Closed Thread
Old 07-10-2010, 07:36 PM   #1576
Rich 5150 69
Rich 5150 69's Avatar
Re: What did you do to your truck today?
How long has it been on said fender...
I did manage to get plugs, oil, changed, greased the front end, now its too hot to get out there 102 degrees
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Old 07-10-2010, 10:55 PM   #1577
SRVBLUES64
well tomorrow will be 3 days welding, filling, sanding, sanding filler, sanding I guess not to bad
SRVBLUES64 is offline
Old 07-11-2010, 04:41 PM   #1578
losthope
losthope's Avatar
Hit the five hundred mile mark on new motor so changed the oil, painted the top and dash green, and picked up some chrome smoothies from a friend and slapped em on the truck. Hopefully metal flake and lace the top in the next week.
losthope is offline
Old 07-11-2010, 05:21 PM   #1579
daverod
SSN 706
daverod's Avatar
362 days more and you should be done.
daverod is offline
Old 07-11-2010, 05:23 PM   #1580
SRVBLUES64
I was planning on taking the week off. you seem to have me working all year,on this fender
Old 07-11-2010, 05:58 PM   #1581
markeb01
Senior Enthusiast
markeb01's Avatar
Installed my back up lights last night, and wired them up today. Waiting for it to get dark so I can take some photos of how well they illuminate the area.
The nice part being if I get tired of the setup it can simply be unbolted and removed. I'm looking forward to having reverse lights since there are no street lights where we live.
markeb01 is offline
Old 07-11-2010, 06:02 PM   #1582
Rich 5150 69
I raised the back end end up one inch, now i`m not kissing the rubber stops, when I get enough time will drop the front two inches with disc spindle kit, can`t tell that I raised it but it drives a lot better.
Old 07-11-2010, 06:36 PM   #1583
SRVBLUES64
lets see! I worked a little bit more on the fender, I cleaned the garage up a little and then I stared at all the work I have left and cried LOL
Old 07-11-2010, 06:42 PM   #1584
Rich 5150 69
Don`t feel bad about the time spent on one fender, in the end it will be worth it, I spent 120 hrs on one right rear fender for this...
Old 07-11-2010, 07:22 PM   #1585
thunder71
thunder71's Avatar
Thumbs up Re: What did you do to your truck today?
looking goodhow well do they work? are you on a reverse switch?
thunder71 is offline
Old 07-11-2010, 08:45 PM   #1586
Malibob
Malibob's Avatar
I blew a rear brake line while coming back from GG PPG Nats while going about 75 mph. Good thing I caught it there and I could slow it down instead of SLAMMING into the guy in front of me. Real good thing I had friends who helped me too. We band-aided it and I made it home all in one piece. Thanks Frank, Dave and Joey.
This statement was made possible by a grant from this station and continued support from viewers like you.
Flickr
Malibob is offline
Old 07-11-2010, 08:49 PM   #1587
markeb01
Senior Enthusiast
markeb01's Avatar
There are several transmission switches available but I actually prefer having manual control over the backup lights, so they can also be used for work lamps if desired. They are wired up to a toggle switch on the dash. It's the center switch under the safety cover, so it's easy to tell you have them on, plus I'm going to be adding an indicator light in the dash panel.
I was saving that switch for the electric exhaust cutouts, that were going on right after the new engine with the rough cam. Financial changes cancelled those plans.
I'm still waiting for it to get dark in a couple of hours to see how much they light up behind the truck. All I can tell at this point is they hurt your eyes if you look right at them in the daylight!
Here are a few more pics of how the backup lights look at night:
And these shots are in near darkness. The first is illuminated with parking/tail lights only. The second shows the power of the backup lights. I think the genuine glass prismatic lenses really makes a difference.
markeb01 is offline
Old 07-11-2010, 09:36 PM   #1588
sams60gmc
sams60gmc's Avatar
WOW your truck is CLEAN!
