#126 |
Re: How much would you spend
Agreed. If the sending unit is that rusty then the inside of the tank is just as bad.
Replace the tank if you have the money. If not, carry an extra fuel filter with you. Also add a filter before the pump. |
#127 |
I don't have the money right now I'm goin to replace the sending unit and I have a inline filter already under the truck and there's one in the carb
#128 |
Ok guys today I did half a tune up I changed the plugs, coil, PVC valve , bought valve cover gaskets for tomarrow rubber ones felpro , and sprayed the motor down with degreaser and washed it off with water, bagged the carb,dizzy, and altnator so no water got on those
How does the plugs look to you guys ![]() |
#129 |
![]() Join Date: May 2012
man its good to hear that you got it running , and now you can have some fun with it...
#130 |
The plugs look like it is running a little rich - but not too bad. No oil is good.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
#131 |
#132 |
#133 |
Ok guys I'm goin to a junk yard in pa Harry's u pull it very cheap compared here in ct so I was wonder what parts do I need to swap to discs all around and stay 8 lug ? What year trucks am I looking for ,last time I got a 5 lug swap for my mustang it cost me 80 bucks for everything. Spindles, axle shafts calibers,brackets master cylinder. So if I can find a donor truck I'm getting the swap, I think I need spindles lower ball joints calibers for the front and as for the rear I have no idea
#134 |
http://www.wegotused.com/?page_id=13...anyName=harrys if anybody is close to pa check out there price list, it's worth a trip I live 3 hrs away and I'm goin Saturday
#135 |
