Old 10-06-2014, 08:57 PM   #126
clinebarger
Re: 700R4 build thread.
Converter TV Valve/Converter Shift Valve.
**NOTE, Valve Bodies manufactured after '88 usually do not have the bore machined, And some are not machined for the Converter Shift Valve, But are Machined for the Converter TV Bushing.**
If your Valve Body Is not machined for BOTH valves Ignore this post!!!!!
Remove Converter TV Bushing, TV Valve & spring, & Converter Shift Valve If equipped.
If the Valve Body has Outer & Inner Aluminum Dummy Plugs, Remove those.
Replace with a TransGo 700-LU Hydraulic Lock-up valve kit.
Read the instructions, DO Not Install Checkball in the TCC Solenoid!!! As much as I like some TransGo stuff, Blocking the TCC solenoid is retarded.
Ground the Black wire of the TCC Solenoid to a Valve Body bolt.
Run the Red wire of the TCC Solenoid to a "Dual Pole" brake switch to kill the Power to the TCC solenoid when the brakes are applied.
This will apply the TCC after 3rd gear under normal driving, And after 4th gear during hard driving. Will unlock with heavy throttle. Works really GOOD!
clinebarger is offline   Reply With Quote
Old 10-07-2014, 08:03 PM   #127
clinebarger
3-4 TV Bushing, TV valve & Shift Valve.
If you have a '88 & up Valve Body, Clean & reinstall Valvetrain.
If your Valve Body is earlier & You want full throttle 3-4 upshifts, Install TransGo 7-4-V. http://www.transgo.com/products.php?...dcountview=Yes
The Late 3-4 TV bushing has a protruding end, The Early Bushing has a flat end.
And of coarse install roll-pin through the top of the Valve Body.
Old 10-08-2014, 07:52 PM   #128
clinebarger
2-3 TV Bushing, TV Valve & Shift valve.
Clean & reinstall, If tuning is required later on.....
A Stouter TV Valve spring will render Later 2-3 shifts, Lighter = Earlier 2-3.
The TV Valve & Bushing comes in different Diameters that is matched to the Governor for the original vehicle it came in......
The larger the TV valve, The Later the shift.
Measure the "Face" diameter of the TV Valve that faces the Shift Valve, Record the measurement for Tuning purposes.
This is the reason Shift Kit springs for Shift Valves do not work in "Swap" 700R4's
Again, Install roll-pin through the top of the Valve Body.
Old 10-08-2014, 08:39 PM   #129
clinebarger
1-2 TV/Low Bushing, TV/Low Valve, & 1-2 Shift Valve.
Clean & reinstall, If 1-2 shift is way off, Governor Changes would be next. The 1-2 shift is usually pretty good with a Calibrated Governor.
Roll pin through the top
**Note, Early (Type 1) valve bodies have separate Bushing/Valves for LOW & 1-2 TV...& has 2 versions, PM me if you need info.**
Old 10-08-2014, 08:57 PM   #130
clinebarger
Check your work on the Shift Valves....
Old 10-09-2014, 07:04 PM   #131
clinebarger
Valve Body Checkball locations, Use TransJel to stick the Checkballs to the Valve Body....Just enough to do the job!
Old 10-09-2014, 08:47 PM   #132
clinebarger
Time to Install the Valve Body.
Install the Manual Link Rod as shown in the picture below.
Hand tighten the 1-2 Accumulator Housing & Auxiliary Valve body bolts.
Remove the Z-Bolt alignment stud that is closest to the shifter Comb.....It gets in the way of installing the Valve Body.
You may need help holding the Valve Body over the Case to start the Manual Link Rod into the Manual Shift Valve.
Center the Valve Body over the remaining Z-Hole alignment Stud, Slowly lower the Valve Body onto the Separator Plate Gasket.
**NOTE, Before sitting the Valve Body all the way down...Make Sure no Checkball has fallen onto the Separator Plate, You can usually hear them drop, But still check**
Start the Z-Hole Valve Body Bolt First!
Install the Forward Accumulator Feed Pipe if equipped.
Start the rest of the Valve Body bolts, Be aware of the Brackets & Hold down locations in the Pic below.
