Old 12-31-2014, 12:31 PM   #126
Ratpin
Ratpin's Avatar
Re: '65 SWB Patina Build
Originally Posted by w00dst0ck View Post
Spent a few hours cutting the driver door bottom off to put in a patch panel. Fitment was absolute ****, and the replacement lines didn't even match the door.
Pretty frustrating. I'm going to make it work, somehow...
Where did you get your patch panels from?
"It ain't as easy as Chip Foose makes it look"
Ratpin is offline   Reply With Quote
Old 12-31-2014, 04:23 PM   #127
w00dst0ck
w00dst0ck's Avatar
I've bought from various sites, top banana, LMC (mostly), and brothers. Seems to all be the same ****.
The only panels that have even come close to fitting correctly are the outer rockers.
I put the driver door back on today after finishing the lower patch and everything looks good. Lines up well with the outer rocker. Inner rocker isn't tall enough to meet the bottom of the outer rocker, so I will have to add a strip to the bottom from the spare inner rockers I have. Getting close to having the driver side done. Passenger side is worse, but the door is fine.
Scrapped my first valve box and built this one to accommodate 4 valves with a gauge in the middle. Turned out pretty good for piecing it together from scrap 16gauge lol. It's hard to tell in the picture, but it's flat in the center and each side angles towards the dash, slightly angling the valves inward.
w00dst0ck is offline   Reply With Quote
Old 01-01-2015, 11:26 PM   #128
w00dst0ck
w00dst0ck's Avatar
Finally got motivated to finish the driver side tonight. Turned out well. Need to grind a few welds and them seam seal.
Old 01-02-2015, 12:53 AM   #129
joedoh
joedoh's Avatar
I was referring to my air lines. I've read too many horror stories of DOT PTC line blowing up. Plus I'm running a York 210 which will put out a lot of heat.
I have a york 210 and I used a 24" stainless leader hose to a 1/2" check valve to 1/2" DOT plastic line. I dont expect any problems.
Copper is good too but be sure to have a vibration/movement joint in there, copper work hardens in high vibration environments. My buddy ran all copper on his truck air system and it kept breaking at one bend after about 4 months.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 01-02-2015, 02:04 AM   #130
w00dst0ck
w00dst0ck's Avatar
It seems about even on both sides of the DOT vs hard line argument.
I'm a helicopter mechanic/crew chief by trade (two extremely different worlds when it comes to mechanics), I'm quite familiar with vibration fatigue, however vehicle vibration is minor at best. That being said I'm going to put a few loops in the line to be safe.
Planning on running a stainless line to the tank in the back, then hard line everywhere else.
Old 01-02-2015, 02:33 AM   #131
joedoh
joedoh's Avatar
nice, sounds like you have it handled, that stainless will isolate the area of most vibration (the engine to body transition).
I am a master degreed engineer (worked in aerospace design, so I get your comments on different worlds) and have had tens of bagged trucks and cars over 20 odd years, most with electric compressors and the last 4 with EDCs, the only problem I have ever had with DOT line even in texas heat wave heat was when a clamp came loose and rubbed the tire. In fact phil (my copper buddy) had more problems in 8 months with copper than I had in 20 years with DOT plastic. just a data point, synflex is pretty durable.
Old 01-02-2015, 03:33 AM   #132
w00dst0ck
w00dst0ck's Avatar
since the truck is already plumbed mostly in DOT, I might run it all the way up to the cab, then everything under the dash in copper.
I'm changing from 3/8 to 1/4 since I'm running Dloe's valves.
Old 01-02-2015, 03:44 AM   #133
w00dst0ck
w00dst0ck's Avatar
Seems like hydraulic hose is the best of both worlds.
Old 01-02-2015, 04:13 AM   #134
joedoh
joedoh's Avatar
I cant even imagine plumbing/connecting hardlines to the back inside top of the dash. you have my respect! I see lots of fiddling and god-holding-his-tounge-right in your future, but as a helicopter mechanic you probably call that "tuesday".
I on the other hand was loudly crying to my wife earlier tonight that there wasnt an easy way to connect dual needle gauges to the valve set (using little larrys) BEFORE clamping them into their dash holes, it has to be done upside down and dimly.
