Old 03-15-2013, 01:00 AM   #1476
6lcummins
Re: Finally starting my Longhorn 4x4 conversion
Originally Posted by mosesburb View Post
One thing to keep in mind with the Oasis is the 180ish-200A draw for the lighter duty unit. If you are not mounting it close to the batteries the voltage drop alone will shorten the motor life dramatically. That's the reason I went with an Extreme Outback compresssor. 100% duty cycle and a whole lot less amp draw. Yes, it puts out less air too, but I'm not running air tools on a regular basis off of my truck so that's not a major concern.
Do you have room for a York?? Hell, Autoworld probably has a bolt-on bracket for it. Bang for the buck, it can't be beat. I did not have room or I'd have one on my truck. I was even trying to engineer a pto driven setup that used a York compressor to get it out of the engine compartment, but the time came that I needed OBA and I wasn't far enough along in the engineering process to make it a feasible option so I went electric. A York with a tank on it would allow you to get rid of your shop compressor. LOL.
I dont need a big compressor, initial fill will be my biggest issue. I dont plan on draining the tanks everytime I use the horns or suspension dump. Plus thats money away from my power mods.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 03-15-2013, 08:04 AM   #1477
ryanroo
ryanroo's Avatar
yeah, the amp draw is big. but, i have a nice spot saved on the truck just on the opposite side of the framerail for the compressor. i can get it mounted with maybe 18" of cable to the motor. i also have 2 batteries, so i had thought about running the 24v version and just isolating it from the rest of the 12v stuff.
outback has a smaller belt driven that is a possibility though. not so bulky as a york. i may look into that
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 03-15-2013, 11:51 AM   #1478
watahyahknow
watahyahknow's Avatar
maibe you can do the monster cable setup that most of the audio lunatics use along with a good relay that way the amperage dont get as high , im not sure but using a (good namebrand ) capacitator from the audio setup might help too flattening the startup peakcurrent of the compressor
there accuswitches that are being used in campers mostly that helps charging a second battery on a single altenator and prevents drawing current from the starterbattery to power the interiour lighting when camping so the engine will still start when the other battery is death
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 03-15-2013, 02:33 PM   #1479
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Originally Posted by jbclassix View Post
I have a IH 466 belt driven 2 piston tumor you could bolt to the side...
I can keep an eye out for one (any) if you guys keep an eye out for a 4BT saginaw pump for me.
PS pump, or hyd. pump?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-15-2013, 02:35 PM   #1480
Dieselwrencher
Oh yeah, for $1500 I'll buy an Ingersoll Rand for the corner of the shop.
Ryan
Old 03-15-2013, 05:37 PM   #1481
jbclassix
Junk Yartist
jbclassix's Avatar
Power steering pump. I want to loose the Vacuum pump on my brothers truck all together. I could use the hydraulic pump, but that means custom lines. We are doing a remote reservoir either way.
are you looking for a particular air pump? 2 cyl? 1 cyl?
Edit: I need to look and see what compressor is mounted in our service truck. It is tiny and POWERFULL.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 03-15-2013, 09:05 PM   #1482
Dieselwrencher
I may know a guy that might have a saginaw ps pump. I'll call him and see.................
Ryan
Old 03-15-2013, 09:37 PM   #1483
ryanroo
ryanroo's Avatar
Im looking at for a 1 cyl. im not sure ill have room for the BMF
72 K20 12v build
Old 03-17-2013, 12:09 AM   #1484
jbclassix
Junk Yartist
jbclassix's Avatar
I just went all the way back to page 5 to see what you did to get your D80 mounted... the first time. And I am asking both you and Ryanroo this question. If you hypothetically mounted your axles on leaves(not the Ryanroo AirRide), would you build custom mounts to move the springs out further, or would you stick with just moving the spring pads in?