I do the TV Actuator Assembly last along with removing the other Alignment stud
Old 10-09-2014, 09:11 PM   #133
clinebarger
Torque ALL Valve Body Bolts, 1-2 Accm., & Aux. Valve Body Bolt to 8 Foot Pounds (96 Inch Pounds), A Inch Pound torque wrench is best, Foot Pound are not very accurate in the lower scales.
Tighten in Sequence!!!
Install Manual Detent Spring, Torque the bolt to 18 foot pounds.
Old 10-10-2014, 08:56 PM   #134
clinebarger
Lock-Up wiring.....WITHOUT CONVERTER SHIFT VALVE in the Valve Body!!
The easiest solution is to stack Lock-up on top of the 3-4 Shift with the 4th gear pressure. You will need a N.O. (Normally open) pressure switch installed in the 4th gear oil port in the Valve Body, The Switch you see in the above pictures is where the Switch goes.
Bowler has a "Time Delay" TCC module that works very well in Swaps. A Vendor here is selling them at a good price http://67-72chevytrucks.com/vboard/s...d.php?t=611898
Comes with a New harness, 4th gear switch & Dual Pole brake switch, Keep that in mind when you perceive the price to be high.
Old 10-10-2014, 09:19 PM   #135
clinebarger
Install the transmission Filter, SPX Filtran is highly recommended, Delco Filters are Filtran.
Install Trans Pan Gasket & Trans Pan. Cork & Rubber gaskets LEAK!!
OEM Gasket, AC-Delco part# 8654799.
The Bowler TCC kit comes with a OEM style Gasket.
Clean & Place Magnet in Trans Pan.
•Tighten the bolts alternately and evenly to 8 Foot Pounds (96 Inch Pounds).
Old 10-10-2014, 10:14 PM   #136
clinebarger
Extension Housing/Tail Housing.
Speedometer gear selection. http://www.transmissioncenter.net/sp...__va.htm#700r4
Install Speedo Drive gear on Output Shaft If replacing. Note the Color you have when searching for Driven Gears & Housings.
Replace Bushing, AC-Delco 24241501 Teflon coated Bushing.
Aftermarket Brass are OK to use.
Stay away from the Aluminum ones!!
Install Output Seal, Coat the outside diameter of the seal with Loctite.
Install Tail Housing to Case seal on the Housing. It is "square cut" be sure it's not "rolled"
Install Tail Housing, Torque the Four Bolts to 25 Foot Pounds.
Install Speedo Driven Gear & Housing.
Old 10-11-2014, 08:18 PM   #137
clinebarger
Governor.
Let me start out by saying.....Stock V8 700R4 Governors are calibrated to hit "High Gear" as soon as possible for MPG & Emissions reasons, Corvette & F-body Light Weight Governors being the exception.
But they have there drawbacks as well like "Floating the Valves" on a WOT 1-2 shift on certain engines.
I have found that using TH350 Governors are a good compromise, New NOS ones can be found on E-Bay.
TCI & B&M sell Governor Calibration kits, If you wish to go that route.
**Tuning with TransGo Governor Springs**
These are Combinations I find to work well.
Earliest Shift to Latest Shift....
Red & Yellow
Blue & Yellow
Red & Green
Red & Black
Blue & Green
Red & White
Blue & Black
Blue & White
Yellow & Green
Yellow & Black
Yellow & White
Green & White
Yellow & No Spring
The Green Governor spring comes in TH350 shift kits, It is modeled after a Stock Green TH350 spring.
Inspect Governor Gear for wear.
Make sure the Governor Valve has free movement, Hold the Weights closed & shake the Governor, The Valve movement should be audible.
Insert Governor in it's bore.
Install the square cut Cover seal on the Governor Cover.
Install Governor Cover, Do Not Use Silicone, That seems to be a thing for people to do....It's not needed.
Old 10-12-2014, 07:16 PM   #138
clinebarger
TV Cable Seal Installs in the Case First! Then the Cable Housing.
Install Dipstick Seal into Case.
Double check that the Turbine Shaft Seal is in place, Lube it with some TransJel before installing the Converter.