Old 01-02-2015, 09:49 PM   #135
w00dst0ck
w00dst0ck's Avatar
I'm not sure if the problem is in the outer rocker or if my door skin didn't get perfectly lined back up when we put in the ****ty patch panel.
Regarless, my outer rocker lines up good, but doesn't come out enough to meet the bottom of the door.
Looks like I'm going to have to slice it and pull it out a 1/8 or so to meet the bottom of the door.
Old 01-03-2015, 10:01 AM   #136
Ryguy442
Yup I had to do the same thing on a 67 for my buddy, gotta love after market patches!!
Ryan
Ryguy442 is offline   Reply With Quote
Old 01-04-2015, 04:18 PM   #137
w00dst0ck
w00dst0ck's Avatar
Started on the passenger side this morning.
Old 01-06-2015, 11:00 AM   #138
w00dst0ck
w00dst0ck's Avatar
Picked up a stupid clean '70 last night.
Old 01-06-2015, 03:33 PM   #139
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I'm jealous of that 70! lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 01-06-2015, 06:48 PM   #140
White knuckle Garage
White knuckle Garage's Avatar
were did you get ur motor mounts for ur thrid gen from and are they a complete bolt in
White knuckle Garage is offline   Reply With Quote
Old 01-07-2015, 09:27 AM   #141
Ryguy442
What's the plans on the 70?
Ryan
Old 01-07-2015, 04:16 PM   #142
w00dst0ck
w00dst0ck's Avatar
For the 5.3?
I'm running ECE mounts. You have to drill 2 holes on each side of the crossmember, and you have to remove around 1/8 of the lip of the framerail on each side.
Old 01-07-2015, 04:17 PM   #143
w00dst0ck
w00dst0ck's Avatar
Ryan
It's for sale. Fixing a few things, 3/5 drop on TBSS wheels and then it will be for sale.
Old 02-06-2015, 12:58 AM   #144
w00dst0ck
w00dst0ck's Avatar
Finished the passenger side in a few hours. Much easier the second time around.
Also pic of civic door seals.
Old 02-12-2015, 12:48 AM   #145
w00dst0ck
w00dst0ck's Avatar
Old 02-13-2015, 08:58 PM   #146
w00dst0ck
w00dst0ck's Avatar
Injected fuel system I built using the stock tank. Factory sending unit still mounts in the original location next to it. Just waiting on a new float.
Also finally installed the PSI harness. Very impressed so far. I did have the #1 injector hot wire pull out of the connector, but it might have been my fault. EV6 connectors suck ass.
Old 06-19-2015, 03:14 AM   #147
w00dst0ck
w00dst0ck's Avatar
Haven't touched this thing in forever. Between waiting on the porterbuilt stuff and other projects, it's sat in the corner of the shop for months untouched.
Finally moved it out of the corner, installed the C notch, and set the bed back on to start raising the floor. Getting close!
Not as low as I would have liked, but it looks really good.
4L80E shifter install
Old 06-19-2015, 11:53 PM   #148
rwade
rwade's Avatar
Can you tell me if you have any spacers on your wheels on the rear? I've got the same set I'm planning on using on my 61 SWB. How close is the outside of your tire to your bedside? Yours is logo awesome by the way. You planning on using poverty hubcaps?
Thanks, Wade
rwade is offline   Reply With Quote
Old 06-19-2015, 11:54 PM   #149
rwade
rwade's Avatar
That's looking awesome (lol!).
Wade
Old 06-20-2015, 09:34 AM   #150
w00dst0ck
w00dst0ck's Avatar
Thanks, Wade
No spacers. Put them on my buddies CNC and opened up the centers. Now that I have disc brakes up front they don't sit on the hubs, but I have several sets of these wheels so I plan on swapping the fronts with another set.
No, I don't like how far the poverty hubcaps stick out. I tried to fit some early chevy caps I have but they are too small and where the clips need to be mounted doesn't work.
Probably not going to run anything, I like the look with no caps.
They fit perfect with no spacers, but you won't be able to run your wheel wells in the rear. I ran them without for a while, but now that I'm raising my bed floor a few inches, I'm going to widen mine and solve the issue.
