Old 09-27-2011, 12:30 AM   #1526
VA72C10
VA72C10
VA72C10's Avatar
Re: 1967 C10 Custom Big Window
i have to agree....I like the hidden wires the best as well as black loom or the fabric style loom but still in black. I did the colored loom years ago....blue to match my blue 1980Z28 and chrome on a white VW turbo diesel beetle I had....but in 2011...that look is played out
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-27-2011, 04:45 AM   #1527
slick copper
slick copper's Avatar
I believe Summit Racing has a nice set of 8mm orange wires. And yeah, I'd stick with black loom on wires too!
Raymond
1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594
The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939
Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402
slick copper is offline   Reply With Quote
Old 09-27-2011, 09:34 PM   #1528
Slick67
Sofa King Crazy!!
Slick67's Avatar
Cool. Guess that sums it up. CHROME!!!!! Just kiddin, the black stays!
Originally Posted by 68 TT View Post
If I remember right Taylor makes a set of orange plug wires.
I wouldn't go with any other color than black on the wire looms. I usually try to hide the wires and not draw attention to them when I can't get them out of sight. The black loom helps make them disappear.
Agreed. They match alot of other stuff under the hood.
Black it is!!!! Thanks guys for the input, sometimes we gotta ask.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 09-27-2011, 09:41 PM   #1529
Slick67
Sofa King Crazy!!
Slick67's Avatar
I made a super trac bar out of my adjustable today. Still got to get a sleeve for it so it will look cleaner. It may not look as nice as the $150 trac bars but it only cost me $6 to make. WOW....that's dusty. Bringing her home for the weekend to start cleaning it for the show on the 16th.
Old 09-27-2011, 09:46 PM   #1530
jbice70gmc
jbice70gmc's Avatar
I bought an adjustable also instead of the super trac bar. Was just going to eat it. What exactly did you do? Pics!
1969 GMC SWB Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=486320
jbice70gmc is offline   Reply With Quote
Old 09-27-2011, 09:52 PM   #1531
Slick67
Sofa King Crazy!!
Slick67's Avatar
5/8-18X3 ft. All thread rod, 3 jam nuts to fit, and a nice peice of 3/8 thick metal from a Toro 32 inch mower!! I used the bolt from the rear differential and drilled 3/4 inch holes for the u-bolt and the rear end bolt. Worked great. It is alot more sturdy than you would imagine. It took 20 minutes to drill each hole. I will be using a tie rod adjustment sleeve on it instead of the jam nuts. The sleeve will allow me to adjust it without removing either end of the trac bar since the sleeve is reverse threaded.
Old 09-27-2011, 09:56 PM   #1532
Slick67
Sofa King Crazy!!
Slick67's Avatar
Oh. Forgot to mention that most tie rods are 5/8-18 so that should make it really easy to get a sleeve to fit!
Old 09-27-2011, 10:04 PM   #1533
Slick67
Sofa King Crazy!!
Slick67's Avatar
The part off the mower is easy to get because most yard crews remove them since this part makes the mower too wide to get through standard fence openings. Who woulda thought?!?!? I just cut it in half after drilling my holes. The ends are already bent at a 90 degree so the hard work was done for me!
Old 09-27-2011, 10:19 PM   #1534
jbice70gmc
jbice70gmc's Avatar
OK sorry when I looked the first time I did'nt see the pictures. Thanks
Old 09-27-2011, 10:20 PM   #1535
Slick67
Sofa King Crazy!!
Slick67's Avatar
If you need a better pic, I'll be able to post it tomorrow. Hate to see money wasted on parts that we THOUGHT we needed just to turn around and lose money on selling or trading them.
Old 09-28-2011, 12:13 AM   #1536
71Sleeper
71Sleeper's Avatar
What tranny are you running behind the 327.
71Sleeper is offline   Reply With Quote
Old 09-28-2011, 12:31 AM   #1537
mcbassin
Still Learning
mcbassin's Avatar
Hey, very nice work on the track bar. Keep up the hard work.
mcbassin is offline   Reply With Quote
Old 09-28-2011, 12:52 AM   #1538
jbice70gmc
jbice70gmc's Avatar
Thanks Slick67 those pics are perfect.