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline
Old 07-11-2010, 09:42 PM   #1589
thunder71
thunder71's Avatar
very good idea & having a indicator light is also good ...i have always liked your short stepper, just awesome
Old 07-11-2010, 09:43 PM   #1590
markeb01
Senior Enthusiast
markeb01's Avatar
Thanks! It looks a bit better in pictures than in real life, it does get used as a truck and we still have about 1/4 mile of gravel road in front of our house.
markeb01 is offline
Old 07-12-2010, 07:45 AM   #1591
lakeroadster
Mark,
Looks like those backup lights really work great. Are they a big amp draw such that you had to use a relay?
lakeroadster is offline
Old 07-12-2010, 12:56 PM   #1592
64c20crewcab
64c20crewcab's Avatar
7/11: Ran the cut to fit Taylor wires. Bolted up the flex plate and TH350 to the motor and FINALLY installed these back into my rig. Pic to be posted on my build thread. Thanks.
..............................._________
......___________//___[[___{\ _____
...../__(_(O)_)___/____/____/_(O)_/
1964 C20 Long Stepside 3 Door Crew Cab
- Armbruster-Stageway Conversion
Y2K INDN Chief
"ONE OF A KIND, NOT ONE OF THE CROWD"
Aug 2010 - Front end frame cleanup & engine swap done!!!
June 2011 - Rear end bagged
Sept 2011 - Rebuild motor top end
Sept 2012 - Parked and slowly working on it.
Aug 2013 - Front end bagged - finally!
Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas...
Here is my build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=335427
64c20crewcab is offline
Old 07-12-2010, 01:47 PM   #1593
markeb01
Senior Enthusiast
markeb01's Avatar
Originally Posted by lakeroadster View Post
Mark,
I thought about wiring a relay, but each bulb only draws 2 amps. They're just standard 1156 single filament bulbs. I think what makes them so bright is the housing reflector and the glass lenses, plus I always run separate ground wires to each housing so they run nearly full voltage.
I was disappointed I couldn't use the original 1133 bulbs, since they have such a distinctive appearance:
The reality being you can't see them inside the lamp anyway, and they're 6 volt, and on 6v they only last 200 hours, while the 1156's last 1200. I think I might find a way to put them on display though just because they look so unusual. Interestingly, I found information on the box label that dates the lamps to February 1951. They even came with a spool of wax coated cloth wrapped wire, which had melted into a solid glob. They must have been stored somewhere very dry and hot, because the paper mounting templates fractured like 500 year old parchment.
markeb01 is offline
Old 07-12-2010, 06:39 PM   #1594
Jdeere16
Jdeere16's Avatar
Got a little sanding done.....it feels like a never ending process.
Jdeere16 is offline
Old 07-12-2010, 07:01 PM   #1595
markeb01
Senior Enthusiast
markeb01's Avatar
It will all be worth it in the end though. I found the hood and the back of the cab the most entertaining. They'll keep you busy just about as long as everything else combined.
markeb01 is offline
Old 07-12-2010, 07:28 PM   #1596
glendale
glendale's Avatar
and maybe cut a coil up front?looks sick dude!
glendale is offline
Old 07-13-2010, 02:22 PM   #1597
Vernski
Markeb your back-up lights look great the picture a night sure brightens things up!...Vernski
Vernski is offline
Old 07-13-2010, 04:18 PM   #1598
63sbssbbw
UCA63
63sbssbbw's Avatar
Got the ps box,idler arm and tie rods in
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline
Old 07-15-2010, 02:10 AM   #1599
Bugeyev8
Bugeyev8's Avatar
Well after a few months back to work...unemployed again...so till materials run out, I will be repairing the body panels for my 62, this was todays progress, started out with 3 rh fenders and ended up with one, cut the lower section from one, fender brace from the other, stripped to bare metal welded and shot with high build epoxy, tomorrow guide coat and blocking
Bugeyev8 is offline
Old 07-15-2010, 02:14 AM   #1600
Bugeyev8
Bugeyev8's Avatar
looks like my garage, I am in the same process..only I have 8 of those cowl corners and none of them are very good and each one the antenna is in a different location !!
Bugeyev8 is offline
Closed Thread
