Old 10-03-2011, 02:36 AM   #1551
David67
David67's Avatar
Re: 1967 C10 Custom Big Window
I'll definitely have to check it out sometime soon when I'm back in Spring.
1967 C10
Fightin' Texas Aggie Class of 2015
IG: david_r67
David67 is offline   Reply With Quote
Old 10-03-2011, 02:44 AM   #1552
71Sleeper
71Sleeper's Avatar
This is one GREAT LOOKING ride. Wish I lived closer to see it in person.
71Sleeper is offline   Reply With Quote
Old 10-03-2011, 01:16 PM   #1553
Slick67
Sofa King Crazy!!
Slick67's Avatar
Hope you are having fun up there!
Thank you! I say the same thing about alot of the trucks on here. ROADTRIP!!!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 10-05-2011, 10:29 PM   #1554
Slick67
Sofa King Crazy!!
Slick67's Avatar
Ordered some breathers for the valve covers today from So Cal Speed Shop. This will eliminate the engine pressure and look pretty good doing it. I'm gonna install them on the end of the vc's closest to the firewall. Thanks 67Cheby for pointing those out to me!
Old 10-05-2011, 10:32 PM   #1555
67cheby
67cheby
67cheby's Avatar
sweet i hope it works , thats exactly where i plan on putting mine, and then i can take the top off to fill the oil
67cheby is offline   Reply With Quote
Old 10-05-2011, 10:36 PM   #1556
Slick67
Sofa King Crazy!!
Slick67's Avatar
It should work if you have another way of venting the engine, pcv, carb intake from the filler.
Old 10-05-2011, 10:39 PM   #1557
67cheby
67cheby
67cheby's Avatar
i am still planning on putting a pvc on the back close to the cab on one of them , is that the only thing we should need ?
Old 10-05-2011, 10:39 PM   #1558
67cheby
67cheby
67cheby's Avatar
or PCV ...lol
Old 10-05-2011, 10:43 PM   #1559
Slick67
Sofa King Crazy!!
Slick67's Avatar
or PCV ...lol
Ummmmm....yeah! The letters are right together on the keyboard. Dangit.
Old 10-05-2011, 11:45 PM   #1560
71Sleeper
71Sleeper's Avatar
Originally Posted by Slick67 View Post
Thanks VA, this is even sweeter, the engine is back home!! Put some oil in it and got the pressure up, put on the starter, the alternator and the pulleys so I decided to go for it. Luckily I had help at the shop, Ronnie, Mike and Fisher....thanks guys!! Might have it runnin in a couple of days hopefully.
Attachment 794246
How do you like the alternator bracket you are running? I got the dbl hump heads also and been trying to figure out what to do about the alternator.
Old 10-07-2011, 12:18 AM   #1561
Slick67
Sofa King Crazy!!
Slick67's Avatar
Seems to be sturdy and have not had any issues with any of the brackets. The bracket on the headers does not hinder the bolts from tightening down and staying tight. I'm happy with the outcome!
Old 10-07-2011, 12:51 AM   #1562
71Sleeper
71Sleeper's Avatar
Cool! I have already stopped by the speedshop here and priced them but wasn't sure how sturdy they would be. Guess this is the route I will go. Thanks
Old 10-07-2011, 01:41 PM   #1563
Slick67
Sofa King Crazy!!
Slick67's Avatar
Of course the main bracket only works with headers, but you probably already knew that. Hope this settup works for well for you!
Old 10-11-2011, 03:19 PM   #1564
Slick67
Sofa King Crazy!!
Slick67's Avatar
After talking to 2 very knowledgeble people about the engine vacuum and breathing i finally got a clear answer. The setup that i am doing should be more than enough pcv for the engine. My breathers should be in tomorrow and i can get them installed. @ 67cheby, looks like we'll b runnin the same settup!
Old 10-11-2011, 03:20 PM   #1565
67cheby
67cheby
67cheby's Avatar
sweet...
Old 10-11-2011, 03:33 PM   #1566
Slick67
Sofa King Crazy!!
Slick67's Avatar
sweet...
Did u want to go first??? Hahaha
Old 10-11-2011, 04:30 PM   #1567
67cheby
67cheby
67cheby's Avatar
shoot no i will let you go ahead and work out the bugs for me ....LOL
Old 10-11-2011, 05:16 PM   #1568
Slick67
Sofa King Crazy!!
Slick67's Avatar
Maybe I'll just keep running this settup......if you want to do this it's a lot cheaper. Some old vc's, a little tape, and a small peice of cloth......$0.
Old 10-11-2011, 08:37 PM   #1569
butternut1972
butternut1972's Avatar
Attachment 812887
At least use some orange tape. It would match better....
1972 GMC (PROJECT LONG OVERDUE)
1998 SWB 4WD
butternut1972 is offline   Reply With Quote
Old 10-11-2011, 08:47 PM   #1570
71Sleeper
71Sleeper's Avatar
LMAO!!!nothing that a little orange paint can't fix.
Old 10-12-2011, 05:46 AM   #1571
slick copper
slick copper's Avatar
Not with how much his paint costs!
Raymond
1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594
The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939
Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402
slick copper is offline   Reply With Quote
Old 10-12-2011, 10:50 AM   #1572
Slick67
Sofa King Crazy!!
Slick67's Avatar
You guys are too much! I thought the neon green matched my paint, at least when it's in the sun, at the right direction, with you head tilted, holding your mouth just right, and only on Wednesday.
Old 10-12-2011, 08:55 PM   #1573
Slick67
Sofa King Crazy!!
Slick67's Avatar
The brown truck stopped by my house today! I finally got my breathers in from SoCal. I opted for the MOON brand for the nostalgia. Install is really easy and took about an hour or so to be totally done and to reinstall the vc's. First I used the gasket to mark where to drill the holes, drilled first with a 7/64 then stepped up to a 1/4 inch bit. They came out nice, and fit really good!!!!
Old 10-12-2011, 08:57 PM   #1574
Slick67
Sofa King Crazy!!
Slick67's Avatar
Here is a pic of the fitment on the other side.
I also tried to get my speedo workin with no luck.
Old 10-12-2011, 10:16 PM   #1575
67cheby
67cheby
67cheby's Avatar
yep ....ordering mine tomorrow..perfect fit !! plenty firewall clearance ?
1967, custom, lwb