A Dry 700R4 with a Stock Diameter Converter takes 12 Quarts of ATF, Pour 7 quarts in, Start the engine, Then pour the rest.
That is pretty much it. You can post Questions &/or Comments now.
Old 10-30-2014, 11:38 PM   #139
RANZTRANZ
Ensure you state the external vacuum switch everyone wants to use is no longer required when you use the Transgo Lock up kit....I knew you would like the results of this....no more electrical requirements on a 700R4 swap.....been doing this for years....
RANZTRANZ is offline   Reply With Quote
Old 10-31-2014, 08:13 PM   #140
clinebarger
OK, Yes...Vacuum switches are terrible & should not be used.
I think it is important to kill power to the TCC solenoid when braking. Even when using the 700-LU or the stock Converter Shift/TV Line-up.
Old 10-31-2014, 10:26 PM   #141
RANZTRANZ
Play nice or don't play at all. Insults will not be tolerated.
Old 10-31-2014, 10:52 PM   #142
cableguy0
I didn't make this a sticky so it could become a pissing match. This thread will be extremely helpful to people DON'T RUIN IT. Im not going to take sides but from the hundreds of people that Clinebarger has helped he obviously knows what he is talking about. Either hes the best google searcher on the face of the planet or he knows what hes talking about. Anymore nonsense and I will edit this post.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-31-2014, 11:09 PM   #143
clinebarger
Edited to remove quotes from inflammatory posts.
Old 11-18-2014, 12:41 PM   #144
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
great info havent gone thru it all yet. really helpful
thanks clinebarger
Sick5 is offline   Reply With Quote
Old 01-11-2015, 09:03 PM   #145
OrangeCrush1970
OrangeCrush1970's Avatar
Thank you in advance for taking the time to break this down for us!
I just toasted 3rd and 4th in my 700r4 after putting it behind a built 410 big block. It had around 25k miles on it behind a mild 350...built by a transmission shop that I will not name in Cumming, GA. They claimed it would handle 500ft lbs of tq. I think my engine is on the low end of 400 ft lbs...
After reading through this twice, I think I will tackle the rebuild. I will have many questions when I get this started.
Rottenwood Garage
1970...71...72 C1500 aka Orange aka Sideshow Bob
540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600
2 Tons of Fun
OrangeCrush1970 is offline   Reply With Quote
Old 01-19-2015, 12:23 PM   #146
BADAZ chevy guy
BADAZ chevy guy's Avatar
So, I just finished reading this whole thread again. I have all the parts I need for the 700R4 and I'm going to tear into it this next Saturday. Wish me luck and I'll keep you all posted as I work on it.
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline   Reply With Quote
Old 02-10-2015, 12:49 PM   #147
BADAZ chevy guy
Had my first scare this last weekend. Washing down the case and valve body at the local spray wash. I picked up the valve body and the manual valve slipped out and fell through the grate into the sump. 1/2 hour later, and smelling like a swamp monster, I found it with a magnet. fyi... Take that valve out before you do much work on the valve body there's nothing holding it in until the valve body is bolted to the case.
Old 02-15-2015, 01:45 AM   #148
mechanicalman
Originally Posted by BADAZ chevy guy View Post
I'm starting a new build thread for my 1993, 700R4. I've never built a transmission before, but Clinebarger has been gracious enough to offer his help and advice through this. I'll try to keep a photo record as I do this and post them here.
Wish me luck.
Sub'd.
mechanicalman is offline   Reply With Quote
Old 05-30-2015, 07:15 PM   #149
clinebarger
This is for GMCdeadhead, But figured it can help others with a similar problem.
His 700R4 is locking on top of 2nd gear, This is usually because the TCC solenoid is getting power & ground at all times, The Converter apply valve gets its oil from 2nd gear oil.....That is why it will lock in second & stay locked up 'til the trans downshifts to 1st gear (2nd gear oil is present in 2nd, 3rd & 4th)
He has a 2 pole 4th gear pressure switch, Here are some diagrams on how to wire it correctly.
Old 06-19-2015, 03:42 PM   #150
70's luvr
So looking at my trans do I need to change any of the wiring to use a TC lockup switch? 1986 700r4
Thanks!
70's luvr is offline   Reply With Quote
