Old 04-11-2018, 01:38 PM   #126
dieseldude4bt
Re: '66 Budget friendly driver
Maybe not.
I just saw you were in GJ and looked like you worked at the Chevy Dealership.
I droped some off to a guy that worked there, thought it might be you.
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 04-11-2018, 01:55 PM   #127
olrosa
olrosa's Avatar
Originally Posted by dieseldude4bt View Post
Maybe not.
Oh, crap yes! I remember now. Yep thats me
olrosa is offline   Reply With Quote
Old 04-13-2018, 05:09 PM   #128
olrosa
olrosa's Avatar
Check out the videos! Please do me a huge fave and comment on them on the YouTube channel
https://www.youtube.com/watch?v=b9BAjzPo8fE
Old 04-13-2018, 05:11 PM   #129
olrosa
olrosa's Avatar
Video 2
https://www.youtube.com/watch?v=lH64FCP-llM
Video 3
https://www.youtube.com/watch?v=vAM0bzhIYds
Old 04-13-2018, 11:23 PM   #130
CRGRS 66
CRGRS 66's Avatar
Coooool
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 05-16-2018, 06:39 PM   #131
olrosa
olrosa's Avatar
Finally got the 8" wheels painted black. Have to get some wider rubber now too. Also working on getting the dual master cylinder installed.
Old 05-22-2018, 10:02 PM   #132
olrosa
olrosa's Avatar
Finally got to the master cylinder. I had the help of big Willie once again. I didn't have time and he can run brake lines like no other.
Old 05-23-2018, 10:50 AM   #133
made2drag
made2drag's Avatar
Great build! Ive seen those hub caps somewhere but I don't remember what they are off of?
made2drag is offline   Reply With Quote
Old 07-17-2018, 03:01 PM   #134
1lucky1
Any updates,How well do the brakes work without a booster,Can the front be adjusted to get it lower,Thanks Lucky
1lucky1 is offline   Reply With Quote
Old 07-19-2018, 01:29 PM   #135
olrosa
olrosa's Avatar
I'm not sure what they came off of
Yes the brakes work perfectly without the booster. I like the looks as well because I don't have that big ol booster under the hood!
The front could be brought down a little bit, but I don't want it any lower. I don't really have to worry about much sticking up in the road when I'm driving. Everything is working perfectly together. Couldn't be happier with this setup.
Old 09-07-2018, 04:10 PM   #136
Styler1968
Are those the stock steel wheels that came on the truck or are you running something different? Which spindle did they use on the front, the modular or just the regular 2.5” drop? Looks like there was no issue with the brakes clearing those wheels are you running a wheels spacer also?
Styler1968 is offline   Reply With Quote
Old 09-07-2018, 04:43 PM   #137
olrosa
olrosa's Avatar
You need stock 4x4 Blazer wheels to clear the calipers, then no type of spacer is needed. We just used the regular 2.5" drop spindle
Old 09-07-2018, 05:02 PM   #138
Styler1968
So the wheels you had on it when you had the qa1 suspension where from a 4x4 blazer do you recall the year? 15x7? I was gonna order some of the wheel vintiques but I’m not sure what size and backspacing.
Old 09-07-2018, 06:12 PM   #139
350TacoZilla
The plain steel ones remind me of the military blazer wheels (m1009). Good looking truck man and I bet its a fun drive with suspension dialed in.
350TacoZilla is offline   Reply With Quote
Old 09-07-2018, 06:27 PM   #140
olrosa
olrosa's Avatar
Wheel Vintique will know exactly what you want. I think my wheels are from a late 70's early 80's square Blazer
Old 09-07-2018, 06:28 PM   #141
olrosa
olrosa's Avatar
Thank you. It's a blast!
Old 09-07-2018, 11:55 PM   #142
Captainfab
60-66 Nut
I have a set of 4 of the factory 15" x 8" 6 hole wheels for sale in the classifieds.
Old 09-08-2018, 11:05 AM   #143
olrosa
olrosa's Avatar
Old 09-12-2018, 03:52 PM   #144
1enick72
1enick72's Avatar
So, you've said a number of times how well the truck handles with the new suspension, how is the ride? I'm about to assemble my suspension. I have been going back and forth on what to use. I live in Maine where the roads are hilly, curvy and not the smoothest.
65 short step
edited by staff
1enick72 is offline   Reply With Quote
Old 09-13-2018, 11:05 AM   #145
olrosa
olrosa's Avatar
The ride is outstanding as well! And with the adjustable shocks you can tailor the smoothness or stiffness as you like. You won't be disappointed with the setup.
Hope this helps.
Old 09-13-2018, 01:13 PM   #146
MDPotter
MDPotter's Avatar
I'm in GJ as well, restoring a '64 for my dad. I just finished painting everything. Chassis is 80% complete and we will start putting the body back together this weekend.
Your '72 is awesome, I'd like to build that body style for myself.
MDPotter is offline   Reply With Quote
Old 09-14-2018, 03:58 PM   #147
olrosa
olrosa's Avatar
That's awesome! I'd love to see it sometime
Old 09-15-2018, 01:01 AM   #148
namloc
namloc's Avatar
Very cool. Been in the back of the crowd watching. Did ya get the vibration issue doused out ?
The Snortin' Bull
namloc is offline   Reply With Quote
Old 09-15-2018, 10:47 AM   #149
olrosa
olrosa's Avatar
ya, it was the bearing in the back of the tranny
Old 01-31-2019, 07:17 PM   #150
olrosa
olrosa's Avatar
Who here has replaced the bearing in the back tail section of the 3 on the tree tranny? Where the drive shaft slides in.
I need some advice. Can I just pull it out or does the transmission have to be dropped? Thank you.
