Old 03-20-2015, 04:55 PM   #126
rusty76
rusty76's Avatar
Re: 1977 K10 Silverado Longbox
I used to love going to the junkyards before you had to sign in and in some cases pay. Was a lot more fun with older cars too......
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 03-23-2015, 02:05 PM   #127
77K10Silverado
77K10Silverado's Avatar
Got the carb on yesterday. No more gas smell is the first con. Currently determining gas mileage so i'll report back with that. I still need to do a little tuning.
First pic is old carb coming off, 2nd and 3rd is all buttoned up.
Mike B.
77 K10 - http://67-72chevytrucks.com/vboard/s...=1#post6752641
77K10Silverado is offline   Reply With Quote
Old 03-23-2015, 05:38 PM   #128
rusty76
rusty76's Avatar
Air cleaner looks good.
My build thread
Crossmembers CC
Old 03-26-2015, 10:19 AM   #129
77K10Silverado
Scored a new instrument bezel off the classifieds here. Clear glossed it and slapped it on. not NOS but a great driver improvement over my faded one which is now for sale!
Mike B.
Old 03-26-2015, 05:32 PM   #130
mingoman
Absolutely love your truck. Everything is looking great.
76/77/78 Cheyenne
1997 K3500 454 soon to be 496
mingoman is offline   Reply With Quote
Old 03-26-2015, 08:52 PM   #131
rusty76
rusty76's Avatar
That looks really good. I really like the wood grain look personally.
My build thread
Crossmembers CC
Old 04-24-2015, 10:29 AM   #132
77K10Silverado
OK! Back to it. Was on a short break for how do I say.. choosing my battles
Finally got the ol' girl to fit in the garage to beat the heat this summer. I have a nasty oil leak that is my current mission to stop. I went ahead and dropped the front drive shaft. I'll clean paint and re-u-joint it. Also drained all fluids and will drop the tranny and oil pans to re gasket. I also plan to replace the crapped out t-case mounts with poly.
Mike B.
Old 04-24-2015, 04:09 PM   #133
ECU PIRATE
ECU PIRATE's Avatar
Nice build. Makes me wish I would have went ahead and built up a little 4wd play toy on the 77' K10 short bed frame I had. If you are ever in the Eastern part of the state around Edenton, you need to look in a my buddy AJ's Uncle Hoghead. He had about (6-8) round eyes in his personal junk yard behind his shop. He builds all of the motors in that area as well.
The Fleet........
68' Camaro - 1st car (restored & still have it)
09' VW Tiguan (Wife's Daily Driver)
14' VW Passat SE TSI (my personal)
14' Ford Edge Sport (Daily Work Vehicle)
73' SWB Stepside - 77K org. miles
74' LWB 454/TH400 - drive train transplant for my (Sold)
98' SWB C1500 W/T - shop truck (Sold)
90' GMC Sierra SLE short step - aka " Jezabelle " (Sold)
ECU PIRATE is offline   Reply With Quote
Old 04-24-2015, 07:28 PM   #134
rusty76
rusty76's Avatar
She's a tight fit in there isn't she....geez. Don't worry mine would be a tight fit as well.....And mines a short wheelbase...lol.
My build thread
Crossmembers CC
Old 04-27-2015, 09:01 AM   #135
77K10Silverado
Ok some more pics.
So there are letters stamped into the block. Was this done at the factory or or could this only have been done by a rebuild. I strongly believe it was never pulled and opened but not sure about the stampings.
Mike B.
Old 04-27-2015, 09:05 AM   #136
77K10Silverado
Pulled the oil pump off and it was filled with plastic bits. Either the pump shaft sleeve came apart or the gear on the cam is failing.. Either way I cleaned out the pump and soaked it in carb cleaner. It will go back in for now and be replaced when I do the engine rebuild next year.
Mike B.
Old 04-27-2015, 10:13 AM   #137
enaberif
Those ittty bits are your cam gears failing. Going to want to swap that very soon.
enaberif is offline   Reply With Quote
Old 04-27-2015, 10:44 AM   #138
crashz
crashz's Avatar
The cam gear is steel and the driven gear on the distributor is plastic right? If the plastic gear fails completely, you lose oil pressure, but the distributor stops too, so you would loose power immediately (ie engine shuts down) as soon as the gear fails, and therefore there is no danger of running without oil pressure.
But that looks like an awful lot of plastic for that one tiny gear. Must be holding on by a thread.
Sorry to hear about the battle. In one myself, and losing. Likely leading me to a divorce now.
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB
1987 GMC V3500 Dump, 6.2L diesel, TH400
1983 GMC K2500 - awaiting its restoration and Cummins swap.
crashz is offline   Reply With Quote
Old 04-27-2015, 12:16 PM   #139
Matt Man
Matt Man's Avatar
I just put a new motor in mine, 35 pounds of compression on 2 cylinders I got a GM GoodWrench 350 for 1509$ shipped to my door from Summit. Good deal for a daily driver motor
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 04-27-2015, 08:31 PM   #140
y5mgisi
Second Chance Program
y5mgisi's Avatar
This is a factory timing chain setup. The cam gear is lined with plastic. Supposed to make them quieter or something. And crashz, that is the only bit of plastic in the timing system. Both the distributor drive on the cam, and distributor gear are metal.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 04-27-2015, 09:10 PM   #141
enaberif
You are partially right. Stock most distributor pump bushings are plastic not metal. Usually when a person works on a motor if they do some research they will find its a good idea to upgrade to the heavy duty style with the metal bushing.
When I took my engine apart both my cam gear nylon parts were obliterated and the oil pump bushing crubmled.
Old 04-29-2015, 12:44 AM   #142
77K10Silverado
Thanks for the info dudes. Anyone know about the stamping in the block and rods?
Mike B.
Old 05-01-2015, 07:12 PM   #143
rusty76
rusty76's Avatar
Years ago the timing gear cam gear broke apart on my 400. The were the plastic like gears. I replaced the timing gears and chain with steel and never looked back.
My build thread
Crossmembers CC
Old 05-05-2015, 02:31 PM   #144
77K10Silverado
I made a phone call to the PO and he enlightened me that the timing gear had been replaced.. Probably due to the plastic one failing. That being said, i feel good to run the motor for another year to keep on my financial schedule and that the tid-bits were never scooped out when it did fail. #NEXT
Here are some pics on the pump after the dip and a new radio/tape deck I scored at the yard for $20.00
Mike B.
Old 05-05-2015, 02:32 PM   #145
77K10Silverado
Mike B.
Old 05-05-2015, 02:34 PM   #146
enaberif
Are you going to do the rear main seal since your in as far as you are now? Only takes another 5 minutes.
Old 05-05-2015, 03:59 PM   #147
77K10Silverado
Enaberif, I guess so.. I'm not sure how to do it. I guess You Tube will show me.
Mike B.
Old 05-05-2015, 04:11 PM   #148
enaberif
As long as you don't have a 1 piece rear main you undo 2 bolts for the bearing cap and one bolt for the oil pump drive.
Rear seals just slide out and back in.
Old 05-05-2015, 04:12 PM   #149
77K10Silverado
Gotcha. Anyone have a good pic of what i'm looking for?
Mike B.
Old 05-05-2015, 04:21 PM   #150
77K10Silverado
So heres mine and i think these are the bolts to drop?
Mike B.