-Jeremy
Rebuilding an NP205
Old 03-17-2013, 12:57 AM   #1485
ryanroo
ryanroo's Avatar
Spring pads in. moving the mounts out would put a lot of leverage on the frame and the mount. wider is better, but to do the mounts wider would be way to much work for not uch benefit.
72 K20 12v build
Old 03-18-2013, 02:42 PM   #1486
Dieselwrencher
On mine, I just cut off the cast mounts, and got some axle perches from DIY4X. I happen to have my rear suspension for sale if you're interested. My DIY4X shackle flip, new springs, D80 spring perches, u-bolts, cast upper retaining plate, D80 lower mount, and front spring hangers. I'd seperate the stuff for sure. If I keep it around, it'll mean I need to put them on something.
Ryan
Old 03-18-2013, 09:55 PM   #1487
ryanroo
ryanroo's Avatar
markets gonna be flooded! i have a custom set of plates U bolts that point up, ballistic pads ground for 4" tubes,some custom ass shackle hangers, and stock front hangers for sale...
72 K20 12v build
Old 03-18-2013, 11:22 PM   #1488
Dieselwrencher
Ryan
Old 03-21-2013, 06:32 PM   #1489
Dieselwrencher
We finished up the 02 Dodge job this week, and I've gotten started on my GN and frame. I got the cross members welded in, and boxed in between them. Here are some smokey shots.....
Today I trimmed down the center hitch and notched my front cross member so the center section would fit in there. I sat it in the frame and low and behold the release handle hits the frame. So tomorrow, I'll notch the frame, install a tube to give clearance, and then weld in my lower supports and weld the center plate in.
Also, my brother took the center section to work to sand blast it so it doesn't retain it's dredger look.
Ryan
Old 03-21-2013, 07:03 PM   #1490
ryanroo
ryanroo's Avatar
Sweet baby jesus thank you!
that welder looks suspiciously not grey?
72 K20 12v build
Old 03-21-2013, 07:33 PM   #1491
Dieselwrencher
Just for you dude! And, I don't want to get the other one dirty yet.
Ryan
Old 03-21-2013, 07:37 PM   #1492
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Damn what are you going to be pulling with that hitch? The USS Missouri?
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 03-21-2013, 07:44 PM   #1493
Dieselwrencher
Well yeah! I've got to do in real life what Toyota and Chevy do in photoshop. Here space shuttle........ I bet I could throw some rubber on the bottom side of it and get her haulin....
Ryan
Old 03-21-2013, 07:46 PM   #1494
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Ha ha! that you could.
Old 03-22-2013, 05:21 AM   #1495
watahyahknow
i think youre underdoing it with the hitch
Old 03-22-2013, 04:19 PM   #1496
Dieselwrencher
That's a 5th wheel, not a gooseneck. Just sayin.
Ryan
Old 03-22-2013, 04:28 PM   #1497
Dieselwrencher
Well today I added some cross members to support some more weight under the center section. I then welded them in, and fit the center section to fit. Next, I cut my hitch release pin and used a die grinder to clearance the housing to allow the release pin to go up farther. I welded the handle back on, and walla! I have clearance over the frame rail and no need to cut and notch the frame rail. Then I placed the center section in and welded it up.
I then cut a piece to replace the rear cross member. I'll replace the last 2 stock cross members, and then start boxing the frame.
Ryan
Old 03-22-2013, 04:57 PM   #1498
MrBeast
high-Tech Red Neck
MrBeast's Avatar
So how far did the suspension drop stuffing all that pig iron in it? xD
Old 03-22-2013, 05:29 PM   #1499
Dieselwrencher
I don't know yet. I've got it blocked in the level position. But, it won't matter because the mammoth air bags will hold it up just fine.
Ryan
Old 03-22-2013, 05:49 PM   #1500
MrBeast
high-Tech Red Neck
MrBeast's Avatar
On my dually that is an up and coming mod, that thing is going to get full air ride all the way around with a ride height controller, I want it to ride smooth as if it were riding on rails.
