Old 09-27-2022, 03:26 PM   #126
pjmoreland
pjmoreland's Avatar
Re: Boyd Tank Installation
Eliminating the safety roll-over valve on the vent did not solve the fuel leaking issue. I discovered that the electrical connector I have on the Aeromotive pump is becoming saturated with fuel when the tank is full. I recently rerouted the electrical wires away from the fuel lines so I could tell if the fuel was getting on the wires from the fuel lines. The connector is still becoming saturated with fuel. I'm thinking fuel is wicking up the pump wires from the pump. I sent a message to Boyd Tanks to find out if they've seen this before. Here's a video that shows fuel dripping off of the connector.
https://youtu.be/ycdYeLjtAPA
pjmoreland is offline   Reply With Quote
Old 09-27-2022, 03:29 PM   #127
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
wow - making me not to ever want to put one of these tanks in....
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 10-05-2022, 08:32 PM   #128
May70
May70's Avatar
Any update on this? Ive emailed them twice for an inquiry with no response.
Granted there was a lot going on down there the past week. They posted on 9/30 saying they were having power issues.
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 10-05-2022, 10:12 PM   #129
pjmoreland
pjmoreland's Avatar
Dave Boyd explained to me that the leaks I have been dealing with are a result of overfilling the tank. They can be avoided by leaving the tank one to two gallons below completely full. I have noticed that the leaks have happened only when the tank is filled absolutely all the way up to the top. It isn't particularly convenient to stop filling at less than all the way full though. This would be even more inconvenient for someone who has installed a long filler neck that runs over to the side of the bed. Apparently the auto manufacturers build features into their tanks that cause the gas pump to shut off at an appropriate level that will leave some unfilled space in the tank. Dave is working on a prototype fill restriction that I believe will be installed in the filler neck and will cause the gas pump to stop filling at the appropriate time. He is waiting on me to give him a measurement of the height of my filler neck, but I am away from home right now.
Old 10-06-2022, 04:17 PM   #130
Jason Banks
Jason Banks's Avatar
I have the same tank set up as you and don't have the same problems. I usually hold the nozzle up off the floor of the bed and watch the fuel level rise.
It appears that California have those 'bellows' on the nozzle that you have to compress to get the fuel to flow?
I'm guessing that isn't allowing you to get the nozzle deep down in the tank and it doesn't shut off until fuel is up in the filler.
If I were fueling up in Texas without the bellows and just dropped the nozzle in until it shut off, I would end up underfilled.
I was searching for CA gas pump bellows and found this where they call it a Nozzle Foreskin. Apparently this is a big problems for some motorcycles.
https://www.advrider.com/f/threads/c...stions.646709/
Here's another interesting one:
https://www.k1600forum.com/threads/c...le-key.186582/
Jason Banks is offline   Reply With Quote
Old 10-06-2022, 04:20 PM   #131
Jason Banks
Link was dead in those forum posts...but it appears they sell that key still
https://www.aerostich.com/aluminum-g...ozzle-key.html
Old 10-06-2022, 04:20 PM   #132
pjmoreland
pjmoreland's Avatar
Yes, I think you are right about the vapor scavenging bellows on the CA nozzles being part of the problem. It is possible to hold the bellows back by hand, and that's what I'll be doing for now.
Old 11-08-2022, 08:51 PM   #133
pjmoreland
pjmoreland's Avatar
I received a custom fill restrictor from Boyd today. I haven't filled my tank with it installed yet. It protrudes below the top of the tank, so it should cause fuel to come up the filler neck and shut off the fuel dispenser when fuel in the tank reaches the bottom of the restrictor. This will trap a layer of air at the top of the tank, which should prevent overfilling of the tank.
Old 11-08-2022, 08:56 PM   #134
kwmech
So it only leaks when you put fuel in it?? Got it! I am having my own issue with them at the moment
Old 11-08-2022, 09:09 PM   #135
pjmoreland
pjmoreland's Avatar
It leaks if I fill the tank absolutely all the way to the top. Fuel wicks up through the fuel pump wires. Based on some internet searching I've done, this is a common issue with custom fuel tanks in general. The fuel doesn't seem to wick up the wires if I leave the tank an inch or two shy of all the way full. This restrictor should make it easier to fill the tank to the correct level.
Old 11-08-2022, 09:35 PM   #136
kwmech
I would think if wicking through the wires it would do it just sitting there. Shouldn't leak at all regardless.
Old 11-08-2022, 09:39 PM   #137
pjmoreland
pjmoreland's Avatar
It does do it just sitting there parked in my garage, but only if the tank is totally full. My guess is there is some damage to the wire insulation where it passes through a gland seal at the top of the tank. Take a look at this video of the leak.
https://www.youtube.com/watch?v=ycdYeLjtAPA
Old 11-08-2022, 09:40 PM   #138
kwmech
Those wires are usually epoxied in place aren't they?
Old 11-08-2022, 09:44 PM   #139
pjmoreland
pjmoreland's Avatar
The wires pass through a cord grip similar to the one below. You can see it in the video I posted above. It's the blue one.
Old 11-08-2022, 09:54 PM   #140
kwmech
So if the tank is dropped to get a complete look and access to that, can it be taken apart and the wires glued to seal?
Old 11-09-2022, 02:14 AM   #141
pjmoreland
pjmoreland's Avatar
Yes. I have removed my tank about 5 times now. It is easy. I will be investigating the wires soon.
Old 11-09-2022, 05:01 PM   #142
May70
May70's Avatar
Is boyd pretty responsive? Ive emailed twice and FB msg'd them and no response.
Old 11-09-2022, 05:03 PM   #143
pjmoreland
pjmoreland's Avatar
They're reasonably responsive. Sometimes it takes them a couple of days to respond.
Old 11-09-2022, 05:41 PM   #144
kwmech
I've been waiting 2 weeks by phone and e-mail
Old 11-09-2022, 06:07 PM   #145
May70
May70's Avatar
I emailed them in Sept, then again in Oct and then messaged their Facebook since then.
Old 11-09-2022, 09:37 PM   #146
kwmech
Any response??
Old 11-10-2022, 07:16 AM   #147
May70
May70's Avatar
Any response??
No. That’s why I was curious how others we being responded to. Not sure if you have to purchase something first to get a response or what the deal is.
Old 11-10-2022, 09:06 AM   #148
67C10Step
67C10Step's Avatar
Must be more of an indication of demand or free time. Back when I purchased my tank from Boyd's (about 2 years ago) the communication was very satisfactory.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 11-13-2022, 12:15 PM   #149
pjmoreland
pjmoreland's Avatar
I removed my fuel pump last night to inspect the wires for any damage that would allow fuel to wick up the insulation. I did not find any damage. The wires run through an electrical connector inside the tank. I disconnected the two halves of the connector, and there was a small amount of white powdery substance inside. Not sure what that was. Maybe mold release agent that fuel getting inside the connector has washed off of the seal? Anyway, I'm assuming fuel is getting into the wires through the top end of that connector.
I just put it all back together as-is. I'm going to give the fuel restriction a chance to prevent leaking. I filled the tank up with the restriction last night, and it did its job well. There is no fuel leaking this morning.
If the fuel wicking issue shows up again, then I'll look into a solution.
Old 11-13-2022, 12:19 PM   #150
kwmech
Cross your fingers
