Old 09-24-2016, 10:10 AM   #126
Gregski
Post Whore
Gregski's Avatar
Re: INNOVATE DLG1 Wideband O2 Oxygen Sensor Tuning Diagnostics Logging Air Fuel Ratio
from what I can regurgitate from what I read, the rating (number) on the Power Valve says at what vacuum (negative pressure in PSI) the valve will open allowing more fuel to leave the fuel bowl and enter the main well
a Power Valve is a helper that says ah snap all this air is about to rush in to the carbie I better do something before those lazy cousins of mine the Main Jets kick in
J - E - T - S (.... what? too soon?) ha ha
so we will try replacing my stock default 6.5 PV with a new 7.5 PV this should shoot some gasoline in the engine 1 PSI sooner so as the vacuum drops from say 19 PSI as I am cruising as soon as it drops below 7.5 now the PV will open, before it wouldn't until it dropped below 6.5
the Power Valive lives in the front metering block (thank god) and can be replaced with the carb on the truck like so
Gregski is offline   Reply With Quote
Old 09-24-2016, 10:17 AM   #127
Gregski
Post Whore
Gregski's Avatar
the Power Valve requires a 1" wrench, naturally the biggest one in my toolbox be a 7/16th so I had to use an adjustable one
be careful, the valve screws into an ALUMINUM block that is very soft metal, so you don't need a cheater bar to loosen or tighten it, ha ha
Old 09-24-2016, 10:19 AM   #128
Gregski
Post Whore
Gregski's Avatar
the balck/gray gasket is horrible and separates in two like an Oreo cookie when you remove the old power valve, so please make sure to clean it off the block, I just used my high tech thumb nail to scrape it off and the bottom of my T shirt to wipe it clean, magic!
Old 09-24-2016, 10:21 AM   #129
Gregski
Post Whore
Gregski's Avatar
new power valve comes with a new gasket (same terrible one) but oh well
Old 09-24-2016, 10:23 AM   #130
Gregski
Post Whore
Gregski's Avatar
and back on the truck it goes, if you are running ported vacuum (black hose to the distributor diaphraghm) then don't forget to connect it back up, as you had to remove it to take the primary metering block out and bring it to your work bench, that vacuum nipple is on the block
Old 09-24-2016, 10:25 AM   #131
Gregski
Post Whore
Gregski's Avatar
the Holley 4150/4160 carburetors are modular so they are fantastic to work on, as you can completely remove a component and not interrupt any of the other pieces, brilliant
the confidence you get from doing even a small job like this feels great, it really builds your knowledge and motivates you to take on other tasks
Old 09-24-2016, 10:27 AM   #132
Gregski
Post Whore
Gregski's Avatar
blah, blah, blah Greg, so did this fix your hesitation problem?
Um, no, no change, lol, but hey Rome wasn't burnt in one day
so just for the heck of it and since I already bought it, we are going to give the 8.5 power valve a shot today (pun intended)
Old 09-24-2016, 01:36 PM   #133
Gregski
Post Whore
Gregski's Avatar
So I tried the 8.5 Power Valve this morning and no change, so I still have a hesitation problem when I step on it and floor it in any gear at any RPM
I doubt it is the Power Valve unless I am supposed to go all the way up to like the 10.5 which I doubt
Old 09-24-2016, 01:43 PM   #134
Gregski
Post Whore
Gregski's Avatar
let me show you graphically what this hesitation looks like
here I am changing from 1st (first spike) to 2nd gear (second spike the tallest one) and then flooring it in 2nd gear until I reach 2500 RPM (purple line) then I let off
what we are interested in is that huge red and green spike (about 13 seconds into the test, bottom axis), those two lines represent the Air Fuel Ratio in the right bank ie Passenger side cylinders/exhaust pipe and the left bank ie the Driver side cylinders/exhaust pipe
see how after I floor it they lean out all the way to 22 parts air to one parts gasoline, way too lean, and we are trying to prevent that
