Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 05-14-2015, 03:56 PM   #126
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Buried to Bagged 1972 2wd
Rock on, David...
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 05-14-2015, 04:35 PM   #127
Slick67
Sofa King Crazy!!
Slick67's Avatar
Hahaha, thanks Heathro!!!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 05-14-2015, 04:40 PM   #128
Slick67
Sofa King Crazy!!
Slick67's Avatar
Best of Show Car and Best of Show Truck. The last show Slick was in before her demise. I miss her. Shirts will be made with this picture on them for the Fall show this year, think I'll order about 5 of em.
Old 05-19-2015, 09:44 AM   #129
Slick67
Sofa King Crazy!!
Slick67's Avatar
This weekends progress was not too bad. After being concerned that I had not received all of my items from Porterbuilt I looked in every box, including the one that had been moved while the shop was being cleaned....and there it was. Duhhhh. At least I had all the parts needed to finish building the frame and to move on to the brakes. Whew!!
Old 05-19-2015, 10:02 AM   #130
Slick67
Sofa King Crazy!!
Slick67's Avatar
I took a few of the frame because it just looked awesome. The rotors are 14 inch with C5 Corvette calipers.
Old 05-19-2015, 09:23 PM   #131
SOON2BLAZE
SOON2BLAZE's Avatar
Full on badassness going on here!
SOON2BLAZE is offline   Reply With Quote
Old 05-20-2015, 06:17 AM   #132
Chulisohombre
Chulisohombre's Avatar
Looking great.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 05-20-2015, 08:58 AM   #133
Slick67
Sofa King Crazy!!
Slick67's Avatar
I hope so!! I need to do this Blazer justice!
Originally Posted by Chulisohombre View Post
Looking great.
Thank you sir!
Old 05-20-2015, 11:02 AM   #134
smbrouss70
smbrouss70's Avatar
It looks like you were able to keep all of the Blazer body mounts. Is that correct?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 05-20-2015, 12:35 PM   #135
Slick67
Sofa King Crazy!!
Slick67's Avatar
Yep, as far as I can tell it looks that way. The PB rear end kicked the frame rails out a little in the rear but I won't know how much until I do a fitment with the body. When the bar between the c-notches was installed that pulled them in some.
Old 05-20-2015, 02:03 PM   #136
mcbassin
Still Learning
mcbassin's Avatar
Looking real good!
mcbassin is offline   Reply With Quote
Old 05-24-2015, 05:55 PM   #137
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Blazer is looking good.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-27-2015, 01:11 AM   #138
JJ's Sierra Grande
JJ's Sierra Grande's Avatar
what's with the lug nut holes on that rotor? they don't make a chevy 5 bolt pattern?
JJ's Sierra Grande is offline   Reply With Quote
Old 05-27-2015, 01:21 PM   #139
Slick67
Sofa King Crazy!!
Slick67's Avatar
They are chevy, 5 and 6 lug rotors. This is how they came from Pro Performance.
Old 05-27-2015, 01:31 PM   #140
Slick67
Sofa King Crazy!!
Slick67's Avatar
A little update is due! I had a nice Memorial Day, thanks to all our veterans!! Hope you all did as well! I was able to get the front c-notches installed with some changes to the measurements I was provided from PB. I guess the 6.0 DM is situated a little further forward than past versions. After getting the notches in I was able to mount the rack and pinion, which fit well, and decided to mount the old rims and set it on the ground for the first time.
Old 05-27-2015, 02:14 PM   #141
Slick67
Sofa King Crazy!!
Slick67's Avatar
Here are the pics!!!
The PO had torched holes in the frame that allowed it to crack, I cut the stiffener out and patched it and added a hump over that for strength.
The measurements called for 4 1\8 but that wouldn't work with the new 6.0 version DM. Had to move it to 5 1/4 to centerline the notch.
As you can see in this pic, the bright white mark is way too far back so I double measured and put the rack and pinion in diagonally to check clearance. I had to move it up quite a bit!
Welded the notch in on the backside....don't laugh, I had forgotten to turn on the gas.....
Old 05-27-2015, 02:24 PM   #142
Slick67
Sofa King Crazy!!
Slick67's Avatar
I used my new plasma cutter to cut the frame, love that tool!!! Very little grinding to get the notch in.
Since I was having soooo much fun with the welder, I decided to triple weld the notches in on the outside.
Just so I could spend hours having fun grinding it down to make it look nice.
After drilling out the spindle tie rod holes I added the rack and pinion to the DM. Those 15 inch rims didn't leave much room for the 14 inch rotors!!! Had to pull the calipers off so they would fit.....
TOUCHDOWN!!!! I added the rearend to the frame and was able to lay it out on the shop floor!!!!!
Old 05-27-2015, 02:29 PM   #143
Slick67
Sofa King Crazy!!
Slick67's Avatar
Of course I was excited and couldn't get enough pics so here they are for you to check out!!! I'll shut up now, enjoy the pics!!
Old 05-28-2015, 11:21 AM   #144
HSRACER
HSRACER's Avatar
Looking good so far. I am in for the ride!
HSRACER
Slammed 53 5 window
Blown/Bagged 54 Pickup
Patinaed 67 LS stepside
Supercharged 67 Nova
Bagged 69 Suburban Turbo'ed 5.3 LS
HSRACER is offline   Reply With Quote
Old 05-28-2015, 11:42 AM   #145
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
This is looking awesome! I am digging the look of the new DM version 6..
I realize it's mockup phase and all, but just in case you missed it, I think on the Extreme Dropmembers the trailing arms need to be in the lowest mounting position on the cross member..
Keep up the good work..
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 05-28-2015, 04:26 PM   #146
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thanks for following!!!
Thank you!! Still a learning process for me on this one. If you see anything else let me know!!! Definitely follow the build!
Old 05-28-2015, 04:47 PM   #147
mcbassin
Still Learning
mcbassin's Avatar
Awesome progress on the chassis Slick! I'm digging all of it.
Old 05-28-2015, 11:30 PM   #148
Blown06
Blown06's Avatar
Finally layin frame! Looks great, I know you're excited, I'm excited for ya.
I gotta try to swing by next Friday and see it in person.
Me: Jarrod
My project: http://www.67-72chevytrucks.com/vboa...d.php?t=646563
Blown06 is offline   Reply With Quote
Old 06-01-2015, 10:59 AM   #149
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thank you! It sure is nice being able to bolt on a complete custom suspension, fabricating all this would have put me back at least 6 months!!
Layed out for sure!! I am pretty excited about getting to this point! My first frame layin C-10, can't wait to get behind the wheel.......in about a year and a half. Definitely swing by, we'll have the refreshing adult beverages waiting.
Old 06-01-2015, 01:45 PM   #150
Slick67
Sofa King Crazy!!
Slick67's Avatar
A small update for the week, but progress is progress!!! The frame is no longer swiss cheese, got a lot of the holes welded up. Also started to delete the holes in the firewall, it felt good to do something on the body. I do have full covers for the firewall so this is just practice. Slosh Tubz sales smooth firewall panels if you didn't know!! I'm sure Mike Losh would be happy to hook ya up!! (Shameless plug)
