Old 02-13-2017, 01:39 AM   #126
MMcMasters
MMcMasters's Avatar
Re: 1970 Med Olive Project
It's a small world...I'll get those pictures to you tomorrow night
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 02-13-2017, 01:47 AM   #127
Jason7121
Jason7121's Avatar
No problem thanks again
Jason7121 is offline   Reply With Quote
Old 02-13-2017, 01:48 AM   #128
MMcMasters
MMcMasters's Avatar
Anytime sir
Mike
Old 02-13-2017, 09:44 PM   #129
Advanced Design
Advanced Design's Avatar
Nice work, looking very good!
Advanced Design is offline   Reply With Quote
Old 02-19-2017, 12:04 AM   #130
MMcMasters
MMcMasters's Avatar
When I was calculating my driveline angles I used washers as spacers to put the carrier bearing where I needed it. I had a local shop machine a spacer to replace the washers.
I also modified my PB crossmember today to allow room for my exhaust.
I hope to have the exhaust finished tomorrow.
Mike
Old 02-19-2017, 12:48 AM   #131
Jason7121
Jason7121's Avatar
Wow nice work love it!
Old 02-19-2017, 10:15 AM   #132
Dustmaker65
Dustmaker65's Avatar
Looks great Mike!
Jimmy Hoelzel
Dustmaker65 is offline   Reply With Quote
Old 02-19-2017, 10:44 AM   #133
Bennett68C10
Bennett68C10's Avatar
Looks good Mike!
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 02-19-2017, 05:11 PM   #134
MMcMasters
MMcMasters's Avatar
Originally Posted by Dustmaker65 View Post
Looks great Mike!
Originally Posted by Bennett68C10 View Post
Looks good Mike!
Thanks guys!
Mike
Old 02-19-2017, 05:22 PM   #135
MMcMasters
MMcMasters's Avatar
I can't leave anything alone. I was looking at the crossmember mod that I did yesterday and started worrying about how heavy the tail shaft of the transmission is. I worried the open gaps would allow the boxed sections to flex. I cut some small pieces of 1/8" and used it for gussets.
Mike
Old 02-19-2017, 06:14 PM   #136
Jason7121
Jason7121's Avatar
Perfection love the work!
Old 02-19-2017, 07:39 PM   #137
kehstr
kehstr's Avatar
Being a gearhead gets annoying sometimes, no matter how good something is we always have to modify it to make it better!
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 02-26-2017, 02:00 AM   #138
MMcMasters
MMcMasters's Avatar
Thanks Jason
I usually modify because I messed it up in the first place
Mike
Old 02-26-2017, 02:24 AM   #139
MMcMasters
MMcMasters's Avatar
I worked on my exhaust again today. It's all tacked together and I'm fairly happy with it, almost...I may lower the mufflers
I want to be able to remove the entire system if the need arises so I flanged the head pipes in front of the H pipe and I'm going to use a band clamp just in front of the trailing arm crossmember. I plan to finish my hangers tomorrow and finish weld everything. Then I'm going to have the entire system ceramic coated.
I'm running out of excuses to not start pulling the green truck apart and prepping it to go onto this chassis
Mike
Old 02-26-2017, 09:12 AM   #140
Bennett68C10
Nice job on the exhaust Mike!
Keith
66 Suburban
IG: bennett68c10
Old 02-26-2017, 09:25 AM   #141
GR8-68
GR8-68's Avatar
I was thinking the same thing when I first seen it Good idea to gusset, I love your build
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 02-26-2017, 03:56 PM   #142
MMcMasters
MMcMasters's Avatar
I finished welded everything from the h pipe forward this morning. The more I looked at how I had the mufflers, the more I didn't like it. I have been thinking how I want to raise my bed floor and where I want to put my air management and I realized the mufflers would be in the way. I simplified it a little and lowered them 4". I think it really cleaned things up and it will be less restrictive. What do you guys think, I'm hoping for some opinions.
Mike
Old 03-04-2017, 08:10 PM   #143
MMcMasters
MMcMasters's Avatar
The never ending exhaust project is almost complete. I pulled everything back off and ran every piece through the media cabinet to prepare it for coating. My initial plan was to send the entire system to Jet-Hot to have it coated but their quote of $900 about made me sick.
I have a buddy on my department who customizes AR-15's and pistols and he uses a product called Cerekote. He told me it is hard as a rock once cured and is good to 2000 degrees. I called Cerekote and told them what I planned to use their product on and they said it would work great for my application. I ordered 1 qt of their graphite black for $132.00.
I spent the better part of 3 hours cleaning, blasting and re-cleaning every piece to prep it for coating. My buddy let me use his booth and he sprayed it all this afternoon.
The tech sheet says it will tack up in 35 mins and partially cure, enough to handle, in 24 hours. It's fully cured and ready for abuse after another 4 days. Only time will tell if it will hold up but it sure does look nice right now. Fingers crossed!!! I will pick it up tomorrow afternoon and get it installed for the final time.
Disassembly on the green truck starts tomorrow too. It's getting real now
Mike
Old 03-04-2017, 09:55 PM   #144
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Awesome detail work on the entire rolling chassis!
Looking forward to seeing the body swap too!
ChuckDriver is offline   Reply With Quote
Old 03-05-2017, 06:11 PM   #145
MMcMasters
MMcMasters's Avatar
What do you guys think of the finished product? My main objective was to be able to remove the whole thing without any cutting. I'm pretty happy with it.
Mike
Old 03-05-2017, 06:16 PM   #146
GR8-68
GR8-68's Avatar
Wow !!! That is one of the nicest looking builds I have seen
Larry
"Project 68"
paypal.me/ldgrant
Old 03-05-2017, 06:21 PM   #147
GR8-68
GR8-68's Avatar
So did the cerekote get sprayed dtm ?
Larry
"Project 68"
paypal.me/ldgrant
Old 03-05-2017, 06:26 PM   #148
Advanced Design
Looks great! Be interesting to see how the product holds up over time.
Old 03-05-2017, 06:28 PM   #149
MMcMasters
MMcMasters's Avatar
Larry,
I degreased everything then prepped the surface with 80 grit glass beed. Everything was then wiped down with wax and grease remover and sprayed with two light coats. They recommend 1mil of coverage. Just made sure the bottle was mixed good and poured directly into the gun with no thinning. It sprayed like **** but flowed out nice once it was on. 30 minute flash time between coats. I let it hang for 24 hours before I touched it. They said it is fully cured 5 days after spraying.
They also have a oven cured product but I didn't have access to an oven large enough so I went this route.
Mike
Old 03-05-2017, 06:30 PM   #150
MMcMasters
MMcMasters's Avatar
[QUOTE=Advanced Design;7877296]Looks great! Be interesting to see how the product holds up over time.[/QUOTE
I hear ya I hope it holds up too!!
They told me if I followed their prep instructions I will get years of service with no discoloration or corrosion. Only time will tell.
Mike
