Old 11-04-2014, 10:18 AM   #126
reaper71
reaper71's Avatar
Re: "Project Orangepeel" 52 A.D
This pic shows the plate I made for the latch after I cut out the door (sorry did not have pic of cutting section out) because of how the latch is this section of the door moves out 1/2" so I had to build it out..
reaper71 is offline   Reply With Quote
Old 11-04-2014, 10:22 AM   #127
reaper71
reaper71's Avatar
This view shows how it needed to come out.
the reason it comes out is the arm for the hinge where it needs to line up with hole in the door dictates this
Old 11-04-2014, 10:25 AM   #128
reaper71
reaper71's Avatar
Quick shot of the Carriage bolt this will be my button (put in drill and sanded then polished)
Old 11-04-2014, 10:29 AM   #129
reaper71
reaper71's Avatar
These are the components for the buttons..
large bushings,small bushings,flat washers,cone shaped springs and the carriage bolts. (never mind the pins i decided not to go with them)
Old 11-04-2014, 10:43 AM   #130
FarmerSid
FarmerSid's Avatar
Cool! Watching how you are doing your latches.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 11-04-2014, 04:18 PM   #131
RockinKees
RockinKees's Avatar
X2 ^^
Very interesting for me how you make this work.
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 11-04-2014, 08:43 PM   #132
Advanced Design
Advanced Design's Avatar
On my to do list too. Nice work Reaper....now if I can just remember it all.
Advanced Design is offline   Reply With Quote
Old 11-05-2014, 11:07 AM   #133
reaper71
reaper71's Avatar
Farmersid,kees and A.D. thanks so much for the support I'll keep posting if all you guys keep checking in..
Mark..
Old 11-05-2014, 11:16 AM   #134
reaper71
reaper71's Avatar
So how it works is take the washer and drill it out to fit the small bushing then weld. you can see how the cone shaped spring fits over the bushing and will fit under the head of the carriage bolt.
Old 11-05-2014, 11:17 AM   #135
reaper71
reaper71's Avatar
Small bushing welded to the washer..
Old 11-05-2014, 11:20 AM   #136
reaper71
reaper71's Avatar
Now I weld the large bushing and washer together..
Old 11-05-2014, 11:22 AM   #137
reaper71
reaper71's Avatar
Here you can get the idea of what I'm going for.
Old 11-05-2014, 11:25 AM   #138
reaper71
reaper71's Avatar
This is what it looks like together..
the bushing will then be inserted into the door and the carriage bolt AKA the button will be exposed...
Old 11-05-2014, 12:10 PM   #139
RockinKees
RockinKees's Avatar
Nice so far!
And I am sure we'll keep checking in ;-)
Cheers!! Kees.
Kool Guyz CC
Old 11-05-2014, 04:14 PM   #140
reaper71
reaper71's Avatar
Right on brother!!
Old 11-05-2014, 06:22 PM   #141
Advanced Design
Mark..
That's a deal! Now I gotta print these pages and tape them to my doors.
Great next steps.....thanks for sharing.
Old 11-05-2014, 06:37 PM   #142
FarmerSid
FarmerSid's Avatar
Mark..
Keep posting updates man. Always check'in in.
C4 IFS & D44 IRS
5.3 HO L33
Old 11-06-2014, 10:46 AM   #143
reaper71
reaper71's Avatar
Thanks again guys!!!
Old 11-06-2014, 10:48 AM   #144
reaper71
reaper71's Avatar
Just a quick pic of how it looks going together..
Old 11-06-2014, 10:56 AM   #145
reaper71
reaper71's Avatar
In this pic it shows a couple things 1. the nut on the backside of the large bushing is for setting the depth of the button. 2. the flange or plate I welded to the bushing is for mounting it to the inside of the door. the reason I made this is I didn't want to weld anything to the outside of the door..so a hole is drilled for the bushing to go through the plate sets the desired depth for bushing sticking through the hole then the plate is welded to the inner skin of the door (A.D. doors have this for strength around handle)
Old 11-06-2014, 11:00 AM   #146
reaper71
reaper71's Avatar
As you can see in the 1st pic the hole for the bushing and the shape of the plate. In the 2nd pic it shows how it goes in the backside also it reveals the inner skin I was talking about...
Old 11-06-2014, 11:04 AM   #147
reaper71
reaper71's Avatar
This is what the bushing looks like coming through the door. I wanted this sticking out to make a trim ring (this will not be painted body color) once the plate is welded to the inner skin there is NO body work to be done!!!!
Till next time..
Mark...
Old 11-06-2014, 05:27 PM   #148
RockinKees
RockinKees's Avatar
Nice!!
Maybe I missed it, but how is the door locked?
Electrical with a remote?
Cheers!! Kees.
Kool Guyz CC
Old 11-07-2014, 10:01 AM   #149
reaper71
reaper71's Avatar
To answer this question there is no lock at this point.. we dont have to worry about people getting in out cars around here lol..
Originally Posted by RockinKees View Post
Nice!!
Old 11-07-2014, 10:04 AM   #150
reaper71
reaper71's Avatar
Here is a shot of what the button looks like installed on the truck as you can see no weld to clean up and after i blend in the paint around the bushing i will make a nice trim ring..
