12-06-2023, 11:38 AM | #126 |
Active Member
Re: My 1967 Chevy K20 Build Thread
Nice work Clay! I just went through your whole build thread. I'm just a step behind you on getting the cab stripped down and in primer as well on my build. You got a lot accomplished over the past year! Looking forward to seeing the K10 getting put back together.
Also good to see another AZ'er on the build board.
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
12-06-2023, 11:50 AM | #127 | |
Clay
Clayton Sikes Peoria, Arizona 1967 Chevy K20 Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272 |
12-07-2023, 10:31 AM | #128 |
Active Member
Clay, It was great to meet you and stop by your garage yesterday afternoon and see your project and talk trucks.
12-07-2023, 10:49 AM | #129 | |
Clay
12-10-2023, 10:08 AM | #130 |
12/9/2023
Epoxy Prime Applied to Cab I believe that I have finally gotten the cab to the point where I can prime and seal the metal so that it doesn’t rust. I cleaned the metal as best I could with acetone and ensured that the entire surface had a decent tooth on it to accept the epoxy primer. I don’t have a paint booth unfortunately, so I was forced to spray this in my driveway. I have also realized that despite my best efforts, I am no painter…..I did get decent coverage, but I will have a ton of sanding to do. I got runs in the primer, and also had some dirt and crap fly into it as it was drying. I didn’t realize how challenging it would be to paint an irregular shaped object like a cab. There were some areas that I missed and some areas where I think the primer started to flash as I came back over it causing bubbles in it. It is nothing that can’t be fixed, but it will cause me a bit more labor in the future. My main goal anyway was to get a coat of primer on it so that it wouldn’t flash rust. It will likely sit like this until after the holidays before I can do anything else on it anyway. I have decided however, that I will just have it painted. I still intend to do the body work to the best of my ability, but I found a guy local that will shoot paint on it for me. I figure that is the best course of action at this point. I think I can likely paint the smaller flatter things like fenders and such, but the big stuff I will leave to the professionals.
12-10-2023, 10:10 AM | #131 |
More.....
12-11-2023, 09:30 AM | #132 |
Active Member
Nice job, Clay! Good to see the cab in primer.
12-11-2023, 12:20 PM | #133 |
Thanks Scott! Yeah, it looks good from 10 feet away, but I am about as good painting as I am with neurosurgery....LOL
I will sand it all out and do the body work and then just pay someone to shoot everything for me. I am going for a driver and not a show car with this build so I think that I can outsource the painting and still not totally break the bank. Clay
12-17-2023, 08:51 AM | #134 |
Looks good Clay!
71 C10 72 K20 72 K10 Super Kirk |
12-19-2023, 05:47 PM | #135 |
Looks good! It's pretty rewarding to finish stuff by yourself at the end of the day.
My 1970 C10 ChassisFab LWB to SWB Build Thread |
01-21-2024, 06:18 PM | #136 | |
But, do the brake drums just slide off the spindle? I pulled my spindle and hub as an assembly and can't seem to get them apart? I did take the 2 screws that hold them together and air hammered around the hub on the drum(before I just pulled them together). Had to quit for today, but I thought tomorrow I would parts washer the grease out of the hub and stick them in the sandblaster to make sure there's not paint/grime buildup causing a ridge at the ID of the drum. I say that, because when they were still on the axle. I could pry lightly between the backing plate and drum and see movement at the lug studs. I also lightly heated the drum in the same place. I'm trying to be gentle for fear of warping them like you thought you might have.... |
01-21-2024, 06:49 PM | #137 | |
Good luck! Clay
01-21-2024, 08:16 PM | #138 |
The good news is, the drum and spindle came right off the brake shoes, still stuck together. I'm going to proceed with the sandblast clean up and then I'll try to stick it the press to 'gently' separate them.
01-24-2024, 12:28 PM | #139 |
Cab looks great. I see so many people doing extensive work to their trucks to repair floors and such but hardly any mention or show of them actually putting effort into preventing it from coming back. The undercoating looks great.
