11-15-2021, 10:05 PM | #126 |
Re: 1950 Chevy 3600 Woody R
Massaging that right rear corner
That corner ready for filler
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 11-16-2021 at 11:22 AM. |
11-15-2021, 10:07 PM | #127 |
The front cowl metal was so stretched that the only real option was to cut it out, straighten it, flap disk the sides, (to make it fit again) and weld the piece back in.
We’ll have to do the same on the drivers side
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 11-16-2021 at 11:23 AM. |
11-17-2021, 11:27 AM | #128 |
We finished the upper cowl
no to fill, and then on to the lowers
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 11-18-2021 at 11:08 AM. |
11-17-2021, 11:30 AM | #129 |
got the alternator bracket assembled, but the AC bracket didn’t come with instructions
I think it looks killer!
11-19-2021, 10:16 AM | #130 |
We cut the hole for the AC lines to enter the cab
we will put "door edge guard” on the steel edge, we couldn’t find an appropriate grommet This shows that all 4 hoses fit through We spent some time figuring out what ends we needed, had to order 45s for the top.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 11-19-2021 at 11:11 AM. |
11-19-2021, 10:18 AM | #131 |
We also got the corner of the cab nearly there
And did bodywork to the upper cowl Laid the initial coat of filler
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 11-19-2021 at 11:10 AM. |
11-19-2021, 11:04 AM | #132 |
Looking good Chris...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
11-19-2021, 12:14 PM | #133 |
Thanks Jim, we’re trying to make this one special!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
11-20-2021, 01:32 AM | #134 |
First we took that vent out
Then we worked on the upper cowl as you can see, it’s looking pretty darn good!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 11-20-2021 at 11:20 AM. |
11-20-2021, 01:36 AM | #135 |
Next we ironed out the dents on that passenger cab corner
a final fill, and she’s razor straight then on to the headlight bezels we have the basic look, now to braze metal from the stock bezel to the harley one Then we stripped and cut down the inners (the cut for the A-frame will happen later)
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 11-20-2021 at 11:19 AM. |
11-20-2021, 01:38 AM | #136 |
we finally figured out the AC bracket
But we will be unable to paint the alt and compressor engine color. We are unable to get the alternator casing apart for paint. We also pulled the chassis in the shop Put on the spacers and wheels, this thing is gonna look killer!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 11-20-2021 at 11:17 AM. |
11-20-2021, 01:38 AM | #137 |
Looking good. We gotta figure out the sideways pics though lol
11-20-2021, 10:15 AM | #138 |
lol... Don’t know why it does that
11-23-2021, 11:35 AM | #139 |
so the right upper cowl is ready for paint, but we found a dent in the beltline we’ll need to address
The left upper cowl had a high spot that required bodywork and another fill as well as a small dent in the beltline
11-23-2021, 11:40 AM | #140 |
There is a little book called the key to metal bumping. It is a short read and worth the time. Maybe help you with those little high and low spots. A shrinking disc is also a great tool if you have some time to practice.
11-23-2021, 11:42 AM | #141 |
There was body damage where the mirror was bolted do
as well as a dent from door hyperextension so we cut out the damaged metal, straightened, recurved, and welded it back in And here’s a link to a video of us melting the lead in the seam https://www.facebook.com/olesarge201...01162355536046
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 11-23-2021 at 11:52 AM. |
11-23-2021, 11:45 AM | #142 |
I still have lead spray spots on my garage door from removing the lead from my 57 roof drip rail. I though I would heat it and give it a shot of air. Yeah, not doing that again lol.
11-23-2021, 12:03 PM | #143 |
And the compressor came in, so we cleaned, painted, and installed
The new tensioner and knock sensors came in, so we installed them too and finally we stripped the gas tank, driveshaft, and wiring from the chassis. Tomorrow we start rebuilding the front suspension!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 11-23-2021 at 06:49 PM. |
11-23-2021, 12:38 PM | #144 |
Have one, use it! Thanks
11-23-2021, 12:40 PM | #145 |
Yeah, I don’t think air would not be a great idea!
11-23-2021, 11:33 PM | #146 |
We got the patches in the left cowl
And started laying filler Wyatt really is getting good at bodywork We also fabbed up the throttle pedal
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 11-24-2021 at 10:42 AM. |
11-23-2021, 11:35 PM | #147 |
Then Steven and Wyatt started to tear apart the front suspension
We prepped and painted it in undercoat Tomorrow we start putting it back together
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 11-24-2021 at 10:43 AM. |
11-24-2021, 08:45 AM | #148 |
OK, I have to admit I've been dilatory in checking out the links you provide. Today I went to your Facebook and ".com" links to check things out.
VERY NICE! If I can ever get in a road trip up that way, I'm stopping by to see you and that shop. I'm glad you are doing and posting this work. It keeps me motivated. Robert
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
11-24-2021, 10:12 AM | #149 |
Thank you buddy! Feel free to stop in any time, I love showing off my work!
11-24-2021, 08:51 PM | #150 |
Today we installed your 99-02 Silverado throttle cable
here are shots from the inside and the firewall
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 11-25-2021 at 10:03 AM. |