Old 09-28-2011, 07:17 PM   #1539
Slick67
Sofa King Crazy!!
Slick67's Avatar
It's the stock Turbo 400, that should handle the 327!
Well.........it does the job. I'll paint it and make it look purdy tomorrow.
Cool, I hope it helps out a few of yall that got stuck with an adjustable. Oh yeah, the tie rod sleeve didn't work so I went to the hardware store and got a 5/8-18 connector sleeve, it's about 3 inches long and will work fine. The jam nuts will be used at each end of it and another jam nut at the end of the trac bar just for good measure.
Old 10-01-2011, 05:07 PM   #1540
Slick67
Sofa King Crazy!!
Slick67's Avatar
I got the engine bay cleaned up and waxed for the most part yesterday, cleaned a little on the frame today so I can do some touch up paint on it. Started to wet sand the truck again to get it even smoother, but I only have 1500 grit here at the house so I will have to get some 2000 and work on it for a couple of days. It's starting to look better. I brought her home with me for a few days and will take her back to the shop sometime next week. Still not happy with the engine ventilation.
Old 10-01-2011, 07:20 PM   #1541
Slick67
Sofa King Crazy!!
Slick67's Avatar
Sorry, I got pic happy. Finally got a shot of it that shows the green and gold pretty good.
Old 10-01-2011, 08:15 PM   #1542
VA72C10
VA72C10
VA72C10's Avatar
Looking good!!! Did you paint the bike to match? Love the pearl!!!
Old 10-01-2011, 09:16 PM   #1543
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thanks dude! The bike was my inspiration on the color for my truck, so they are almost a perfect match. That candy and pearl really pops in the sun, and has alot of people asking what I used when they see it in person. It is kinda different......but in a good way!
Old 10-02-2011, 04:25 AM   #1544
David67
David67's Avatar
That is some sweet paint! Im diggin that bike back there too
1967 C10
Fightin' Texas Aggie Class of 2015
IG: david_r67
David67 is offline   Reply With Quote
Old 10-02-2011, 02:22 PM   #1545
67cheby
67cheby
67cheby's Avatar
cool pic
67cheby is offline   Reply With Quote
Old 10-02-2011, 05:47 PM   #1546
Slick67
Sofa King Crazy!!
Slick67's Avatar
When ya get a few extra minutes in your busy schedule you should swing by and check it out!
Originally Posted by 67cheby View Post
cool pic
Thanks, it was kinda random, I saw the colors and tried to capture it with the camera. Came out ok, but still didn't show the neon lime green.
Old 10-02-2011, 07:01 PM   #1547
72SWBChevy
72SWBChevy's Avatar
X2! Looking sweet! Cant wait to check it out again.
1977 Camaro 468 BBC - SOLD -
1972 Chevy SWB....in the works!!
2006 Crew Cab Dmax/Allison Summit White-SOLD-
2009 Toyota Tacoma V6 Pre Runner - daily driver -
my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595
72SWBChevy is offline   Reply With Quote
Old 10-02-2011, 10:45 PM   #1548
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thanks! You and the wife should come out to the Niftee 50ees again. I will more than likely be taking it to the last one which is the first weekend in November. Should be a great turnout with weather permitting.
Old 10-02-2011, 10:54 PM   #1549
77chris03
77chris03's Avatar
got the grille test fitted....and taped. everything as far as the latch and chip guard and grille are lining up perfect...pic posted on my thread
68 C10 Stepper #1- GONE 68 C10 Stepper #2
1977 Chevy Cheyenne...gone...was my first Chevy
04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD
99 Sierra Stepside, 17 Denali HD, 84 K10
My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333
My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310
77chris03 is offline   Reply With Quote
Old 10-02-2011, 11:43 PM   #1550
Slick67
Sofa King Crazy!!
Slick67's Avatar
I saw em. It looks cool when they are that stage.
1967, custom, lwb