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
01-30-2024, 01:05 PM | #140 |
12/10/2023 - 1/30/2024
Cab body work and preparing for body work on front clip Well, the major body work on the cab has been completed! I still have to shoot a seal coat for the body filler and then another 2-3 coats of high build primer / surfacer and then block all that down prior to doing a final seal coat and then I can finally paint the cab. I have to say, that seeing the cab in this state is a bit rewarding! This was a major learning experience for me. As I have mentioned in the past, I am no body or paint guy! I ended up have to remove a bunch of filler that I applied due to the fact that I didn’t like it, or I did it wrong. This resulted in using almost an entire can of body filler for just the cab with 90% of that being removed and ending up on the floor. I have made sure that I have no filler thicker than about 3/16”. So, this meant that in some cases, I would strip the filler off, rework the metal, and then reapply the filler again. A ton of waste and rework, but ultimately I am very happy with the results. The rear style lines / body lines behind the cab were a bit of a struggle for me. I redid these about 4 times before I finally broke down and hired a body guy to come over and do it right. Getting the line projected around the cab radius was a lot harder than it looked. No matter how hard I tried, I just could not get the line straight. Rather than continue to waste materials, I figured it was best to just let a professional do it. I am happy and proud that the other 98% of work was completed by yours truly. I have also begun the initial work on the front clip. I was going to start on the bed next, but after taking it apart, I have realized that there is just no saving it. It will be cheaper and quicker in the long run to just get a repop bed. Instead, I have decided to move on to the front clip. I had all of the parts media blasted by a local powder coater and have begun the process of getting those pieces coated in epoxy primer. The plan at this point will be to finish the primer on the cab, set it back on the frame for now, and then begin the body work on the front clip. After the front clip body work has been finished, I will do final block sanding on everything, seal it, and then it will be on to paint.
01-30-2024, 01:06 PM | #141 |
Here is the disassembled bed that I have decided not to use.
01-30-2024, 01:07 PM | #142 |
Here are the front clip parts that I have begun to get into epoxy primer
01-30-2024, 04:36 PM | #143 |
Active Member
Fantastic progress, Clayton! Looking forward to meeting up later this afternoon.
01-30-2024, 04:44 PM | #144 | |
Clay
02-05-2024, 06:07 PM | #145 |
2/1/2024 - 2/5/2024
Primer Cab The cab is now primered and ready to be block sanded. After doing a thorough cleaning of all the metal, I proceeded to apply a total of 2 coats of epoxy primer to the entire cab. I could have probably just spot primed where the body work was, but seeing as how the initial epoxy primer application was not all that good, I opted to ensure that the entire cab was fully sealed up. After waiting 2 days to ensure that the coats fully flashed, but was still within the window to top coat, I followed up with 3 coats of 2K primer surfacer. This was only applied to the areas that mattered, like the inside roof, back panel, and dash align with the roof, rear of cab and the door jambs. There was no reason to put any 2K primer surfacer on the firewall, floors, or anywhere else that isn’t readily visible. Now on to blocking!
02-06-2024, 10:22 AM | #146 |
Active Member
Awesome update! Love the progress you've made on this
02-06-2024, 03:41 PM | #147 |
Thanks Scott! She is getting there!
Clay
02-23-2024, 11:50 AM | #148 |
You are making great progress, that's a lot of work. I have another question, Dunbar was able the put new bushings in your existing shackles for the rear springs?
I'm trying to get mine done, just dropped them off local and he wasn't sure if he would be able to do it. The shackles themselves are apparently specific to 1967-1968 4wd trucks and I can't find anything that matches. GM PM 3888966 |
02-23-2024, 01:05 PM | #149 | |
Hi Jason, yes Dunbar was able to get the new bushings pushed in. We used the existing shackles and they just put new parts in. The only thing that I had to have rebuilt and replaced was the rearmost shackle mounts themselves. They were totally fubar, so I had another spring company (Valley Spring Service) here in Phoenix fabricate totally new brackets. Everthing fit like a glove, although I did have to do a bit of trimming on the new mounts to ensure they wouldn't rub the springs. Let me know if you need any detailed pictures or anything. Clay
02-23-2024, 01:12 PM | #150 |
I don't remember exactly what part number was what, but here is the parts list that Dunbar billed me for.
Clay
