Old 10-08-2014, 10:37 AM   #126
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: jimbosprint 1972 C20 - the good, the bad, and the ugly
I have the same motor in my burb and do not run the heat shields and the wires have
25k miles on them and they are perfectly fine.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 10-08-2014, 03:16 PM   #127
knomadd
knomadd's Avatar
I don't know for certain, so maybe it's not correct, but it looks like you have the boss for the hole to be drilled in the block. Couldn't the machine shop drill and tap the hole for you, if they don't have the heat shields that can work with the combo as-is?
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 10-08-2014, 04:20 PM   #128
no1udknow
no1udknow's Avatar
Originally Posted by Xeen View Post
Honestly the metallurgy in the new crate motor is so much better than the old 60's-70's small blocks it's not even funny, you have the better deal with what you have you just need to figure out a solution and trust me it's out there.
You will burn up your spark plug wires very quickly unless you shield and route them properly then you will definitely be unhappy, don't give up so easily.
The local machine shop will know in 2 seconds what heat shields you need with that block/exhaust manifold combination so load up the engine and take it down there, they will probably even have them in stock and sell them to you.
Burn up the wires??? Jimbo, I can't remember an engine that I have had that ever burnt up wires without heat shields. Yes, most of them had headers, but even ones with the OG mani's and no heat shield never burnt up wires. But as far as the heat sbield mount goes, are you afraid to drill and tap it yourself? You may need a special tap to work with the hardness of that block, but you can take a dial caliper and measure the depth of the holes on the old one, and then mark it out on your drill bit so you dont go too deep, then just use a corded variable speed drill, go slow, and use lots of cutting oil. You could do it man, I have faith. Then when you are running the tap, you go 3/4 turn forward, then 1/4 back to remove debris, and keep spraying the cutting oil. Youll be done in no time.
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 10-08-2014, 04:54 PM   #129
Xeen
Xeen's Avatar
I'm not talking about burning up the wires with radiating heat I'm talking about the wires touching the exhaust manifolds and burning up, it has happened to me before.
If the wires are properly separated and routed you won't have that problem though.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 10-08-2014, 06:44 PM   #130
boostedc10
boostedc10's Avatar
Jimbo worse case if you don't want to drill and tap it, cut the tab off at the bottom weld a small piece to it to make the 90 and use the hole next to it. No1 is right though, if you take your time you can drill and tap it with very little risk.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 10-08-2014, 08:08 PM   #131
jimbosprint
jimbosprint's Avatar
What heat shields?
Engine is in the truck!
jimbosprint is offline   Reply With Quote
Old 10-08-2014, 08:35 PM   #132
Saclandman
Saclandman's Avatar
Originally Posted by jimbosprint View Post
What heat shields?
Lookin' good in there. Light the fires!
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline   Reply With Quote
Old 10-08-2014, 08:39 PM   #133
boostedc10
boostedc10's Avatar
What heat shields?
Lol, problem solved!
Brandon
Instagram: DRVFSTR
Old 10-08-2014, 10:28 PM   #134
jimbosprint
Here it was mocked up on the engine stand.
Old 10-08-2014, 10:40 PM   #135
no1udknow
no1udknow's Avatar
Just run straight lead plug wires an you will be fine, if you run the 90° ones, they might get melted.
Built not bought!
Old 10-08-2014, 10:41 PM   #136
jimbosprint
I'm gonna try to run em down the back and under the manifolds like stock.
Old 10-10-2014, 05:08 PM   #137
jimbosprint
So (I hope) everything is hooked up except the transmission kickdown cable. Somehow the Edelbrock "universal" SBC throttle bracket I got is not so universal. I have the stock throttle bracket hooked up temporarily so it will work mostly, but it won't go all the way wide open throttle.
Just need to fill with fluids, prime the oil system, and install the distributor.
Then... first fire!
Old 10-10-2014, 05:11 PM   #138
Saclandman
Saclandman's Avatar
Lookin' sharp in there, Jimbo. Good work.
Rich J.
Old 10-10-2014, 05:18 PM   #139
Xeen
Xeen's Avatar
Nice work, you are almost there.
Edelbrock probably makes a bracket that will work properly with the cable throttle that you have, now you have me curious, I'm gonna look into it.
Edit:
Ok I found some throttle brackets on Ebay using the search term "edelbrock throttle bracket GM 1972 truck" part # 8031 so give that a shot.
The only other thing I found is a GM Transmission Cable Adapter but that is for the 700R4 and similar transmissions.
Edelbrock has the worst part descriptions ever for accessories!
Old 10-10-2014, 06:48 PM   #140
jimbosprint
So I'm pretty sure the radiator leaks. I don't know if it was leaking before. It was full when I bought it. It sat in my yard for most of this time that it was out of the truck, but I did take it up to the transmission shop to have the lines cleaned out.
Old 10-11-2014, 04:18 PM   #141
jimbosprint
Strange. I put a pan under the leak and it appears to have stopped.
Old 10-12-2014, 02:06 PM   #142
jimbosprint
Turned the key, got it to run smooth and the timing set pretty quick. Noticed quite a bit of smoke and shut it off. Would anyone with experience mind if I called to talk about it? PM me your number. Thank you!
Old 10-12-2014, 02:39 PM   #143
swamp rat
swamp rat's Avatar
Rising off the outside of the engine? That could be the exhaust manifold dressing curing.
Out the exhaust? burning the assembly oil off the rings would be my first guess.
You didn't mention the color of the smoke, white would be water, blue is oil and black is too much gas (to rich)
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 10-12-2014, 04:24 PM   #144
jimbosprint
Super short YouTube video
It's breezy out so I noticed it by the engine, and my first reaction was to look for oil leaking near the exhaust. But it was definitely coming out from the tailpipe (and leaky old exhaust). Smoke smelled lightly of oil burning and was white-ish or light blue-ish, but blew away quick due to the wind. Oil pressure gauge showed near "H" while running.
Before startup I ran an oil priming tool for 3-4 minutes while turning it over manually to put oil throughout the engine. Pressure gauge showed oil pressure while priming. I used Red Line engine break-in additive with zinc in the the oil and topped off the level before startup.
Started it up a second time and it didn't smoke right away, but did smoke like the video above within a couple minutes. Smoke increased when engine was revved up (didn't go above 1500).
I just don't know what to expect so I shut it off out of caution, and I don't remember this much smoke at first firing when I put a rebuilt 350 into my Nova 15 years ago. Do I need to rev it up higher to seat the rings? Should I do the 20 minute break in at 2000rpm and just let it billow out?
Old 10-12-2014, 06:17 PM   #145
jimbosprint
Bump.
New somewhat longer video: http://youtu.be/mCncKo0Ch20
Old 10-12-2014, 09:08 PM   #146
Xeen
Xeen's Avatar
Jim maybe the guys in the engine & drivetrain section can provide some answers.
Old 10-13-2014, 07:12 PM   #147
jimbosprint
Just needed to break it in, or it could have been burning off the old exhuast pipes. Smoke stopped after about 10 minutes. I test-drove it around a little (my first time driving it) with a ear to ear grin.
Old 10-13-2014, 07:30 PM   #148
Saclandman
Saclandman's Avatar
Sweet! Drive it on down to Sac, we'll take it for a spin.
Rich J.
Old 10-13-2014, 09:38 PM   #149
Xeen
Xeen's Avatar
HAH I knew it!
I'm glad to hear it Jim, congrats!
Old 10-13-2014, 10:47 PM   #150
jimbosprint
Photo gallery update (285 photos).
1972, c20, deluxe, stock
