Old 03-22-2013, 06:38 PM   #1501
watahyahknow
watahyahknow's Avatar
Re: Finally starting my Longhorn 4x4 conversion
you might as whell use the bottom of the hitch assembly as the top mounts of the bags it should hold just fine and you can hide the airlines only the exaust might be in the way , i see you allready have some boxsection welded in there to fill the gap for the hitch setup and it looks like it would place the bags pretty close to the leafsprings
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 03-22-2013, 09:32 PM   #1502
ryanroo
ryanroo's Avatar
Leaf springs, we dont need no leaf springs.
i have a hunch that Ryan has some bracketry to 4 link his truck and eliminate the current springs entirely and get them bags out wide enough to promote good stability.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 03-23-2013, 12:56 AM   #1503
Mattman2010
Mattman2010's Avatar
Ive seen picture proof of the brackets!
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 03-24-2013, 08:48 PM   #1504
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I got some more done yesterday. I removed the old rear cross member, welded in the new, and removed the rest of my tank cross members. I then welded up all the un used holes from the goose neck back. Next I'll replace the last OEM cross member and then remove the stock suspension.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-24-2013, 09:48 PM   #1505
ryanroo
ryanroo's Avatar
Its all downhill from there....
72 K20 12v build
Old 03-24-2013, 11:28 PM   #1506
6BT 56
6BT 56's Avatar
Hi Ryan. Whats your hyd clutch exerience? Im abt to mount my master cyl and dont like the oem dodge 1/4 turn master. I will use the getrag slave but was hopin 4 something with a little better mount than the oem dodge master. Any thoughts ?
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 03-25-2013, 12:24 AM   #1507
jbclassix
Junk Yartist
jbclassix's Avatar
Maybe I will convince my brother he needs to box his crew cab frame... and have someone else do it
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 03-25-2013, 09:15 AM   #1508
6lcummins
You could use a Ford master and Dodge slave, but there is a little bit of adapting that will go on. What exactly dont you like about the 1/4 turn master? Aftermarket 3rd gen use a bracket that bolts to the firewall.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 03-25-2013, 03:12 PM   #1509
Dieselwrencher
The 3rd gen still twist into the bracket. We've only had one truck have issues with the master cylinder popping out out of many. You can use a 94-97 ford f-250 and 350 master and line on a dodge slave and it'll work fine. The ford master bolts on to the firewall.
Ryan
Old 03-25-2013, 03:14 PM   #1510
Dieselwrencher
Here are a couple other pictures from Saturday.
Ryan
Old 03-25-2013, 03:25 PM   #1511
MrBeast
high-Tech Red Neck
MrBeast's Avatar
So wheres the fuel tank gonna go?
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 03-25-2013, 05:11 PM   #1512
6lcummins
I know, but if he was worried about fabbing a hole in the firewall of his conversion for the 1/4 turn hydros, that would be a way around that, just like your firewall.
"STOCK"
ASSEMBLY THREAD
Old 03-25-2013, 06:23 PM   #1513
Dieselwrencher
It's going to go in between the goose neck hitch and the rear cross member. The 40 gal burb tank I have fits in there pretty good. I'll take pics of that when I get it back in there.
Ryan
Old 03-25-2013, 06:37 PM   #1514
6BT 56
6BT 56's Avatar
Hi ryan. thanks for the advice. My prob with the 1/4 turn job is it will be mounted under the floor. To work with the 56 pedals etc. I took the bracket from behind the firewall on the dodge but it just seems too easy to turn. I had visions of it popping out and me trying to get it all back together when the eng is hot. I will try to locate a ford unit and fab brkt accordingly.
Thanks again .
Old 03-25-2013, 08:44 PM   #1515
ryanroo
ryanroo's Avatar
Right where all the exhaust is going to try and go...
72 K20 12v build
Old 03-25-2013, 09:44 PM   #1516
jbclassix
Junk Yartist
jbclassix's Avatar
I thought he said something about one of those contraptions on the front that eats small cars struggling with a Yakima roof carrier and turns them into fuel.
-Jeremy
Rebuilding an NP205
Old 03-26-2013, 08:06 PM   #1517
Dieselwrencher
I removed the last stock cross member today and welded in the new. Now I have to remove the rear suspension, and get welding holes up. Then it'll be on to boxing the frame and getting the 4 link brackets placed and welded on.
Ryan
Old 03-26-2013, 08:08 PM   #1518
Dieselwrencher
Yep, pretty much sums it up. Exhaust routing is going to be fun. The easy way would be a stack, but IDK if I really want to go that route at the moment.
It fits in there pretty nice. I need to get the frame boxed, set the bed on, and see how much room I don't have above the frame first.
Ryan
Old 03-26-2013, 08:26 PM   #1519
ryanroo
ryanroo's Avatar
You dont have, pretty much any... the bedfloor supports are at the top of the frame. if you want to notch them you could have some room.
72 K20 12v build
Old 03-26-2013, 08:27 PM   #1520
ryanroo
ryanroo's Avatar
Then it'll be on to boxing the frame.
bout time.....
72 K20 12v build
Old 03-26-2013, 09:32 PM   #1521
tecky11
lo0ks great so far
Truck: 1972 International Harvester 1210
Engine: Caterpiller 3116 220 HP 630 tq
Transmission: Eaton Fuller rt 6610
Axles: Merritor I beam front axle
tecky11 is offline   Reply With Quote
Old 03-26-2013, 10:35 PM   #1522
Dieselwrencher
Originally Posted by tecky11 View Post
lo0ks great so far
Thanks! How's your truck coming?
Ryan
Old 03-26-2013, 10:36 PM   #1523
Dieselwrencher
bout time.....
I may do just that. I don't know yet. Bout time, I hear ya......
Ryan
Old 03-26-2013, 10:55 PM   #1524
tecky11
mine stalled, got a new job and dont have the time yet, i have all the parts, just need to install it
Old 03-26-2013, 11:48 PM   #1525
fummins
fummins's Avatar
You should go with the regular exhaust, I dont think a stack or dual stacks would look good on that truck. plus it will be cleaner for the truck an any trailer that you haul.
1984 chevy K20 in the works
1992 F350 cummins swap
1999 F350 powerstroke
fummins is offline   Reply With Quote