this is difficult because all these things happen in a second or less: as the vcuum decreases to less than 6.5 PSI (black line that goes flat to 0 PSI when WOT) the power valve kicks in, at the same time the secondaries open (they too are vacuum operated) and I don't know at what exact RPM they open yet, also the accelerator pump gives a shot of added fuel, all three in that one second
Old 09-24-2016, 01:47 PM   #135
Gregski
Post Whore
Gregski's Avatar
Next step, put the default / original 6.5 Power Valve back in, essentially returning the carb to its original factory setting
again we like to play with and change one thing at a time
Old 09-24-2016, 01:58 PM   #136
Gregski
Post Whore
Gregski's Avatar
ok so since we got the vacuum secondary springs delivered we will try changing those next
Holley Secondary Diaphragm Spring Kit
Part# 20-13
Old 09-24-2016, 02:00 PM   #137
Gregski
Post Whore
Gregski's Avatar
we also ordered the Holley Quickchange Vacuum Secondary Housing Cover
Cover-Diaphragm Housing 1 x 4 bbl
Part# 20-59
Old 09-25-2016, 11:15 AM   #138
Gregski
Post Whore
Gregski's Avatar
Good Morning, just another day at the office! ha ha
Old 09-25-2016, 11:16 AM   #139
Gregski
Post Whore
Gregski's Avatar
well, so my carb didn't come with the Purple vacuum secondary spring like the spec sheet that did come with it said, ha ha, instead it had the plain spring, like so
Old 09-25-2016, 11:20 AM   #140
Gregski
Post Whore
Gregski's Avatar
Holley recommends a heavier spring for a heavier car, so I figure Rusty (my truck) is 4,000 lbs it aint no Miata so we'll call him heavy and try the Brown spring first
Old 09-25-2016, 11:22 AM   #141
Gregski
Post Whore
Gregski's Avatar
but first we mount that quick change pod
Old 09-25-2016, 11:23 AM   #142
Gregski
Post Whore
Gregski's Avatar
old cap vs new
Old 09-25-2016, 11:24 AM   #143
Gregski
Post Whore
Gregski's Avatar
had to do it off the carb, it was easier that way
this should make swapping springs way easier
Old 09-25-2016, 11:25 AM   #144
Gregski
Post Whore
Gregski's Avatar
carb back together
brown spring in
ready for a test drive
Old 09-25-2016, 12:14 PM   #145
Gregski
Post Whore
Gregski's Avatar
No luck with the stiffer Brown spring, going to go the other way now and try the Purple lighter springer
Old 09-26-2016, 11:54 PM   #146
Gregski
Post Whore
Gregski's Avatar
alright so I tried the Purple lighter spring and holy cow things improved, the hesitation was almost gone but not quite - alright we was on to something here
this defied all logic but what the heck it's what my truck liked
Old 09-26-2016, 11:55 PM   #147
Gregski
Post Whore
Gregski's Avatar
excited about the progress I went one step lighter and tried the tall yellow spring - and the hesitation was gone!
Old 09-26-2016, 11:56 PM   #148
Gregski
Post Whore
Gregski's Avatar
the process calls for us to keep going until things get bad again and so I kept putting in a lighter spring and tried the short yellow one
things got worse - the hesitation returned
Old 09-26-2016, 11:59 PM   #149
Gregski
Post Whore
Gregski's Avatar
so we backed up a step back to the tall yellow spring
test drove it and the hesitation was once again gone
and this is how you do it folks, you change one thing at a time, it takes patience and discipline but that's what tuning is all about, it's taking an engine that is running 90% good and finalizing that last 10% to make it perfect
Old 09-27-2016, 12:04 AM   #150
Gregski
Post Whore
Gregski's Avatar
Alright this left us with a slight hesitation upon blimping it, aka flooring it while in neutral, it would go
vrooo vroooooom, instead of a smooth vrooooooooooooooooooooooom
so it was time to try a bigger accelerator pump nozzle or a different accelerator pump cam, I bought both just in case
my carb came with the .031" and the next size up is the .032" which I thought would not be enough so I bumped it to the next size up the .035"
let me tell you swapping the little nozzle is a major PIA, I had to take the carb off to do i, as those pesky little black washers kept falling on the butterflies, danger danger
the bigger squirter took care of the hesitation while flooring it in neutral and the truck is running BEAUTIFULY!
