just need my driveshaft and throttle cable and that's about it.
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
ivorton74 is offline   Reply With Quote
Old 05-12-2014, 07:54 PM   #128
dman1982
dman1982's Avatar
Sounds like your moving along man
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 05-12-2014, 08:33 PM   #129
ivorton74
ivorton74's Avatar
Oh yeah its comin down to the wire
Old 05-12-2014, 08:48 PM   #130
dman1982
dman1982's Avatar
i gotta install some gauges and do a u-joint...then I'm pretty much done with the ls part lol
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 05-12-2014, 10:02 PM   #131
ivorton74
ivorton74's Avatar
feels good doesn't it? I still gotta get the cable x for the speedo but ill get that later on. ill use my gps or my phone app for a speedometer for the time being. I really wish I could get those vhx digital gauges but damn...not that bloody expensive they are....
Old 05-13-2014, 09:54 PM   #132
AGearHead4Life
AGearHead4Life's Avatar
Not sure if you gauge cluster is similar to my 84 but I was able to use a 90 suburban speedo since they're digital. The signal didnt have to be converted or anything. Just ran a wire from my LS harness to it.
AGearHead4Life is offline   Reply With Quote
Old 05-13-2014, 11:01 PM   #133
ivorton74
ivorton74's Avatar
I thought about swapping clusters but I wanted to keep my 100mph speedo. Im also thinking of getting some autometer gauges too.
Old 05-13-2014, 11:14 PM   #134
dman1982
dman1982's Avatar
Yup!!! GPS goes in and out on my phone...here is the gauges I went with
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 05-15-2014, 05:19 PM   #135
ivorton74
ivorton74's Avatar
update...SHE'S ALIVE!!!!...heard her run for the first time today and im just straight up excited. its just a matter of time before shes on the road. the only thing is that sound I hear from the starter(the sounds of metal on metal) is there when the engine is running. my buddy thinks I probably didn't tighten the flywheel properly so we gotta check that out. Also there's a fuel leak from the line running from the pump to the rail...its leaking right at the pump end. and then I lost the fittings for my trans cooler line to go into the radiator. still have a little more work to do but that engine running is a HUGE breakthrough.
heres the video of the motor starting...https://www.youtube.com/watch?v=pZEg...ature=youtu.be
Old 05-15-2014, 07:27 PM   #136
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Haha, and he even says "we need to fix the flywheel" in the video. What method did you use to tighten it? Its annoying, but you really gotta do the "tighten, turn 180, repeat" method. It will take probably 30 minutes with it all in the truck. Take all the plugs out, have your buddy turn the crank with a breaker, you tighten.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-15-2014, 07:51 PM   #137
ivorton74
ivorton74's Avatar
I just tightened em like u tighten a regular bolt...didn't know there is a method to tighten flywheel bolts lol...man that's gonna suck having to take the dang tranny out again...oh well...its a learning process
Old 05-15-2014, 11:29 PM   #138
ls1nova71
ls1nova71's Avatar
Why isn't the fan turning in the video? Looks like it has a belt on it?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-15-2014, 11:36 PM   #139
dman1982
dman1982's Avatar
very good question
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 05-16-2014, 12:22 AM   #140
dayj1
Do you remember what torque converter to flexplate bolts you used? They're something goofy like 17 mm long. If you buy a "standard" 20 mm long bolts at the parts store, they'll bottom out in the hole before they actually tighten down on the flexplate but they're so close it's hard to tell. The result is a flexplate that rattles like crazy. Ask me how I know
dayj1 is offline   Reply With Quote
Old 05-16-2014, 12:40 AM   #141
ivorton74
ivorton74's Avatar
I cant remember what bolts used for the torque converter...hopefully next time i go to the shop we'll get that sorted. The fan wasnt turning because the hose for the tranny cooler line was in the way n i forgot to move it lol
Old 05-16-2014, 12:44 AM   #142
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
lol, I don't mean the "lefty loosey", I mean the order in which the bolts were done. (4l80e's use more flywheel bolts so the process is longer). When you do a rim/tire, you do the "across" or "star" tightening pattern. When you do head bolts, you torque them in pattern...same goes for the flywheel.
Usually, you tighen a bolt, spin the whole mass 180* and tighten the next bolt. Keep going around 180* at a time, until all of them are spec'd. This makes sure the flywheel stays true all the way around, and doesn't get flexed too much to one side.
Old 05-16-2014, 01:36 PM   #143
ivorton74
ivorton74's Avatar
Ohhhh i didnt know that...like i said its a learning process
Old 05-19-2014, 02:21 PM   #144
ivorton74
ivorton74's Avatar
I was watching a video about torque converter bolts and realized something...I forgot to put in the converter to flywheel bolts....I feel like a dumba** now lol
Old 05-27-2014, 08:05 PM   #145
ivorton74
ivorton74's Avatar
Well made some progress today...put the cab bolts back in..just have to tighten the ones by the front bumper. Also put in the converter bolts so now when I start it the metal on metal sound is gone. Should have my driveshaft back in a day or two.
I am stuck on a few things though. First my b&m shifter...I need to change something inside to make it work with the 4l60 but I have no idea what it is. Also how do I hook up the linkage to the transmission?
Second I still figure how to mount the stupid fuse block. The only place I can mount it because the wiring is short is on the inner fender well. What can I use to mount it without messing up the wiring? I have to drill a hole in the firewall to run some wires in. where's the best place to drill without hitting something?
Last thing is my fan shroud wont fit cuz the motor is closer to the rad now. Can I run the clutch fan without a shroud? I figured its not a big deal since both my Datsuns run without em and they have no overheating issues...and they're both in the Caribbean where its way hotter than here.
Old 05-27-2014, 08:27 PM   #146
AGearHead4Life
You can run with no shroud. Just keep an eye on the temperature while driving it around for awhile. Make sure the fan is doing its job, especially at stop light. I ran mine with no shroud for a while until I converted to electric fans.
Old 05-27-2014, 08:40 PM   #147
dman1982
dman1982's Avatar
For your fuse block make a spacer and bolt it to your fender well, then run some loom around the wires so the don't rub against the metal
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 05-27-2014, 10:05 PM   #148
ivorton74
ivorton74's Avatar
ill monitor the temp gauge...maybe I might convert to electric fans eventually. what can I use to make a spacer for the fuse block though?
Old 05-27-2014, 10:49 PM   #149
Root2812
Root2812's Avatar
ivorton, I like your little fusebox/relay combo. did you do your own harness? Where did you pick that up? What do you have for relays?
Thanks for any info you can give. I am just starting to tackle my harness and I feel lost.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 05-27-2014, 11:05 PM   #150
ivorton74
ivorton74's Avatar
My buddy did the harness at his shop...it was the harness that came with the motor...he ordered the blocks and set all that stuff up. I believe those relays are xpress 40 amps...ill have to look again. that harness was too complexed for me to do myself.
