03-30-2015, 08:56 AM | #1526 |
Re: 1963 C-10 in NC
right-on...they do look good.
i do it the same way, why staple the inner fender to cab seals, they can't go anywhere anyway. sure like that big block... |
03-30-2015, 09:06 AM | #1527 |
Re: 1963 C-10 in NC
Thanks for the compliments.
That was my thinking too. They fit pretty snug against the firewall, so glue was a lot less time consuming. Redoing the staples was very time intensive to make them look good. Pics of the closing panels being done are on post 980, but heres a few pics in case it helps anyone else.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
03-31-2015, 08:21 AM | #1528 |
Re: 1963 C-10 in NC
Got a few minutes in on the truck last night.
Hydraulic clutch line install complete as is the -an stainless oil pressure gauge line. Got the master cylinder remounted and all lines fastened down. Will work on the brake lines soon.
03-31-2015, 08:23 AM | #1529 |
Re: 1963 C-10 in NC
Then got the inner fenders mocked in. Will paint the core support, radiator support and front fenders this weekend after mock up this week. Starting to come together....much more fun reinstalling parts than all the restoration work and tear down.
So far we are good on all clearance issues.
03-31-2015, 09:20 PM | #1530 |
Post Whore
Re: 1963 C-10 in NC
Its looking very nice! Little by little.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
04-01-2015, 08:05 AM | #1531 |
Re: 1963 C-10 in NC
Thanks TJ. I agree...even slow progress is progress though.
04-01-2015, 08:07 AM | #1532 |
Re: 1963 C-10 in NC
Finished up the radiator support last night. Spent a couple hours stripping off the 3/8" of asphalt that was adhered to the core pretty good. The surface rust was an easy task and no rot or pinholes. This core support and the radiator support are from a 61 I parted out a few years back , but are in great shape. Always nice using OEM steel!!!! Also nice having a panel that didn't fight me for once.
Heres a before & after pic
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 04-01-2015 at 08:48 AM. |
04-01-2015, 09:23 AM | #1533 |
Re: 1963 C-10 in NC
Rcvd a couple PM's about the headers I used. Hedman HTC #69136 2" primaries. I used them with POL tubular mounts. Will require frame trimming for both mounts and headers.
http://www.hedman.com/site/?d=118&dt...keID=&ModelID=
04-02-2015, 08:11 AM | #1534 |
Re: 1963 C-10 in NC
Got the radiator support complete and installed. New gaskets for the inner to radiator support and new attachment kit for the core. Another piece complete!!
Also...pic of the gaskets for the inner fender to radiator support and gaskets for the inner fender to outer fender rails. Not used from the factory, but I will be using them on my builds.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 04-02-2015 at 08:41 AM. |
04-02-2015, 08:18 AM | #1535 |
Re: 1963 C-10 in NC
Still a few wet spots in the pics where I did some small touch ups, the finish dried real nice though. I have done the inner fenders and core in bed liner. Drilled some holes for water drainage in the radiator support where they commonly hold water and got the back of grill support lined also. Paint is ordered and I should be able to spray the front end this weekend.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 04-02-2015 at 08:34 AM. |
04-02-2015, 08:36 AM | #1536 |
Re: 1963 C-10 in NC
Looking very good. It is coming together. I know what you mean by putting it back together. I know you are on cloud 9.
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
04-02-2015, 08:45 AM | #1537 | |
Re: 1963 C-10 in NC
Yeah, every piece is one more piece closer to done. The bed will probably get painted after the truck is running. Goal for now is to reassemble the front end....just paint left on the fenders, grill support and hood. Fire up the engine and get it running smoothly. New stainless steel brake lines to install front to rear, upgrade to auto adjusters on the rear brakes and driveshaft. The interior work is marginal for whats left. Just need to complete the glass frames for the door glass and install. The vent assemblies are complete and all gaskets and beltline kits are on hand. So shouldn't be too long. (hopefully)
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 04-02-2015 at 08:59 AM. |
04-02-2015, 10:30 AM | #1538 |
Post Whore
Re: 1963 C-10 in NC
Nice job on the rad support...looking more and more like a truck again.
