06-23-2016, 09:32 AM | #126 |
So there is about a $350 difference between this setup and the fatbar when they are both using Ridetech shocks. What are the advantages of going with this vs your fatbar setup?
Posted via Mobile Device |
06-24-2016, 09:37 AM | #127 | |
Re: No Limit Trailing Arm Rear Suspension
The Fatbar was originally designed for 55-59 Chevs and 53-56 F100s. (sorry for the F word) And, over the years, we tuned on the design to get the best ride and handling we could from a classic truck. It's advantage when compared to the O.E. trailing arm was in Instant Center location/tuning, and the lack of binding during articulation. (we didn't have Monster balls back then) But remember, the Fatbar has parts that MUST be welded to the axle housing. Thus, the install takes a little longer, and requires more tools and skill. In head to head competition, the Fatbar may win out due to it's ability to launch and exit the corner. On the road, the trailing arm may be a little more compliant due to it's longer travel. As for cost, an increase in hardware offsets some addition labor to install. Take your pick, it's a Win-Win.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
06-24-2016, 05:08 PM | #128 |
07-03-2016, 12:59 AM | #129 |
Hey Rob,
Any pictures of the c-notch? |
07-17-2016, 06:14 PM | #130 |
Hey Rob,
Any updates on the c-notch? Thanks |
07-19-2016, 01:20 PM | #131 |
Getting close. matching the bends to fit the OE rail is harder than it looks. We should have formed parts next week. Fixtures and press jigs are ready. - It won't be long.
07-20-2016, 11:13 PM | #132 |
A guy with a truck
Cool stuff here. Any updates/opinions from those who have purchased?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
07-27-2016, 01:16 PM | #133 |
Hey Chris. I purchased and installed the kit with the Ridetech three way adjustable shocks from Rob a couple of months ago. I have a 72 Chevy long bed that is pretty much stock except for the suspension and wheels/tires. I removed the bed for the installation and everything went pretty smooth. Drilling out the stock rivets is the worst part of the job. Everything is great quality, and with a little careful measurement, my truck didn’t require any adjustments in the rear for a perfect four wheel alignment. I haven’t had a chance to put it through the paces on a track, but the ride and handling is amazing. I had to add more clearance to the inside wheel houses to accommodate the 345/19X12 wheels and extra axle articulation for street driving, but the axle tracks the pavement really well and the rear axle hop/oversteer of death is greatly reduced. Rob did a great job!!
07-28-2016, 04:00 PM | #134 |
I tried every method of removing rivets and let me tell you, the $300 you'd spend on a cheap plasma cutter is so worth it -- you can shave the head off a rivet in about 10 seconds and then punch it out.
1968 LWB C20 / AC / Wood Bed |
07-28-2016, 04:40 PM | #135 |
Same thing w/a quality air chisel vs a cheap one. I struggled on rivets w/a new Craftsman unit. Upgraded to a Snap-On . . .... night & day difference.
07-29-2016, 10:55 AM | #136 | ||
A guy with a truck
So true. The HF air chisel will get it done, but you'll be there all day
07-29-2016, 01:19 PM | #137 |
08-10-2016, 11:08 AM | #138 |
A guy with a truck
Any provisions for e-brake cables on the arms?
08-10-2016, 04:35 PM | #139 |
We did not put any cable mounts on the arms fot the OE style cable. Currie and others have bolt-on tabs that can be used. When running Wilwood, or other aftermarket disc set ups, custom cables can be made for you at www.controlcables.com We run the cables through the arm, notice that they are ported on the top/front and side/rear for cable housings.
08-10-2016, 11:43 PM | #140 |
I was hoping to run stock brake drums however the OE e-brake cable runs right into the coilover. So I went with Camaro calipers and CaptainFab brackets. My plan is to use the stock Camaro cables and run them right along the trailing arms like the stock ones. The Camaro cables are strong and well built. I only paid $20 for them at pick-n-pull.
08-10-2016, 11:48 PM | #141 |
08-12-2016, 05:17 PM | #142 | |
A guy with a truck
08-13-2016, 01:43 PM | #143 |
08-15-2016, 03:04 PM | #144 |
Finishing the first run of Notch kits today. Picts up soon.
08-15-2016, 05:20 PM | #145 | |
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) |
08-16-2016, 12:08 PM | #146 |
A guy with a truck
What anti-sway bar works with this kit? Is it just the hotchkis blade style? Looks like your top mount *might* work. Looking forward to notch updates
08-16-2016, 02:06 PM | #147 |
See post #104 he addressed it there and basically says no, since there is welding involved a 4-link would be a better option. You could avoid welding by using a 71/72 rear axle though. I asked him to elaborate on why the trailing arms would be a bad idea in a square but Rob's a busy man so his earlier answer was all he said on the subject.
Your options for trailing arms on a 73-87 are CPP or Porterbuilt, maybe hotrods to hell if they are still around.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
08-21-2016, 11:40 PM | #148 |
2 more days and the c-notch will be here.... Monkey junk
08-25-2016, 04:15 PM | #149 |
Rob, I know you guys install 9 in floaters on your frames and would like to have one on my truck. Is there any chance you could sell the rear end prepped for this trailing arm setup? I'm all about that bolt-in ...
08-27-2016, 01:20 PM | #150 |
We sure do. We can prep both standard 9" big bearing housing/axles. or floaters. Pricing breaks down like this.
9" heavy duty Moser housing with billit Torino (big bearing late model) ends, pinion centered, with fill and drain added + Moser 31 spline axles with access hole, 2 1/2" offset, bearings and seals and 1/2" x 20 studs. Standard C10 width is 63" WMS (wheel mount surface) - can be 62" or 61", no extra charge. With No Limit brackets welded* $1,295.00 9" BBLM brakes 11" Explorer style, drilled/slotted = $590 12.19" x 4 piston Wilwood = $895 13" x 4 piston Wilwood = $1785 9" Moser heavy duty floater housing, fill and drain added. Steel hubs and drive plates, all bearings, seals, retainers, 31 spline axles. Pinion centered, 63" std WMS. - 60" to 62" avail also. No Limit brackets welded = $1395 Floater brakes 11" Speedway style with Wilwood Superlite (no E Brake) $745 12" Wilwood w/E-brake in caliper $895 13" Wilwood with Superlite and Mech spot E-brake caliper $1680 For drilled/slotted rotors on these kits add $90 * Brackets not included, but are part of No Limit suspension packages.
