03-13-2018, 01:30 AM | #126 |
Re: Let's play name that part, bolt, harness, screw....
Your name says it all metal and wood floor adjustable brackets.
03-13-2018, 10:03 PM | #127 |
Carpe manana
Yep. Door latch to door.
The smaller versions are used to affix the lift gate strut to the lift gate on K5s.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
03-22-2018, 12:22 PM | #128 |
Is this a fuel pressure regulator or what?
1968 C10 |
04-02-2018, 08:53 PM | #129 | |
Carpe manana
Anyone know where these seals go? I know generally but not the exact spot.
04-03-2018, 01:29 AM | #130 |
Scrapper 1
that Excssery bolts have so many uses.I now use them as new ground location's all over your truck makes it easier to get to and i can add more then 1 ground to the bolt.Plus if i need to use both sides in the cab i can cleans up my grounds.I have them for metric bolts and standard and fine tread.its all about making my life easier.
But the one i never see you guys showing on this whole site is the AC bracket for a 250 or a 292 Inline 6 I know nova's had them so did impala's But for the life of me never seen a chevy or GMC truck with AC with a inline 6 seen it with the 305 V6 so show me some inline 6 with AC from 1960--72.they are harder to find then the rarest GMC 1 ton short bed or the crew cab 4 door 1960--72 trucks.i've never seen any pics with the factory AC with that big A6 compressor |
04-05-2018, 08:39 AM | #131 |
Carpe manana
I believe this is the correct location for these seals....
06-16-2018, 10:00 AM | #132 |
Carpe manana
Ok - anyone recognize these springs? Seven inches long...
I need two more please
06-16-2018, 10:16 AM | #133 |
Parking brake cable retainer springs?
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count Last edited by SoCoC10; 06-16-2018 at 10:22 AM. |
06-16-2018, 10:17 AM | #134 |
Carpe manana
06-16-2018, 10:31 AM | #135 |
I demand a recount! I changed my guess before you replied!
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
06-16-2018, 01:03 PM | #136 |
Here are a few loose connectors I found while working under the hood.
These two could be almost anything... This one however is totally unknown to me... Initially I thought proportioning valve wire, Nope! My proportioning valve has a female plug. Side View This one is easy, however my truck does not use this type of connector because it has an external regulator. Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! Last edited by bill3rail; 06-16-2018 at 01:12 PM. |
09-30-2020, 04:15 PM | #137 |
The "washers" for tail light bezel screws came up, these can work as a replacement, though you can buy #8 counter sunk washers that are close.
The package calls these ferrule washers, but I think they're really "Cup Washers" or "Neck Washers". Difference is, these are #10, the original screws are #8. No sign of a #8 replacement "cup-washer". The length is a bit too long. I mostly ruined the first with my vise, that doesn't work, but luckily the package has five pieces So the last four were slipped onto a nail to hold it in place without ruining them, with just enough play so the washer spins freely between the vice & nail head of the nail for an easy cut with a Dremel. I cut more than I needed, Curtb1971 provided the exact measurements previous page. Can sand/polish the top rim using the nail if need be.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-02-2020 at 10:44 PM. |
10-02-2020, 11:30 PM | #138 | |
Here guys/gals, have fun, very doable They might be a pinch hard to see, but descriptions are added for "clarity". Where are these bolts used?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
10-03-2020, 12:57 AM | #139 |
I'm going to take swing and guess the top and bottom bolts are for the rag joint?
1971 LSX "Bonnie" build thread http://67-72chevytrucks.com/vboard/s....php?p=8026381 paypal is curtbarton1971@yahoo.com |
10-03-2020, 07:33 AM | #140 |
Carpe manana
X2 rag joint.
10-03-2020, 11:53 AM | #141 |
Ding ding ding. Then you know the other one too?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-03-2020 at 12:02 PM. |
10-03-2020, 11:56 AM | #142 |
Carpe manana
Brake booster related
10-03-2020, 12:01 PM | #143 | |
Darn, I already gave it away. I'm removing it now
Guess again Quote:
STEERING BOX BOLTS UPPER CONTROL ARM BRACKET BOLTS - TOP These bolt on to fixed nuts like for the steering box. My truck had three original types, all GR8. One L8, One stamped with a circle, and two stamped with a dog bone. ENGINE CROSSMEMBER TO FRAME RAIL WALL BOLTS. If memory serves me these take fixed nuts as well. So in a nutshell, if there's a fixed square nut in the frame for a 7/16" bolt you can bet it probably calls for GR8 "L8" type bolt. On a side, I think there are many misconceptions where a GR8 should be used, GM didn't install many for good reason. I can say unless perhaps pulling a block, GR8 is out for long block components. Matter of fact someone long ago busted a GR8 on what's now a LH head, likely from doing just that. The heads came off a 68 Camaro BBC. I spent many hours drilling it out, and if not for my B/A son it would have been many more. I tapped it 7/16, though the hole isn't used.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 04-05-2021 at 11:25 AM. |
10-04-2020, 12:04 AM | #144 |
How about these. Truck takes one, I have two. One is stamped "N" like the rag joint bolts. The other is stamped "WB".
Trivia, the "N" bolts on at least my ride were special bolts, for lack of a better term. Rag joint, bed to frame carriage bolts and this. Double F were special bolts too, you know, like the one you guys haven't figured out yet post 138?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-04-2020 at 12:09 AM. |
10-04-2020, 05:36 AM | #145 |
Maybe steering shaft to column bolts
10-04-2020, 10:56 AM | #146 |
Yep. I think technically the pot joint clamp but you're right there.
Speak of right there, that double F bolt somehow missed post 138 I'm going to ride this out until you guys get it
10-04-2020, 11:04 PM | #147 |
The coin in the pic is the only clue for size. This maybe hard or very easy. One is orig and one NOS.
10-05-2020, 12:11 AM | #148 |
I'm stumped on that grommet, looks familiar.
Where might 5/16-18 flange nuts be used? One of these is 1/4-20, they were used with some heater hose retainers. I have two more someplace, they secure something to the dash
10-05-2020, 06:22 AM | #149 |
I see what looks like shifting arm bushings...
10-05-2020, 10:48 AM | #150 |
Not shift lever auto or standard. No steering column or trans related. Probably only find on low mileage trucks. Took mine off with 25k miles. Found the NOS on EBay a couple years ago.
2 per truck Last edited by John H.; 10-05-2020 at 11:16 AM. |
