Old 01-25-2024, 08:03 PM   #126
raggedjim
raggedjim's Avatar
Re: Previous owner '68
I've also been working on a steering wheel. I think it's out of a Pontiac Lemans but not 100% on that. I do like me some Pontiacs. It's pretty ruff. It is an art project to be sure.
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 01-26-2024, 09:21 AM   #127
hewittca
hewittca's Avatar
You're making some great progress!
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 01-26-2024, 10:27 AM   #128
raggedjim
raggedjim's Avatar
Thanks! I've always enjoyed your builds.
Roger
'70 GMC Jimmy 2wd
Old 01-26-2024, 12:35 PM   #129
wpsharpshooter
Not much grass growing under your feet with this build.
wpsharpshooter is offline   Reply With Quote
Old 01-26-2024, 09:28 PM   #130
raggedjim
raggedjim's Avatar
Trust me, the grass is coming. Didn't do anything with the truck today, my wife kidnapped me to go junking.
Roger
'70 GMC Jimmy 2wd
Old 01-27-2024, 07:44 PM   #131
raggedjim
raggedjim's Avatar
Cut out the angle strips on the bed. Also removed the steps and front panel. The upper roll of the front panel was full of rust/wasp nests/crap.
Roger
'70 GMC Jimmy 2wd
Old 01-27-2024, 07:48 PM   #132
raggedjim
raggedjim's Avatar
Who we are...
Roger
'70 GMC Jimmy 2wd
Old 02-02-2024, 09:03 PM   #133
raggedjim
raggedjim's Avatar
Well, a good friend from my first ship (27 years ago) came and visited me for awhile. We had a great time, but now he is back in Kansas and I'm back in the shop.
I had noticed some rust on the roll of the front panel so I spent some time with the welder to fill in the holes. Some used patch panels, some were small enough to weld up with no patches.
Roger
'70 GMC Jimmy 2wd
Last edited by raggedjim; 02-03-2024 at 10:37 AM. Reason: my spelling is atrocious.
Old 02-02-2024, 09:13 PM   #134
raggedjim
raggedjim's Avatar
I had noticed that the front panel seemed to stick up higher than the bedsides and when I took it off I found that the welded in nut pieces were welded in about a 1/4" off-center. At least they were consistently wrong on both sides.
Took a spot-weld cutter and cut the spot-weld on the threaded plate and then rewelded it in the correct position.
I know, it's bowed, I'll get to that later.
Roger
'70 GMC Jimmy 2wd
Old 02-02-2024, 09:19 PM   #135
raggedjim
raggedjim's Avatar
While I had the welder out I cut some filler panels for the bed stake pockets and filled those wasp nest havens up.
I have a 12" shear that works great for patch panels, especially on the thicker stuff that is tough to cut with hand shears.
Roger
'70 GMC Jimmy 2wd
Old 02-03-2024, 08:34 PM   #136
raggedjim
raggedjim's Avatar
Worked on the radiator surround. I know I want to put a filler plate between the support and the grill so I moved the protrusions on the strengthening ribs down to clear the filler plate. Pretty basis cut and weld job. I had done some work on this surround years ago but deemed it unfit for use in one of my trucks. Now I'm older and not so picky, and I am the future previous owner, I have a reputation to live up to! Some bondo and sanding and it will be just fine.
Roger
'70 GMC Jimmy 2wd
Old 02-03-2024, 08:39 PM   #137
raggedjim
raggedjim's Avatar
I also decided to remove the "points" on the top of the support. I have always hated them. Again, some bondo and paint, it should be good. As you can tell I love bondo (when applied by me).
Roger
'70 GMC Jimmy 2wd
Old 02-03-2024, 09:20 PM   #138
zicc1835
zicc1835's Avatar
Roger,
finally made the time to read through your build thread ...besides the child's play you made out of making that headboard look better than what the General left us with....... the core support mods are awesome ...wish I had your metal work and welding talent ...plus seems like you are setting some speed records with this build running the quarter in the low 9s Im going to keep close eye on what's next appreciate your attention to detail and making tired parts come to life and useful again GREAT BUILD
Jess
Ps I got a thing for Pontiacs of the 48flavor and that medium green color too
zicc1835 is offline   Reply With Quote
Old 02-03-2024, 09:27 PM   #139
raggedjim
raggedjim's Avatar
Originally Posted by zicc1835 View Post
Roger,
Jess
Thanks Jess. I do tend to try to save as much as I can, even when I know I would be better off buying repops. But I already know how to bolt things on, I need to try to learn something (even if I learn what I will never do again!) I'm not really very fast at anything, I tend to think too much, but since I retired I have made a point of working on my projects as much as my wife will let me!
And from what I can tell the headboards vary a LOT in their fit.
Roger
'70 GMC Jimmy 2wd
Old 02-04-2024, 02:20 PM   #140
72 tigger
72 tigger's Avatar
Nice fabrication and welding!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 02-04-2024, 08:03 PM   #141
raggedjim
raggedjim's Avatar
Thanks Kirk, thank god I have a grinder!
Roger
'70 GMC Jimmy 2wd
Old 02-06-2024, 07:39 PM   #142
raggedjim
raggedjim's Avatar
What in the name of western Kentucky redneckery is this? Well, I need a bed floor and I happen to have this short fleet bed floor I pulled out of a GMC that I put a different bed on. It isn't a good floor, but it ain't that bad, so I'm going to try to use it.
Roger
'70 GMC Jimmy 2wd
Old 02-06-2024, 07:49 PM   #143
raggedjim
raggedjim's Avatar
The donor, sold years ago to a guy in Tennessee.
Most guys told me to part it, but do I listen? Nope.
Roger
'70 GMC Jimmy 2wd
Old 02-06-2024, 08:15 PM   #144
raggedjim
raggedjim's Avatar
Measure, measure measure...
Roger
'70 GMC Jimmy 2wd
Old 02-06-2024, 08:37 PM   #145
raggedjim
raggedjim's Avatar
Screw it, cut, cut cut!
Roger
'70 GMC Jimmy 2wd
Old 02-06-2024, 08:45 PM   #146
raggedjim
raggedjim's Avatar
And test fit. Now all I have to do is weld in some side strips, weld up the rust holes, grind down the surface rust, rust treatment, prime, paint, and everything else. Ain't trucks fun?
By the way, the inside edge of the fleetside wheelwells are 50", exactly the width of a stepside bed.
Roger
'70 GMC Jimmy 2wd
Old 02-06-2024, 10:04 PM   #147
zicc1835
zicc1835's Avatar
you, you , ..... you are good
Old 02-06-2024, 10:15 PM   #148
raggedjim
raggedjim's Avatar
Not good, but I am persistant!
Roger
'70 GMC Jimmy 2wd
Old 02-07-2024, 09:14 AM   #149
clay68c10
clay68c10's Avatar
I like where this is going.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 02-07-2024, 09:39 AM   #150
raggedjim
raggedjim's Avatar
Thanks Clay, I'm hoping to get the bed floor to look good enuff so that one day there will be a guy on here claiming to have a one off Chevrolet prototype steel floor stepside! Most people will never even notice the steel floor, but the real truck guys will.
Roger
'70 GMC Jimmy 2wd
