09-27-2021, 12:35 AM | #126 |
Re: 1972 Cheyenne Super 20 on the way home
and the last pictures
09-27-2021, 04:49 PM | #127 |
Sheez, that last photo looks like a brand new truck! Cool sunset too incredible
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
09-27-2021, 06:45 PM | #128 |
09-27-2021, 08:10 PM | #129 |
Who Changed This?
That deep pan looks like what comes on the Allison Hydro?
09-27-2021, 08:18 PM | #130 |
I had a 350 mated to th400 that came out of a late 80’s 2wd one ton and it had that style pan on it.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
09-27-2021, 10:44 PM | #131 |
I agree, that last pic is a wall hanger for sure. Gorgeous truck! Think I'm developing a real liking for green trucks.
1972 C20 402/TH400/3.54 Highlander 1969 Camaro RS with SS trim, 1967 Camaro RS/SS (sold) 1983 GMC Sierra Classic 2500 crew cab (sold) 1972 Chevy C10 Cheyenne Super (sold) 1984 Chevy Silverado C20 crew cab (bought new by my uncle, in the family until I sold it) |
09-27-2021, 11:06 PM | #132 |
09-27-2021, 11:07 PM | #133 |
09-27-2021, 11:11 PM | #134 |
thanks you sir.i'm liking pretty well.i wasn't keen on all that white but i like it just fine now.i've had several of these trucks and most have been green?my 67 wagon is green?must've been a popular color back then.it is a sharp picture,i didn't take it and if i'd known the guy was there taking it,i would've got my rear end out of the shot and closed the hood?oh well,next time.
09-28-2021, 09:17 AM | #135 |
Who Changed This?
I went and checked. My bad, the Allison pan doesn't look like the 400 pan.
09-28-2021, 11:54 PM | #136 |
today i finally got my carb back together that came from j_cst_10 in Ohio,thanks Jeff,re-installed on the engine and running.dwell and timing set,oil changed and transmission filled after changing the filter and pan.i'll tinker with it some more tomorrow,i didn't drive it today but i'm sure it's already running better than it did with the screwed up carb on it.progress,i love progress.
09-29-2021, 07:22 AM | #137 |
Sweet! Well done!
09-29-2021, 09:59 AM | #138 |
10-20-2021, 10:31 AM | #139 |
well another little update,i walked out into the shop the other day and saw an oil slick working it's way accross the floor.i thought it might be water but no such luck,the pinion seal decided that it had enough.i guess sitting still for 25 years takes a toll.i pulled out the driveshaft deciding that i'd change all the u-joints,the tailshaft seal in the turbo 400 and the hanger bearing.on closer inspection,i discovered a groove in the pinion yoke so i installed a speedi-sleeve, the u-joints all like new although they have to be 25 years old or more but i know they were changed as 1 was in backwards so impossible to grease.i know it didn't leave the factory like that,so i ordered seals and decided on the hanger bearing too.the more i putter around this truck,the more neat things i learn,i've had a bunch of these trucks over the years and found cotter pins,in the bolts holding the hanger bearing to the frame bracket?never saw that before.i cleaned all the bolts and hardware in my tumbler and put it right back how the General built it.pretty cool.well the parts arrived,hanger bearing was wrong and i managed to bent the seal going in the trans tailshaft.another seal and the correct hanger bearing,we're back in business.if the weather holds out for tomorrow.we might just go to Masstown Friday night for the old car gathering,there won't be many more.
10-20-2021, 10:36 AM | #140 |
the rest of the job.
10-27-2021, 05:20 PM | #141 |
another little update.i have not yet installed them but arrived today,new front brake flex hoses from Hoses Unlimited in Michigan.great looking hoses and finally after 3 pairs of hoses all too short,a set of quality hoses that i know are going to fit.the hoses with the green tie wraps on them are what turned up,supposed to fit my truck but will not.also scrounged up a pair of tilt columns from a van and an old "A" class motorhome.one of them will make it's way into my truck this winter.i was planning to put everything to bed shortly for the winter and work on making a floor for the 39 Chrysler i'm building but i think i'm changing gears here and will pull the motor and transmission from this truck so i can clean,re-seal and paint everything.it seems everytime i drive the truck i come home with a new oil leak.sitting in storage for 25 years in Idaho saved the body but i imagine every seal and gasket has dried right up.
