Old 02-01-2022, 11:12 AM   #126
mobileortho
mobileortho's Avatar
Re: '50 3600 re-do. Shortening things up!
Got a 33" Ididit column on order & will have to go back to the key in the dash. I never have been a fan of the aftermarket switches for these, just don't like the way they look. Thinking about going with this push button from Digital Dawg. Curious for those who may have tried one of these or similar if they like them?
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 02-07-2022, 06:38 PM   #127
joedoh
joedoh's Avatar
gorgeous work!
thats an interesting push to start, back in the mid 90s I had an alarm called HAALT that used the same technology, disarm as you walk up, and remote start (still had to put the key in and turn it). it was buggy then but I bet 25 years of improvement will make yours better.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 02-08-2022, 12:55 AM   #128
mobileortho
Originally Posted by joedoh View Post
gorgeous work!
Thanks! The unit came in today but it’ll be awhile before I get around to installing it. Still got to rewire it and finish some body mods. ALSO, I’ve been trying my best to resist the LS bug that’s going around… BUT, I stumbled across a brand new 500 hp 6.0 built by the HotRod Engine company someone bought a year or so ago that he never installed. He said he was going to do a stroker instead. The engine normally sells for around $8K but he’s letting it go for $5K! It’s still in the original shipping crate wrapped in plastic. Supposed to be going to pick it up this weekend. Stay tuned!
Robert C.
1950 3600
Old 02-08-2022, 10:12 AM   #129
dsraven
if swapping to an LS engine you may find a keyless option online. their power train control module runs the engine but I think it is the body control module that runs the door locks and cruise control etc, not sure on the keyless start thing. anyway, maybe figure that out before you lighten your wallet just to be sure all the modules will talk to each other and not require more modules to translate jibberish from one to another. ls1tech may be worth some time perusing. I have heard of guys with issues trying to get their cruise control to work with different steering columns and pcm's etc.
nice deal on the engine. if unclear on how long it sat you could boroscope down a spark plug hole to see if there is any rusty spots in the crosshatch cyl walls etc. should be fine though as a reputable shop would ensure the assembbly lube used would hold up for as long as possible.
dsraven is online now   Reply With Quote
Old 02-08-2022, 10:49 PM   #130
mobileortho
Thanks for the heads up. I’ll be sure to scope it before I fork over any cash.
On the ignition, I don’t think there will be much of an issue because it’s carbureted, although I’ll more than likely switch over to a Holley Sniper.
Robert C.
1950 3600
Old 02-13-2022, 08:53 AM   #131
mobileortho
Scope didn’t reveal any rust. Picked it up yesterday.
Robert C.
1950 3600
Old 02-13-2022, 09:57 AM   #132
dsraven
now ya done it, started down the slippery slope. haha.
Old 02-14-2022, 11:37 AM   #133
mobileortho
I KNOW!! Couldn't help it though! I gotta stop buying parts & focus on putting them on the truck! Dakota Digital HDX gauges, Ididit column, Digital Guard Dawg ignition, Nu-Relic power windows, Altman Latches, Roddoors ABS headliner & door panels, Raingear wiper system. If one ore box shows up at my house my wife will kill me!
Robert C.
1950 3600
Old 02-14-2022, 01:09 PM   #134
dsraven
you need to have them sent to a buddies or a neighbours place, haha. have them boxed as shoes.........
Old 02-14-2022, 10:09 PM   #135
mobileortho
Ha ha! Great idea!
Robert C.
1950 3600
Old 02-26-2022, 10:38 PM   #136
mobileortho
Heard a lot of horror stories about the truck oil pan hanging to low on LS swaps, swapped it out & gained a few extra inches of clearance.
Robert C.
1950 3600
Old 02-26-2022, 10:47 PM   #137
mobileortho
Got the Dirty Dingo A/C mounted up. Swapped out the truck water pump & started mocking up the fuel injection.
Robert C.
