Old 09-06-2018, 09:11 PM   #126
nlped
nlped's Avatar
Re: Walter DeWayne...Walt for short
I got the extra SWB frame into the shop and started getting ready for the PB Dropmembers and such. I’ll be putting the Bbc in this frame & then slap Walters sexy body onto it.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-09-2018, 06:33 PM   #127
nlped
nlped's Avatar
Had a chance this afternoon to work on getting some of the PBFab stuff bolted up. Front was pretty easy, but the rear is quite a bit more labor intensive. I only got one notch fitted and was officially whipped. I’ll work on it some more this week after work.
Carter
Old 09-09-2018, 08:04 PM   #128
nlped
nlped's Avatar
Bahhhh... I went ahead and fit the other notch (I was already filthy as hell & I didn’t want to make another huge mess grinding the frame to fit the notch) and started drilling 7/16” holes.
Carter
Old 09-09-2018, 08:07 PM   #129
nlped
nlped's Avatar
I’ll blow it all back apart once I’ve done a complete assembly with fitment and such. Then I’ll paint and/or powdercoat everything.
Carter
Old 09-10-2018, 09:20 AM   #130
knomadd
knomadd's Avatar
Nice progress. You probably made the right choice getting out there and doing the other side while you were already filthy. I've had to make myself work a full day in the garage so I don't have to make a mess multiple times too. It can be exhausting, but it's worth it in the end.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 09-10-2018, 12:26 PM   #131
nlped
nlped's Avatar
Yep Duane, you are absolutely correct, I wasn’t about to create another mess like that. I will admit that I didn’t clean it up last night, but it’ll get cleaned up tonight after I drill the remaining 11 holes for the notches.
Carter
Old 09-11-2018, 08:06 PM   #132
slowcpe
slowcpe's Avatar
Nice progress. There are times I wish I would done the mild notch instead of the c-notch.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 09-12-2018, 08:36 PM   #133
nlped
nlped's Avatar
Yeah, I didn’t wanna lay frame. I just wanted it to sit down low when I’m riding. I’m doing a mild front dropmember too.
Carter
Old 09-12-2018, 08:48 PM   #134
nlped
nlped's Avatar
So I could have a break from drilling and whammin’, I decided to check out the main & rod bearings in the 468 and found bad news. Whoever installed the tranny the last time apparently didn’t do it properly and had the crankshaft “pushed” forward in the motor. It destroyed the thrust plate and chewed up the bearings a little. I got lucky and found a good, freshly machined .010/.010 454 crankshaft for a decent price today. So, I’ll get some new bearings, clean clean clean & reassemble everything.
Carter
Old 09-12-2018, 10:00 PM   #135
Advanced Design
Advanced Design's Avatar
While a bummer, it is good you checked!
Advanced Design is offline   Reply With Quote
Old 09-12-2018, 10:22 PM   #136
nlped
nlped's Avatar
Yes Doug, it certainly is. That woulda been a seriously catastrophic failure.
Carter
Old 09-15-2018, 12:42 AM   #137
nlped
nlped's Avatar
Spent this evening drilling holes and fitting some more. Good LORD!, that was a lot of drilling! And I’d already taken this frame completely apart, so all the body rivets are already gone. Nothings tight except the rear notch. I am going to use a wide (‘70-1/2-‘72) rearend, so I blasted the case, but I have to build it out, so I can put it at ride height and then set the pinion angle and weld on the rear lower bag mount.
So tomorrow I’ll work on “reconstructing” the 468 so I can place it and the 700r4 in to get all my angles set.
Carter
Old 09-15-2018, 10:05 PM   #138
nlped
nlped's Avatar
So I got the new bearings and such for the 468 last night. I spent a few hours this evening getting the crank into the motor and checking the clearances of the bearings. Got that buttoned up and “sealed” the motor, so I can scrub the block and paint it tomorrow. Then I’ll finally get it all back together. Then back on the porterbuilt chassis.
Carter
Old 09-16-2018, 09:10 PM   #139
nlped
nlped's Avatar
Got the bottom end all assembled and buttoned up and started cleaning up the accessories, Intake manifold, and valve covers so I can paint and such. Not a lot to “see”, but a pic to prove it.
Carter
Old 09-17-2018, 07:44 PM   #140
nlped
nlped's Avatar
Nothing really picture worthy, but I got the alternator taken apart, sand blasted the case & painted it (& reassembled with the serpentine fan & pulley). Also got the balancer and p/s pump cleaned up and ready to paint. I got the wrong pulley for the p/s serpentine pulley and called to get the correct one on the way.
Also ordered the posi, 3.42’s and bearings for the rearend. Gotta get it put together so I can weld on the bag mounts.
Carter
Old 09-20-2018, 09:19 PM   #141
nlped
nlped's Avatar
Still nothing picture worthy, but I’m moving forward. I got the water pump paints & installed. Still waiting on the p/s pulley and the correct timing marker (the aluminum timing cover isn’t very user friendly related to timing marker).
Carter
Old 09-22-2018, 09:16 PM   #142
68bowtie
68bowtie's Avatar
Nice progress. That serpentine setup will look great.
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
Old 09-23-2018, 06:14 PM   #143
nlped
nlped's Avatar
Thanks! I love your camper build! Wish mine didn’t have the huge hole for the walkthrough.
I fiddled with the serpentine setup some more, but I’m still waiting on the tool to install the harmonic balancer.
Carter
Old 09-24-2018, 10:24 PM   #144
Advanced Design
Good progress...and those brackets look pretty sweet!
Old 09-27-2018, 06:26 PM   #145
nlped
nlped's Avatar
Finally got the harmonic balancer installed, so I could finalize the serpentine belt setup. I think it’ll look way better than v-belts and I can’t imagine an 8-rib belt slipping on this application.
Carter
Old 09-29-2018, 06:51 PM   #146
nlped
nlped's Avatar
Because I haven’t had much free time, I got a little bit more done on the motor. I’m waiting on some parts for the 700r4, so I’m going back to the chassis tomorrow.
Carter
Old 10-01-2018, 05:35 PM   #147
nlped
nlped's Avatar
I spent the better part of the day working on fitting the rear bumper I bought from forum member GR8-68 a while back and fitting/ modifying the home built hidden hitch. I also had to move the PB rear crossmember back about 2-1/2” so I could fit the Boyd EFI tank between the rear one & the one at the notch. That bought me about 24 7/16” holes to drill, between the hitch, the crossmember relocation and such. I’m getting tired of drillin’ holes!
Carter
Old 10-04-2018, 10:37 PM   #148
boonedogs72
boonedogs72's Avatar
Looks great! Glad to see those parts I sold you getting put to use!!
boonedogs72 is offline   Reply With Quote
Old 10-05-2018, 11:08 AM   #149
nlped
nlped's Avatar
Thanks man! I sold a bunch of them, but I kept the best ones
Carter
Old 10-07-2018, 05:15 PM   #150
nlped
nlped's Avatar
Finished assembling the motor, got the trans cleaned up & painted, new filter, pan, seals etc. dropped the motor in the frame to check some clearances and such. Without help, I don’t want to ruin my back, so I’ll have to wait for help to install the tranny.
Anybody with a mild dropmember and BBC able to point me in the right direction as far as headers that’ll work?
Carter