04-02-2015, 10:35 AM | #1539 |
Re: 1963 C-10 in NC
What a great looking truck!
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
04-02-2015, 10:54 AM | #1540 |
Re: 1963 C-10 in NC
Thanks guys....as a 1 man building crew I aim to please. Nice to be able to salvage the original sheetmetal whenever possible. Also trying to fix some issues that we all encounter on the trucks...like places where water collects. Most are easily resolved. The radiator support collects water in the bays next to where they mount on the frame. So a few 1/4" holes and a few coats of bed liner should make sure the support lasts another 50 years. Also I like to fill the voids under the inner fenders where they commonly collect mud and water causing them to rust out. Will do the same for the lower part of the outer front fenders. Prone to rust due to the drainage issues.
This is actually a 61 radiator support and I noticed it has two less mounting points on the lower part of the panel as the original 63 did. I used this as I hope to use an original steel barrel shroud on the build if possible. I will probably have to trim it down to fit the big block, but its coated and waiting on install after radiator is in.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 04-02-2015 at 11:13 AM. |
04-02-2015, 11:36 AM | #1541 |
Re: 1963 C-10 in NC
your Build it looking mighty fine. Love how your truck is coming Along. one of my new favorite builds that Iv been watching a while.
Well that didn't go as planned. 1965 k20 buikd thread: http://67-72chevytrucks.com/vboard/s...=628346&page=6 |
04-02-2015, 11:55 AM | #1542 |
Re: 1963 C-10 in NC
Thanks Matt, I appreciate the compliments. It helps keep me motivated. Its easy to fall into ruts while working on these trucks and get stalled. I'd really like to enjoy driving this truck this spring and I'm looking forward to my short fleetside build next.
04-02-2015, 11:57 AM | #1543 |
Re: 1963 C-10 in NC
Anytime man! Sometimes it's the comments people leave that make us get up off the sofa and put a few hours in on these trucks. Hope you can get her done by spring man. That'd be pretty trick to cruise round in it.
04-02-2015, 12:48 PM | #1544 | |
Re: 1963 C-10 in NC
I took it off the road in June and it was a daily driver, so definitely looking to get out and drive it again. Every time I see a classic go by it reminds me that mine is blown apart in the driveway.
04-02-2015, 12:54 PM | #1545 | |
Re: 1963 C-10 in NC
I'm in the same boat man. My 65 c20 Used to be my daily driver now it's almost back together. But changed to a k20. Stinks having to look at it everyday and wishing u could drive it...then getting in your actual daily driver. Idk bout anyone else. But my daily is not that cool hah. 92 Toyota is only so much a substitute for the 65 hahaha
04-02-2015, 12:58 PM | #1546 |
Re: 1963 C-10 in NC
True, but it'll be worth the wait!!!
04-02-2015, 01:00 PM | #1547 |
Re: 1963 C-10 in NC
I'm sure it will! I just have a few things left. to do on my Build. Install engine t case and do the brakes and king pin bearings... sooooooo close I can taste it
04-02-2015, 02:46 PM | #1548 |
Re: 1963 C-10 in NC
Couple of pics of the before and after on the 1960 c-10 steel barrel shroud. Was going to use on the fleetside build, but found a real nice shroud out of a 64 to use on the 348 that fit better, so this will go on the big block...if I can make it fit without having to cut 75% of it off.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 04-02-2015 at 02:52 PM. |
04-02-2015, 04:58 PM | #1549 |
Re: 1963 C-10 in NC
Just caught the paint store in time as they are closed tomorrow for Easter. Lucky for me!!!!
Looks like we're spraying this weekend.
04-02-2015, 05:15 PM | #1550 |
Post Whore
Re: 1963 C-10 in NC
Hmm...wish my shop would give me 3 days off! lol