1950 3600
Old 03-06-2022, 12:00 AM   #138
mobileortho
Mocked up the fuel rails and realized the Fitech kit didn’t include the injector wiring harness. I remember what someone told me about LS engines. He said unless you buy a complete junkyard engine you’d spend a fortune buying all the extra little stuff to make them run. So far I’ve had to buy the fuel injection kit, a/c, headers & down tubes, oil filler neck & cap, braided steam vents, throttle cable & bracket, oil filler tube, water pump (swapped the truck pump out for the car version), car oil pan & coil mounting brackets. Still gotta get a belt, the right power steering reservoir cap, a belt and coil harness AND decide what trans I’m going to use. I could use my 700r4, but doubt it will handle the power. Leaning towards a stage two 4L60 or 4L80.
Robert C.
1950 3600
Old 03-06-2022, 12:09 AM   #139
dsraven
sure looks shiny.
bear in mind that the ls engines have a different offset to the torque converter etc so a flywheel spacer is possibly needed if running something that used to be behind a small block chevy. at least thats what I seem to remember. what kind of module or ecm will you run for your engine? the ecm needs to be able to run the trans as well, check around what will work best for you and your set up. some may have different gear ratios going through the gears as well.
Old 03-06-2022, 12:40 AM   #140
oldman3
oldman3's Avatar
Looks great..Jim
oldman3 is offline   Reply With Quote
Old 03-06-2022, 09:06 PM   #141
mobileortho
sure looks shiny.
Yeah, I had read something that said an adapter was needed for the earlier model trans. I was wanted to use my 700r4 but doubt it would last long behind this LS. I I’m using the Fitech Ultimate LS EFI with trans control & it calls for the 4l60, 4l65, 4l80 or 4l85. The rear end is a 8.5 10 bolt & 3:73 gears.
Robert C.
1950 3600
Old 03-07-2022, 07:55 PM   #142
joedoh
joedoh's Avatar
pretty stuff!
Old 05-21-2022, 12:38 AM   #143
mobileortho
Been sidelined with another bout with cancer, but all good now. Got a chance to sneak into the garage to work on my door handle swap. I shaved the original turn downs handles awhile back but decided to go with a set of push buttons with locks on both doors and Altman latches. Still got a little tweaking to do but I’m satisfied with the results.
https://www.flickr.com/photos/907005...posted-public/
Robert C.
1950 3600
Old 05-22-2022, 04:38 PM   #144
mobileortho
Started playing around with the Nu-Relics power windows. I’m thinking I’m the channel needs replacing, it’s not fully seating up top.
Robert C.
1950 3600
Old 05-25-2022, 08:30 AM   #145
rnrdthefox
What's the advantage of the Dirty Dingo setup for the low mount A/C? Asking because that's where my A/C is and I'd like to keep it there but I will need to clearance the frame. Thx
rnrdthefox is offline   Reply With Quote
Old 05-25-2022, 10:42 AM   #146
mobileortho
I didn't want to spend more money changing out the accessory drive that came with the engine and had seen this setup on other AD's. I was concerned about clearance as well so I posed that question on the forum and got positive responses. I haven't mounted the engine as of yet but I'm hoping there won't be any issues.
Here's a link to the forum:
http://www.67-72chevytrucks.com/vboa...d.php?t=831032
Robert C.
1950 3600
Old 05-25-2022, 11:11 AM   #147
rnrdthefox
Ok, Thanks. I will take a closer look. I will be integrating with Vintage air setup. I asked about using my stock compressor and they said it would work so I was trying to save some money. If I can keep from notching the frame, I'll take a look at the Sanden compressor.
Old 06-05-2022, 03:19 PM   #148
mobileortho
Still limited on physical activities, but I figured test sitting the door panels couldn’t hurt me. I’ll cover them later.
Robert C.
1950 3600
Old 07-31-2022, 09:15 AM   #149
61 son of a Gun
61 son of a Gun's Avatar
I've been following your thread, I hope your doing well.
Hey, how exactly is a rainbow made?
How exactly does the sun set?
How exactly does the posi-trac
rear end on a Plymouth work?
It just does.
61 son of a Gun is offline   Reply With Quote
Old 07-31-2022, 09:55 PM   #150
mobileortho
Thanks for checking in on me. Like the truck, I’m still a work in progress, not 100% but I’m getting better. Haven’t had much time to work on the truck lately. Been busy helping raise my 2 & 3 year old grandsons & that leaves little time for anything else. I did manage to squeeze in a little time this weekend and worked on the cowl panels a bit. I’d hoped to have been finished by now but life happens.
Robert C.
1950 3600
