01-02-2016, 07:30 PM | #126 |
Re: Hemi's 70 Blazer build
9 seconds of fun !
https://youtu.be/RJJc1oGZ-Yc |
01-02-2016, 07:54 PM | #127 |
I'm trying....
Woohoo!!!#brrrr
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
01-02-2016, 08:30 PM | #128 |
Very exciting!
01-03-2016, 10:11 PM | #129 |
Cool. Were you sitting on a milk crate.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
01-04-2016, 04:27 PM | #130 |
01-04-2016, 04:35 PM | #131 |
Very nice
01-06-2016, 11:05 PM | #132 |
Today was paint day. I let the high build sit for almost 40 days before blocking it with 500 dry. I put 2 coats of grey sealer, 3 coats of base and 3 coats of clear and will color sand it hopefully this weekend. Turned out pretty good.
01-07-2016, 01:08 AM | #133 |
Nice work Hemi43!!! Looks great!!
01-08-2016, 05:03 PM | #134 |
Thank you !!
I buffed the 1/4s today, and must say it's a bit nerve racking putting a D/A on a freshly painted panel. It's been a few years since I cut and buffed, but after a few minutes my heart rate went down and was able to finish without a hitch. Amazing how well it came up considering I'm using old products on this thing. Believe it or not but the date code on the bottom of the high build urethane primer is 1997 and the clear is 2002. If products are kept in a cool dry place and have been unopened, they should last indefinitely. Some base colors like white don't last too long though. |
01-08-2016, 09:02 PM | #135 |
i need some paint lessons from you!
01-08-2016, 10:59 PM | #136 |
I'm trying....
Looks great Dan! You're in the short rows now.
01-12-2016, 12:45 PM | #137 |
This is the best part of a build, putting new parts on !
I should be painting the rest of the panels but got carried away installing the bling. Putting the 33"on sure changes the look of the truck. Hopefully I'll get the trims rings soon, because they've been on back order for some time. I was also able to put the Peel&Seal down on the floor. Not sure how much noise this will get rid of considering I'll be driving a tent on wheels. |
01-14-2016, 01:36 PM | #138 |
Very nice, tires fill up wheel wells nicely, great work so far
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
01-14-2016, 02:50 PM | #139 |
Dan, truck is looking great. Would love to see a full side shot of it to see the tires and stance next time your in the shop with your camera.
Did you buy new bumpers or refinish ? FYI, I have read a few posts from others who have exhaust straight out the back. They reported getting a lot of suction of fumes back in to the passenger compartment with the top down.
01-15-2016, 01:17 AM | #140 | |
I'll get a side shot when I pull it out of the booth, but I still need to raise the back about an inch to match the height of the reworked front springs. I think I'm also going to move the rear axle back about 3/4" so that it's a bit more centered in the wheel well. |
01-15-2016, 08:12 AM | #141 |
I had a CJ-7 with exhaust out the back and it was a very stinky ride. My 72 has it out the side and is much better. I get more exhaust fumes with the soft top on than off. The tent is noisy! Much nicer with the top off.
01-16-2016, 10:02 AM | #142 |
Almost done painting. Still have the hood and tailgate to do.
01-18-2016, 11:18 PM | #143 |
Awesome build. I was wondering who you got all your patch panels through and also for the rear bed half, I'm assuming it was meant for a truck so was the only modification making the holes for the gas tube? Thanks
Jordan 1972 Chevy K5 Blazer, 6" Lift, 35x13.5R15, 6.0/6L80E/NP205 1982 Chevy C10 SWB, 2006 LS2/4l70e In progress.... http://67-72chevytrucks.com/vboard/s...d.php?t=439860 |
01-24-2016, 08:02 PM | #144 | |
Truck is coming along great and I can see light at the end of the tunnel. I had to machine some lift blocks for the rear to level out the truck after getting the front springs done. I lifted it 1.100" and it's now perfect. This was a good time to move the axle back .625 so that it fits the wheel opening a bit better. It should ride better now with the longer wheelbase ! Now that it's sitting level, I'll check the U-joint angles and will taper the block if need be, then I'll powdercoat them. Panels fit pretty good, but I wished I had more of a gap on the cowl sides. I think I'll have to live with it. |
01-24-2016, 08:52 PM | #145 |
I'm trying....
Strong work Dan.
01-24-2016, 10:41 PM | #146 |
Thanks!! I was looking at your build today to see how well your cowl fit and it looks great. Mine is extremely tight side to side and I won't be able to have the same size gap as the hood. My fenders are bolted on with no shims which is probably one of the reasons, but that's where they need to be in order for them to line up with the doors. I'm crossing my fingers that the hood doesn't give me too many fit issues. I'll find out soon enough.
01-25-2016, 06:44 PM | #147 |
I'm trying....
Our hood gap is obviously the largest of our gaps and thats as tight as we could get it and still clear the cowl on opening. As it was, we still got in the habit of putting a little traction on the hood on opening to ensure no rub. Our gaps were so jacked to begin with, we were pleased with our outcome. We didn't grind any gaps to make them artificially symmetrical (though we talked about it)...just did the best with could with the shapes we had.
01-25-2016, 08:16 PM | #148 |
Been following your build from the start. Amazing craftsmenship!
Question - Did you use repro inner fenders? If so, where did you get them?
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
01-26-2016, 03:13 PM | #149 | |
PITbut
As for the sand marks, thats not necessarily true either. If you use the correct sanding stages the shrinkage you speak of will not happen(or better yet wont be seen) Cant wait for more updates. ** I posted this before i had reached the end of your thread. That thing came out amazing. Using a 19 year or urethane seems a bit sketchy, but holy hell it came out perfect. Do you have a paint code for that tank color you used?****
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. Last edited by lyrikz; 01-26-2016 at 03:26 PM. |
01-27-2016, 09:32 AM | #150 | |
As far as urethane primer, it will always shrink regardless of how well the substrate is sanded. I agree fine sanding scratches probably wouldn't show up, but why take a chance. If it was a daily driver I was painting, I would sand it the next day. The paint code for "Tank" is 2014-2015 NGK(Jeep only). Don't paint a Blazer this color because it's already been done !! |
