Old 11-23-2021, 06:57 PM   #126
SCOTI
SCOTI's Avatar
Re: 2wd swap
Originally Posted by KQQL IT View Post
Good, the bottom bolt is concerning me.
Looks like aired out it might drag/hit 1st
The drop of the pocket can make contact when air'd out depending on another variable (wheel diameter) but only when air'd out....
The images also show other details about aftermarket arms that vary.... Where the grease fitting is tapped & bushing barrel OD.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-23-2021, 08:12 PM   #127
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
The grease zerk is a easy fix. Was more worried about catching the bolt on something.
Currently playing 550 cotter pin
pickup..
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 12-03-2021, 06:24 PM   #128
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Plumbing air this weekend.
3/8 or 1/4 line into the front bags.
Old 12-03-2021, 09:15 PM   #129
SCOTI
SCOTI's Avatar
Re: 2wd swap
The 3/8 is faster which can be appreciated up front. I'm slower with 1/4" speed since I use manual control w/paddle valves.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-04-2021, 05:12 PM   #130
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Ordered 2 got a whole box.
Quick connects on the peterbilt should be ok on this bucket ?
Old 12-04-2021, 06:32 PM   #131
SCOTI
SCOTI's Avatar
Re: 2wd swap
As long as they're DOT fittings. Cheap/China fittings break easier & don't secure the line as well allowing them to pop off.@ inopportune times.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-10-2021, 12:52 AM   #132
Low Elco
Re: 2wd swap
Seems like the "touch line" is the same all the way across. 4X6 pad of 1/2-5/8 steel welded to the bottom of the crossmember for the first hit?
Low Elco is offline   Reply With Quote
Old 12-12-2021, 09:31 PM   #133
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
So we raised the upper arm up 2 inches this time.
Finally got the bumpsteer manageable.
The camber change is pretty good til full droop which is beyond the shock travel.
Old 12-12-2021, 10:04 PM   #134
SCOTI
SCOTI's Avatar
Re: 2wd swap
Visually, that curve does look good. Extension shouldn't be that much of a concern w/the shock limitation.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-12-2021, 10:14 PM   #135
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Now to build the upper bracket that looks nice.
Gonna tie it into the top flange.
Glad the in-house welder is on his game.
Old 12-12-2021, 10:33 PM   #136
SCOTI
SCOTI's Avatar
Re: 2wd swap
How do things look on the driver side interference wise (column/steering linkage)?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-12-2021, 10:58 PM   #137
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
In the way.
But that is a given with a sectioned crossmember
Old 12-13-2021, 12:20 AM   #138
SCOTI
SCOTI's Avatar
Re: 2wd swap
In the way.
True. But it depends on the amount notched. I did a small notche on the stock upper a-arm & it cleared the stock shaft. I feel that's about the limit before you have to go the multi-joint path.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-13-2021, 12:53 AM   #139
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
As soon as we raised the upper mount up it wasn't even a thought.
In the new drivers side upper bracket will be a spot for a heim.
Probably a 3 joint deal
Old 12-13-2021, 12:54 PM   #140
SCOTI
SCOTI's Avatar
Re: 2wd swap
That's what I was thinking. Once the bracket is getting moved up, adding a landing spot for a support bearing becomes easier (well... possibly becomes easier).
Nice progress.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-04-2022, 02:49 PM   #141
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Slow and low lately but progress
Old 01-05-2022, 01:48 AM   #142
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Kid sends these tonight.
2" inch dom lowers sure..
Old 01-05-2022, 09:20 AM   #143
SCOTI
SCOTI's Avatar
Re: 2wd swap
Heavy D.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-05-2022, 08:35 PM   #144
KQQL IT
At the body shop.
KQQL IT's Avatar
Wink Re: 2wd swap
So ride height is set.
3 inches from the deck.
Lower links are gonna be yuge
Old 01-11-2022, 02:23 PM   #145
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Stacks on stacks.
2nd pass of 3 to finish his lowers up
Old 01-11-2022, 03:30 PM   #146
SCOTI
SCOTI's Avatar
Re: 2wd swap
Very nice!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-12-2022, 06:09 PM   #147
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 2wd swap
Wow those links are some monsters. It all looks great.
Old 01-13-2022, 05:49 PM   #148
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Thanks.
We just realized he has been welding for a year the 11th I can't make silicone look that nice.
Old 01-13-2022, 05:53 PM   #149
SCOTI
SCOTI's Avatar
Re: 2wd swap
Thanks.
All the more impressive!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-15-2022, 10:55 PM   #150
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Lower link mock up.
Also some of his production work for his uncle.
Has a 125 pieces to do this round.
